Helmet Cams GoPro or Alternatives?
STONEY!
PostPosted: 14:09 - 27 May 2015    Post subject: Helmet Cams GoPro or Alternatives? Reply with quote
I'm riding to Croatia next month and thinking a helmet cam would be good.
I am happy to spend a decent amount of money as long as it's not just paying for a name.
after something with decent battery life and video quality, a bar mount remote would be nice and so would the ability to take still photos.
any suggestions, recommendations, advice or what to avoid would be good.
PostPosted: 14:12 - 27 May 2015    Post subject: Re: Helmet Cams GoPro or Alternatives? Reply with quote
I have a Drift HD that does all that.
STONEY!
PostPosted: 14:26 - 27 May 2015    Post subject: Reply with quote
want to sell it? Very Happy
stonesie
PostPosted: 15:54 - 27 May 2015    Post subject: Reply with quote
Depending on your budget, they've just lowered the price of the drift ghost s and stealth 2, I would get the ghost as it has removable batteries so you can have a few and a travel charger under the seat.
Personally I have the Sony AS100V and that's different to the ghost.
pro
pro mode records in super fine quality, eats battery and memory though.
it has image stabilization.
smaller than the ghost
Cons
no rotating lens,
the remote is extra and hasn't got the best battery life, also uses WiFi so shortens the camera battery life too.
Not shower proof if you plug a microphone in. The waterproof case has no provision for a microphone.
slightly more hassle to mount.
Picture quality is harder to judge, the drift uses a Sony image sensor so they should be close.
EDIT
https://imageshack.com/a/img901/1184/Hj1UEP.jpg
https://imageshack.com/a/img537/4666/cmL2nP.jpg
Mounted on a perspex block sanded to shape on one side to match the helmet and make it sit straight, attached with 3M dual lock
doggone
PostPosted: 16:00 - 27 May 2015    Post subject: Reply with quote
The ghost is just about the best helmet cam for video but the stills from it are poor, often you might just as well grab a video frame later.
If you have a phone or other small cam for stills it would be OK.
It's all quite a faf about, beware letting the demands of trying to get good video or pics become the main objective of the trip - unless you want it to be.
notbike
PostPosted: 16:02 - 27 May 2015    Post subject: Reply with quote
Drift Ghost S is good, I have one and it does 1080p at 60fps crystal clear. Havent taken stills with it though.
SinceNow
PostPosted: 16:06 - 27 May 2015    Post subject: Reply with quote
The Drift Ghost S is now only £250 and the The Drift Stealth 2 is £150.
The Ghost S come with the remote the Stealth doesn't but you can buy the same one and use it on the Stealth for £25.
Both allow you to switch modes from record to pictures with the remote.
I find with my Ghost S the battery life is just under the 3 hours mark.
Hope that helps
Snop Doog
PostPosted: 16:07 - 27 May 2015    Post subject: Reply with quote
+1 for the Drift Ghost S
c-m
PostPosted: 16:21 - 27 May 2015    Post subject: Reply with quote
In terms of image quality the Sony AS100 beats them all (expect the newer Sonys) at 1080p in 50mbps mode. Better in low light than the gopro models and has better sound quality.
Of course it doesn't do 4k video though.
In the UK is should always come with the remote i.e liveview wrist thingy. The Camera will run for 2 hours with wifi and gps on, but can be run powered via usb even without the battery in.
The liveview remote lasts 3-4 hours.
The sony is the only one with image stabilisation.
It's waterproof without a case, but needs a case to be fully submerged.
Now for the negatives.
- It's near impossible to turn it off and on whist riding, especially if using a chest or shoulder mount. Unlike the Polariod Extreme HD which has a massive button for on/off/rec etc..
- The distortion is more extreme than the go pro (with no software correction in the supplied package)
- The GPS function isn't that great
- No auto image rotation (just mount it the right way up ffs)
- Curved lens is poor underwater
P.S Don't buy the skeleton mount for the Sony. It's shit. 1) you can't use the lens protector with it, 2) the L bracket is weak will wobble.
STONEY!
PostPosted: 18:23 - 27 May 2015    Post subject: Reply with quote
Anyone got any real life experience of the sj4000 or svc200 aaction camera's?
flikers
PostPosted: 19:17 - 27 May 2015    Post subject: Reply with quote
I have a Contour ROAM2. £90 new from Amazon.
Rotating lens. Waterproof out the box. Takes 32GB SDHC. Battery is good for 3.5 hours. Perfect design for helmet (unlike the GoPro).
Only downside for me is that it is only 720p HD at super wide angle, 1080p is a but more narrow.
wr6133
PostPosted: 19:27 - 27 May 2015    Post subject: Reply with quote
SJ4000
It's cheap
Quality is pretty good, if you can be arsed to fiddle about with the settings you can get it even better.
Batteries are cheap as chips so you can buy a load of them and have a couple on charge while using one.
Comes with pretty much all the mounting options you could ever need.
No external mic option if that's on your want list. It is possible to mod a mic jack on to it but it involves opening it up and soldering some stuff. External mic is not too noisy when cam is in the waterproof case.
Be sure you get an actual SJcam one there are crappy knock offs.
Pretty happy with mine, it's comparable to the cheap gopro and has the added bonus of removable batteries. The £200+ stuff though is obviously better
Here's a crappy video I slung together if you want to see the quality (remember to set youtube player to 1080) https://www.youtube.com/watch?v=f80c0H0yU4A
ScaredyCat
PostPosted: 19:36 - 27 May 2015    Post subject: Reply with quote
I have 2 Contour Roam 2's but the other day I was watching this (https://www.youtube.com/watch?v=CaVeVvob0Mw) video and the quality of the Sony AS100V it streets ahead of the GoPro / Roam2 - The KTM rider has a go pro, the other rider the AS100V - when they flick from shot to shot you can see the difference clearly.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
c-m
PostPosted: 20:47 - 27 May 2015    Post subject: Reply with quote
Yeah the AS100 destroys whatever the other camera is they used in terms of sharpness, detail, and colour, but some people prefer the warmth of the Gopro. Looks like the production team didn't bother to even to equalise the footage between the two either.
Why the hell have they recorded it at 60fps.
Everyone knows unless you're doing slow-mo stick to 24/25 fps. It looks more natural. 60fps is looks like bad tv, or computer generated stuff.
The last post was made 11 years, 148 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 83.84 Kb
