Dr125 running issues
hmmmnz
PostPosted: 15:22 - 20 May 2015    Post subject: Dr125 running issues Reply with quote
Hi guys. I bought a little Suzuki Dr125 same motor as (gs. Gn, gz. En125 and quite a few chinky copies)
Any way bought the bike as a wee project.
Basically it's running with a bit of a hiccup at full noise and generally underpowered. And barely does 50 on the clocks
I did the valve clearances which were non existent. So thought it might have a burnt out valve. But a co.expression test disproves this at 110psi with and with out oil in the cylinder.
Starts easily. Idles fine. But sometimes dies at idle when hot (easily starts again)
The revs hang a wee bit. But doesn't have any air leaks.
Plug chop seems to be good.
Carb has been cleaned.
Any clues as to where I should be looking for a problem.
Mucho thanks
the humans are dead
I kick arse for the lord
Suntan Sid
PostPosted: 16:36 - 20 May 2015    Post subject: Reply with quote
Is the air box standard or has some gimp drilled holes in it for more "powahz", are all the bits there, including the seal around the lid, or where ever it opens?
Is the filter good?
hmmmnz
PostPosted: 19:04 - 20 May 2015    Post subject: Reply with quote
yeah all bits are there, and all standard,
air filter was replaced with another oem item.
seems to be a bog standard bike that just needed a tidy up
the humans are dead
Suntan Sid
PostPosted: 20:30 - 20 May 2015    Post subject: Reply with quote
Could try the HT lead, check for cracks, chop a bit off the ends and make new connections.
hmmmnz
PostPosted: 21:06 - 20 May 2015    Post subject: Reply with quote
Thought the same. So had ordered a new coil, lead, plug and cap earlier today.
See if that makes any difference when it turns up.
the humans are dead
PostPosted: 22:00 - 20 May 2015    Post subject: Reply with quote
I test rode two, a 2008 and a 2011 (same owner, no idea why he had two). They were both identically dull, gutless and sluggish and just didn't want to rev - and that's by my standards.
They weren't missing though, so it sounds like something is up with yours, but I wouldn't expect miracles.
hmmmnz
PostPosted: 23:24 - 20 May 2015    Post subject: Reply with quote
for sure, they are strangled, the exhaust header has a reducing tube in it, which wouldnt helping, the cam seems very dull as well, very short duration and minimal lift,
i think even the carbs are smaller than the gs and en bikes
i went for a ride on it with the mrs little brother he was on a sinnis cafe 125, it has the same motor, and i wasnt even close to keeping up.
its more like a tuned 50cc than a 125 (even if it is a 4 stroke it should be a bit faster)
the humans are dead
The last post was made 11 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 54.42 Kb
