should i sand this head down?
PostPosted: 22:25 - 28 May 2015    Post subject: Reply with quote
That's not detonation damage. Foreign object impacts.
PostPosted: 22:46 - 28 May 2015    Post subject: Reply with quote
Cone filter?
None filter?
jimspeed
PostPosted: 23:31 - 28 May 2015    Post subject: Reply with quote
I would just flat the high spots off it to prevent hot spots causing det, possibly a broken ring at some point?
dremel with a fine grade flap wheel maybe good but go easy with it
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
PostPosted: 23:47 - 28 May 2015    Post subject: Reply with quote
I'd leave it. Happened a while ago. Obviously been running ok since.
When I've had similar damage (usually caused by an errant small-end needle bearing). I've tapped down the high-spots in the alloy with a small ball-pein hammer.
To sand off enough material to shift that lot, you're going to significantly increase the squish. which means skimming the head down. Where do you stop? (obviously, when the plug hits the piston... but you know what I mean)
CaNsA
PostPosted: 00:41 - 29 May 2015    Post subject: Reply with quote
PaulFzs wrote:
got the dremel out and smoothed it off, no ridges and polished off with some autosol.
Pics?
The last post was made 11 years, 107 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.8 - MySQL Queries: 13 - Page Size: 58.55 Kb
