| Medicinal_Motocross |
 Medicinal_Motocross Nova Slayer
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
| robertw95 |
 robertw95 Trackday Trickster
| bikenut |
 bikenut World Chat Champion
 Posted: 10:53 - 23 May 2015 Post subject: seals |
as above........and make sure the tiny recouperating port is clear.
this is the tiny hole usually at the bottom of the countersunk hole in the bottom of the fluid reservoir.
it is tiny ( less than 0.5mm diameter ) and important.
it is located more towards the "pressure" end of the m/cylinder, rather than the larger hole towards the "open end" of the m/cyl. By open end I mean the end that the piston goes into.
the larger hole, you will see the piston and its movement.
the first movement of the piston makes the "pressure seal" close off the tiny recouperating port so fluid pressurization can commence.
letting the brakes off uncovers the tiny recouperating port allowing the fluid return from the caliper/wheel cyl etc., meaning the brakes can release fully.
if the tiny hole is blocked then brakes cant release fully and bleeding will be problematic.
get the proper seal kit and try again.
I assume you fitted the pressure seal the correct way round and get some red rubber grease.
brakes are safety critical for you and other road users.
check correct fitting with cmsnl exploded views or see the manuals section for your bike on here.  ____________________ nuts about bikes |
| kramdra |
 kramdra World Chat Champion
 Posted: 13:38 - 23 May 2015 Post subject: Re: . |
Your almost certainly doing it wrong. Air from the port indicates the system was empty and has not been properly bled.
Get a pic of the actual damaged seal, next to the original seal, if you find yourself taking it apart again.
Inspect the old seal, if its in acceptable condition, swap it onto the new piston. If it is held in a grove, use match sticks as the removal tool, they are unlikely to damage it.
The most fool proof/reliable and quickest way to do a full system fill and bleed is to reverse fill from the calliper bleed nipple:
- Use a syringe with pvc tube to bleed nipple. 60ml is a good size (brake system is usually less than 40ml in total)
- Use PTFE tape on the bleed nipple thread, this stops fluid leaking out the thread, or air getting in while it is open.
- After filling, crack open the master cylinder banjo while pulling the brake lever to bleed. This is the highest point, and should be the only place with air if done corrrectly.
Takes me under 5 mins, I often do not need to bleed anything from callipers, though I usually do it just to be sure. |
| Taught2BCauti... |
 Posted: 13:44 - 23 May 2015 Post subject: |
The bleed nipple has a conical metal-against-metal seal on the bottom - it only needs to be screwed in enough to make a good seal, and nothing to do with how many threads remain exposed.
If there was nothing wrong with the old seal, why change it in the first place?
If the old seal was duff, are you seriously thinking about putting it back?
You probably wouldn't be any worse-off by fitting the old seal, the chances are that the oversized seal you damaged whilst forcing it into the cylinder is now blocking the bleed port.
https://bikeadvice.in/wp-content/uploads/2010/11/MC-6.jpg ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| kramdra |
| kramdra |
| kramdra |
 Posted: 20:35 - 23 May 2015 Post subject: Re: . |
Do not touch your brakes, they will never work again  |
| barrkel |
 barrkel World Chat Champion
| kramdra wrote: | The most fool proof/reliable and quickest way to do a full system fill and bleed is to reverse fill from the calliper bleed nipple:
I would rather smear my brakes in shit than use a one man bleed kit or tube in a jar, and probably more effective. |
The bleed nipple on the caliper is normally located such that it vents any air pocket that forms in the caliper (the MC bleed port vents air pockets in the line); you better be syringing long and hard enough to to force that air pocket down and out of the caliper and into the line. And cracking the MC banjo and retightening it will weaken the copper washer seal with work hardening before too long. I wouldn't do that too many times without replacing the washer.
The old-fashioned tube in a jar method works well for me, no tape needed every which place. If you're doing it right, the brake system will be under pressure whenever you crack open the bleed nipple, so air should have no chance of getting in.
It's a different matter if the brake system has been drained, of course. Filling from the bottom up saves a lot of time then. But I think Kramdra is over-doing his contempt a bit.
OP: if you are seeing lots of bubbles from the MC bleed port (the little hole at the bottom of the reservoir) as you jiggle the lever but no fluid is coming out of the system at the other end, you are probably just filling the system with brake fluid, very slowly; the air coming out is just air displaced by brake fluid. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
The last post was made 11 years, 128 days ago. Instead of replying here, would creating a new thread be more useful? |
