Quietest motorcycle possible...
superclass9
PostPosted: 13:39 - 26 May 2015    Post subject: Quietest motorcycle possible... Reply with quote
Hello everyone! My first post!
First of all, I know most people like their ride the louder the better. However, I have a hearing condition (tinnitus) that I don't want to get worse.
I also know the most important noise factor when riding is wind, and for that I already have the best noise cancelling helmet (allegedly), the Schuberth C3 PRO, and I always wear earplugs.
But to be even safer, as I'm considering a new ride and I can't find any info about noise on the internet, I come to you with the question Smile
What would you say is the quietest possible bike? (if there is such a thing) What type?
For reference, the models I'm considering are Yamaha MT-07, Kawa ER6N, Suzuki Gladius 650, Honda CB500F and the like, but I'm open to anything, at least for debate.
I know stock motorcycles have noise standards they can't max and stuff, but anyway, I guess some bikes are quieter that others, bone conduction is a thing so vibration is a factor, etc. Just your personal input will be invaluable.
Thanks a lot!!
DrSnoosnoo
PostPosted: 13:41 - 26 May 2015    Post subject: Reply with quote
At speeds over 40 mph, my helmet whistles louder than my bike.
Bike "loudness" won't make a difference. Get yourself some good quality earplugs.
PostPosted: 13:51 - 26 May 2015    Post subject: Reply with quote
Agreed, the sound from any modern 500-650 commuter bike is going to be insignificant compared to wind noise. It's a common complaint.
If I were being very picky, I'd look for one with a proper sticky-out the back exhaust that exits well behind me, which would mean the Suzuki or Honda.
flikers
PostPosted: 14:03 - 26 May 2015    Post subject: Reply with quote
Go electric. https://www.zeromotorcycles.com/eu/
Ribenapigeon
PostPosted: 14:05 - 26 May 2015    Post subject: Reply with quote
I noticed recently when belting along behind a Honda NCX700 it was very quiet compared to my Yamaha XJ6.
PostPosted: 14:07 - 26 May 2015    Post subject: Re: Quietest motorcycle possible... Reply with quote
While I wouldn't go with Zero, electric should solve engine related vibration issues and some more noise.
However, don't expect electric to be completely silent - you may well get some decent whine. However, if it was really a massive issue, you could no doubt get a belt or hub drive electric that was as quiet as you could tell.
1198
PostPosted: 14:14 - 26 May 2015    Post subject: Reply with quote
Would a decent sized full fairing not help in tipping air and so the noise of buffeting over the rider?
talkToTheHat
PostPosted: 14:16 - 26 May 2015    Post subject: Reply with quote
Unless you put a 'performance' pipe on the bike, it will be irritatingly quite. I suspect the result of such pipes is mostly an improvement in musical performance, unless you fit something that is not for road use, remove baffles and/or remove catalytic converters. All of this will likely result in requiring remapping of your ecu.
You will probably hear more induction noise than anything else from the bike. Earplugs are reasonably adept at dealing with this.
Chin curtains and the likes on a helmet make a significant difference to the amount of wind noise. Intended purpose of helmet makes a difference too, my Shark Speed R is relatively quiet sat up, but gets louder with my head down, and sportsbike fairings seem to interfere with the aero and make it louder still. Conversely my HJC FG-15 was at its quietest tucked in on a sportsbike.
Modern bikes are quiet. Too quiet.
Bandit. does. everything.
PostPosted: 14:34 - 26 May 2015    Post subject: Reply with quote
+1
https://www.webbikeworld.com/r2/windjammer/helmet-wind-blocker.htm
or
https://www.webbikeworld.com/r3/noj-quiet-rider/
If you can find them.
Mmm, Enfielding behind workmate's Bandit through town today, I had to bark at suicide peds for him.
blackbosh
PostPosted: 14:35 - 26 May 2015    Post subject: Reply with quote
Have a go on a BMW F800GT, massive fairing no wind noise and the exhaust is huge so only sound comes fom engine vibrations.
Northern Monkey
PostPosted: 14:38 - 26 May 2015    Post subject: Reply with quote
Have you got one of those Windjammer things 'borg?
I find sitting on my NC750x very loud as the screen directs air at the bottom of my helmet.
The MSX is very quiet in comparison, with no screen and a stock exhaust.
I'd never ride without foam earplugs though.
PostPosted: 14:43 - 26 May 2015    Post subject: Reply with quote
I've tried both.
The Windjammer II feels like shoving your head in a rubber minge. The reduction in either wind noise or cold is fairly minimal. After a year or so it started to come apart and dissolved into sticky rubber.
The chin curtain worked better, but it doesn't take much draft to create a whistle. It's really going to be dependent on your helmet and how deep you can bury it around the rim. (ouch)
Plugs all the way, either way.
PostPosted: 14:45 - 26 May 2015    Post subject: Re: Quietest motorcycle possible... Reply with quote
Actually yes, screen does make a big difference.
140mph behind a double bubble with ear plugs feels slower and quieter than 85mph on KLR650.
Police weren't impressed by this, however!
skatefreak
PostPosted: 14:59 - 26 May 2015    Post subject: Reply with quote
I will mention I bought a 95 import cbr600f3 with a silly loud Yoshi on it. I got a stock pipe (tenner from a breakers) and it was serious sad face! Barely knew the thing was running Sad
Don't dispare tho, rebuilt the yoshi and it's all antisocial smiles again Smile
Don't think you'll get much quieter than stock.
-Jvr
ScaredyCat
PostPosted: 15:08 - 26 May 2015    Post subject: Reply with quote
Use foam ear plugs all the time.
Also use the free Suzuki neck scarf thing that they gave out.
Tried the windjammer which just makes putting the helmet on more difficult and I'm not convinced I was getting any benefit from it.
Similar problem for me with tall screen on NCX, going to put the small one on for summer and see how that goes.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
superclass9
PostPosted: 16:26 - 26 May 2015    Post subject: Reply with quote
Thank you all for your input!
flikers wrote:
I guess that would be the safest bet, but I can't help to believe they are the light beer of motorcycles... Plus, those are like x3 the price tag of the bikes that I posted. Definitely worth having a look though.
Rogerborg wrote:
+1
or
I had heard about those wind blockers, but wouldn't that be redundant with the already covered C3 PRO helmet? I will give them a try though.
Also, anyone that owns or has tried similar bikes can relate? I'm gonna try to test drive the mt07 this weekend but I don't think I'm gonna be able to compare with others...
PostPosted: 16:44 - 26 May 2015    Post subject: Reply with quote
Most of their bikes have you sat in the wind blast.
For less money you could probably pay for someone to convert a more suitable ICE bike to electric and end up with a better spec as well as working better for you.
andyscooter
PostPosted: 17:08 - 26 May 2015    Post subject: Reply with quote
Suzuki burgman with a tall screen
PostPosted: 18:05 - 26 May 2015    Post subject: Reply with quote
True, but I'd rather go deaf.
The Wobbly Orange
PostPosted: 18:11 - 26 May 2015    Post subject: Reply with quote
Bike engine noise when compared to wind noise is so negligible anyway it should not influence your decision. As others have said pick a quiet helmet and good quality earplugs. For the bike, let your heart choose.
(Does BCF sell Nobcat earplugs?)
People tell me I am lovely. How wrong they are!
andyscooter
PostPosted: 20:05 - 26 May 2015    Post subject: Reply with quote
Well he didn't ask for a good looking quiet bike did he
Or one that handles either just quiet
PostPosted: 20:26 - 26 May 2015    Post subject: Reply with quote
https://rogerborg.mooo.com/earplugs.jpg
struan80
PostPosted: 20:29 - 26 May 2015    Post subject: Reply with quote
I've tried both.
I stopped reading right there, sign me up for one of those please.
Just throw in that new CBR650F is painfully quiet with standard exhaust. From above it seems that a lot of new bikes are like this.
Fargage would have stopped those pesky Euro's killing out decibels! (joke)
tomupcraft
PostPosted: 20:45 - 26 May 2015    Post subject: Reply with quote
What ear plugs do you use? if its the generic £5 ones you can pick up anywhere you should invest in some molded ones that are designed to cancel noise. Luckily I get mine through the NHS for swimming as I can't get water in my ears, so they're not designed to reduce the noise, but because of the fact that they are molded makes it pretty darn quiet inside my helmet.
Musicians earplugs are the ones that are molded and designed to cancel noise of all frequencies evenly. I think they're around £100 but will last years and personally, I think they are a pretty good investment to reduce noise and protect your hearing.
CBF125
PostPosted: 20:56 - 26 May 2015    Post subject: Reply with quote
I find that foam ones can be more effective than moulded ones; however the moulded ones should be more comfortable for extended periods.
The last post was made 11 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 130.85 Kb
