306 HDI hatchback water issue
Tritey This post is not being displayed because the poster is banned. Unhide this post / all posts.
misscrabstick
PostPosted: 20:11 - 20 May 2015    Post subject: Reply with quote
I think it's a bad idea, cooling systems need to run under pressure, it raises the boiling point of the coolant, no cap = no pressure=premature boiling of the coolant.
Taught2BCauti...
PostPosted: 09:26 - 21 May 2015    Post subject: Reply with quote
Apart from the head gasket, I have also seen this sort of problem caused by a partial blockage in the radiator, which results in localised over-heating.
Another thing to check - is the radiator cap the correct one and working properly?
It should have two valves - the main one allows expanding water to pass into the expansion bottle, and the smaller valve in the centre allows the water back in to the radiator as it cools.
The one on the expansion bottle only has one valve, which is non-return.
I had a car once where the previous owner had swapped the caps between the radiator and the expansion bottle (so the one on the radiator only had one valve), and it caused water to be lost at about 1/2 litre per day, until I figured it out!
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
bikenut
PostPosted: 11:57 - 21 May 2015    Post subject: con artist Reply with quote
I suppose the rear beam was worn for the tyre to scratch the arch!!
lets hope he doesn't visit here........or his mates.........white trash Karma Karma Karma
nuts about bikes
Taught2BCauti...
PostPosted: 12:15 - 21 May 2015    Post subject: Reply with quote
If it was the head gasket, at least you could have dumped a bottle of K-Seal in the rad. It would have been at least 2 months before you heard from him Smile
Iain.
PostPosted: 16:14 - 21 May 2015    Post subject: Re: 306 HDI hatchback water issue Reply with quote
Tritey wrote:
it's a nice car.
Hateful things.
However, I did do a head gasket on my petrol one in a carpark with no specialist tools having never touched one before.
Could always whack some K seal in it and hope for the best. Magic stuff Thumbs Up
The last post was made 11 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 59.38 Kb
