Rotax 123 desperate help needed please
Sirus2015
PostPosted: 21:44 - 31 May 2015    Post subject: Rotax 123 desperate help needed please Reply with quote
I have a rotax 123 engine in my RS with a slight problem
i recently replaced the clutch but before that i would get a slight sort of knock from the selector area of the bike.
This knock would only happen when i am in gear and i open the clutch leaver ever so slightly.
Now i have replaced the clutch its even worse and knocks even more in the same situation. when i let go of the clutch and im going along she is fine she pulls well and dose what it should do but this seems to be only happen when i have the clutch pulled in and rev (sometimes i dont need to rev) it rattles/knocks and also the chain moves with the knocks.
I checked for play in the rod that the front sprocket is on and there is no movement and seems fine, i have tightened the chain to correct tightness, the bike is not derestricted and is not thrashed. she is run only on the best oils and is looked after well i just have little knowledge on bikes
Please if anyone has any idea i would be greatful for any advice as with out this bike im out of a job Sad
Never take life to seriously as you will never get out alive
alains
PostPosted: 10:25 - 04 Jun 2015    Post subject: Reply with quote
look how are the rubbers (damper) in the back Wheel
if they are worn it will make this bug
Taught2BCauti...
PostPosted: 11:05 - 04 Jun 2015    Post subject: Reply with quote
= Cush Drive Rubbers.
Could also be caused by hydraulic drag between the clutch plates if the oil is too thick, which you would notice less when the engine is hot.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
The last post was made 11 years, 99 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 36.45 Kb
