Carb leaking fuel through overflow
Fidge This post is not being displayed because the poster is banned. Unhide this post / all posts.
Just_James
PostPosted: 00:22 - 22 May 2015    Post subject: Re: Carb leaking fuel through overflow Reply with quote
Finnian3 wrote:
when filled with water there isn't a leak, the float valve also seems to work when blowing into the fuel filter and moving the float.
Not sure what you mean here? Confused
Typically, when fuel is pouring out the overflow you've got a stuck float. If you haven't already, remove float bowl and check that the float is moving freely and that everything looks clean and gunk free.
Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125
mudcow007
PostPosted: 09:18 - 22 May 2015    Post subject: Reply with quote
so, you filled your tank with water then opened the fuel tap an it doesnt come through the overflow
but if its petrol in the tank that leaks through the over flow?
RhynoCZ
PostPosted: 19:27 - 22 May 2015    Post subject: Reply with quote
What are you talking about? Confused
NEVER put WATER, where ONLY PETROL shall be. Be sure to let it all dry out, or the next topic will be, the engine is dying under load.
Also, why would you want richer mixture? Thinking
The last post was made 11 years, 111 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 48.78 Kb
