Rear linkage bolt stuck
steven_191
PostPosted: 16:34 - 27 May 2015    Post subject: Rear linkage bolt stuck Reply with quote
Yamaha fazer fzs 1000. The front most bolt that holds the linkage to the frame is stuck, presumably the bolt is stuck in the sleeve that sits inside the bearing. I would like to take it out as it's moving around a lot so needs to be checked. I've tried levering a 2ft pry bar against it but it's not moving but it does rotate so it's not stuck in the linkage or frame.
As it's dust/grease sealed I can't get in there with any fluids.
Any ideas?
flikers
PostPosted: 16:41 - 27 May 2015    Post subject: Reply with quote
Get some heat on it.
Fisty
PostPosted: 16:58 - 27 May 2015    Post subject: Reply with quote
Heat and beat.
Fatter and faster than Fret
The last post was made 11 years, 112 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.54 - MySQL Queries: 13 - Page Size: 35.2 Kb
