 delsol World Chat Champion
 Posted: 21:43 - 31 May 2015 Post subject: |
I don't worry too much about the type. But the fluid controls the damping. Basically how quickly the forks move. If you use thicker oil the forks won't react as quickly to bumps, etc, and will likely also uncompress more slowly (such as when you come off the brakes).
Personally unless there is a specific problem you are fixing, stick with standard.
The oil level is probably more important to play with. The more oil the less air above the oil, and that air acts as a spring.
K ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
