boat: heater blows fuses constantly.
mudcow007
PostPosted: 09:21 - 22 May 2015    Post subject: Reply with quote
something failed an giving a massive resistance hence the popped fuse?
this of any use?
Islander
PostPosted: 09:32 - 22 May 2015    Post subject: Reply with quote
You have a short circuit in the wiring or a damaged element or switch in the heater. It may even be wired incorrectly. Either way, something is presenting a far lower resistance than it should - what you read as a 'full circuit' is probably a short.
By the way, if you have a fuse blowing constantly never ever replace it with one of a higher value. That's one of the ways that electrical fires start. Find the fault, don't try to bodge around it.
Nb
PostPosted: 10:22 - 22 May 2015    Post subject: Reply with quote
Put a bulb (appropriately rated) across where the fuse goes and unplug wires until it goes out, which should help work out what area the short is in. Bet its the motor.
Taught2BCauti...
PostPosted: 08:44 - 23 May 2015    Post subject: Reply with quote
Try substituting the fuse for an ammeter, so you can see exactly how much current it is drawing, then check agains manufacturer's specifications.
A cheap multi-meter probably won't be much good for this though, you will need one with a 50A range and circuit protection.
It could also be a surge that is causing the fuse to blow - if the ammeter shows this, you could try an 'anti-surge' or 'slow-blow' fuse.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
The last post was made 11 years, 111 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 49.62 Kb
