Just had one of those days.
jjdugen
PostPosted: 15:41 - 30 May 2015    Post subject: Just had one of those days. Reply with quote
I do some work for a local trike builder. At the moment he is building one based on a 900 Divvie. As usual, the fork seals were pissing oil. Removed and rebuilt the forks, the old dust caps to be replaced by new. Came to refit them, put my dust seal in, told him to put the other on. Rebuilt everything, all nice and tight, job done..... Except he put the dust seal in upside down. All out again to put it in properly. Doah!
Day before, I helped unscramble the wiring on a lads Bandit 12. Left everything working hunky dory, he was going to refit bodywork etc.
Phone call to say he had tucked all the front wiring in behind the frame covers, turned the handle-bars, promptly torn most of the wiring as he had left it all too tight...... Another day re-splicing all that lot back together, some days its not worth getting out of bed!
SQL
PostPosted: 21:28 - 30 May 2015    Post subject: Reply with quote
PaulFzs wrote:
so what do you need help with?
Clearly to post in the correct section.
jjdugen
PostPosted: 23:31 - 30 May 2015    Post subject: Reply with quote
Well, anger management would be a start.
It was more to demonstrate that its a good idea to check and double check any job especially if the mentally deficient are assisting.
(Sarcasm IS the lowest form of wit, but then, this is BCF, what else should I expect).
The last post was made 11 years, 103 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 40.87 Kb
