Replacing O-ring chain with unsealed variety?
.Chris.
PostPosted: 12:54 - 01 Jun 2015    Post subject: Replacing O-ring chain with unsealed variety? Reply with quote
Some bike spares shops and manufacturers say that if your bike was originally fitted with an O-ring type chain, you must replace it with another of the same type. Is there any actual reason for this? I wouldn't have thought that the presence or otherwise of O-rings would have any effect on how much power the chain can transmit.
I have done just this on my Honda Rebel (520 chain transmitting 18bhp) and it hasn't snapped yet! I figured that as I don't do many miles, plus the fact that I'm not keeping the bike long-term, a cheap chain would suffice.
The reason I enquire is that I'm just starting work on a Kawasaki Z400F project, which has just over 40bhp. The (530) chain that was on the bike when I bought it was an O-ring, but I was wondering if I'd be able to get away with replacing it with a cheaper unsealed chain.
Chris
1985 Kawasaki Z550F
lihp
PostPosted: 12:58 - 01 Jun 2015    Post subject: Reply with quote
I fitted an unsealed chain once as it's all I could get at short notice.
It came off within a couple of months, as it was constantly stretching. It's far far far less hassle to fit an o-ring chain and really not much more money either.
jimspeed
PostPosted: 12:59 - 01 Jun 2015    Post subject: Reply with quote
should make no difference to the strength its more that the O ring chain will last longer.
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
Irn-Bru
PostPosted: 13:15 - 01 Jun 2015    Post subject: Reply with quote
Don't buy cheap chains, they cause expensive messes:
https://cdn.bikechatforums.com/files/2015-05-23_18.11.45.jpg
Also can do a fair bit of damage to the rider (or vehicle) behind if you're (more) unlucky.
lihp
PostPosted: 13:17 - 01 Jun 2015    Post subject: Reply with quote
That doesn't look like an NC30 to me.
orac
PostPosted: 13:31 - 01 Jun 2015    Post subject: Reply with quote
the o rings keep grease inside the roller and water out. the fact that the grease is in there reduces wear and tear meaning that o ring chains should last longer
Ed Case
PostPosted: 13:33 - 01 Jun 2015    Post subject: Reply with quote
Fit an ordinary (non-0-ring chain) there's no difference just keep on top of the lubrication.
temeluchus
PostPosted: 15:09 - 01 Jun 2015    Post subject: Reply with quote
Despite what the less educated members might believe, adding o-rings to a drive chain doesn't magicly add to its strength.
Provided the chain is the correct grade, it will be fine. Unsealed chain simply needs more regular maintenance to keep it in good nick, a chain oiler goes well with unsealed chain. You can check the strengths of various grades of chain on the manufacturers websites to be sure.
Quick google shows the z400f uses 530 chain. Any 530 chain made by a decent manufacturer will be if anything, overkill.
.Chris.
PostPosted: 15:48 - 01 Jun 2015    Post subject: Reply with quote
Thanks for the replies. The main reason I'm considering an unsealed chain is that they're cheaper to buy, and I don't imagine I'll be doing all that many miles on the bike. Therefore the fact that an O-ring chain will last longer is less of an advantage.
Chris
1985 Kawasaki Z550F
Rogue_Shadow
PostPosted: 16:05 - 01 Jun 2015    Post subject: Reply with quote
Always had it drummed into me to look after the seals on a chain, O or X types.
So to get a unsealed chain to me would be like a kitten genocide Laughing
Either way, I much rather pay money for a decent quality chain (And sprocket set) and be confident it will do it's job and not let me down.
Exhibit A:
Irn-Bru wrote:
What's the difference between the chain you were looking to and a quality brand off Wemoto is all I would ask.
I know motorbikes worked just fine, pre sealed chains.
But times are a changin Rolling Eyes
temeluchus
PostPosted: 16:12 - 01 Jun 2015    Post subject: Reply with quote
Lies IT WAS AN ENDLESS KITTEN MASSACRE!
Rogue_Shadow
PostPosted: 16:28 - 01 Jun 2015    Post subject: Reply with quote
I F**KING KNEW IT !!!
Crazy old people with dem combustion engines!
temeluchus
PostPosted: 16:29 - 01 Jun 2015    Post subject: Reply with quote
All those flying split links..... all those maimed kittens. I weep at the thought.
PostPosted: 17:01 - 01 Jun 2015    Post subject: Reply with quote
Some brands of heavy duty chain have a higher tensile strength than their o-ring.
Race bikes don't use o-ring chains.
lihp
PostPosted: 17:03 - 01 Jun 2015    Post subject: Reply with quote
Race bikes also have much higher standards of maintenance too.
That statement is no different to saying, Race bikes don't use dust seals, or race bikes don't use charging systems, race bikes don't use starter motors, etc.
PostPosted: 17:12 - 01 Jun 2015    Post subject: Reply with quote
I disagree. I think it's pretty relevant because we were discussing the subject of power transmission through drive chains.
Race bikes tend to be using all of their power all of the time so if chain strength was an issue, here is where it would be highlighted.
So yes. O-ring chains are to reduce necessity for such frequent maintainance. Compared to a well maintained HD chain, they actually rob power, which is the main reason they aren't used on race bikes.
lihp
PostPosted: 17:56 - 01 Jun 2015    Post subject: Reply with quote
I don't think anybody has mentioned power transmissions through the chain, I think the maintenance issue was the question.
Though, I did 300 miles a week, and found myself adjusting the chain every couple of days with an unsealed one, where as a sealed chain got me around 2 weeks+ without needing to be adjusted.
PostPosted: 18:07 - 01 Jun 2015    Post subject: Reply with quote
Or there are automatic chain oilers. I have long held the best combination is an HD chain and automatic oiler.
Riddle me this. If an o-ring chain is sealed. Why does lubing it make a difference? What are we lubricating and why? Surely the rollers should roll around the pins and not against the sprocket. So our "sealed" o-ring chain should never require lubricating.
I have long considered there to be a whiff of male bovine excrement in the theory behind sealed drive chains.
Enclosed chains are best.
Mark65
PostPosted: 18:40 - 01 Jun 2015    Post subject: Reply with quote
I have just got 14k out of a D.I.D HD non o ring chain on my CG, take no notice, you just have to keep on top of its lube.
Mark
Ed Case
PostPosted: 19:56 - 01 Jun 2015    Post subject: Reply with quote
Been riding bikes over 40 years including European rallies with capacities of 50cc to 980cc and never had any problems with split links.
temeluchus
PostPosted: 20:39 - 01 Jun 2015    Post subject: Reply with quote
https://en.wikipedia.org/wiki/Sarcasm
PostPosted: 21:32 - 01 Jun 2015    Post subject: Reply with quote
My turbo bike uses a non-o-ring chain (EK DRZ530) AND a split link and it's been on there for 3-4 years and about 4-5000 miles. You absolutely HAVE to keep on top of the lubrication but it can be done.
Non-o-ring chains doesn't have to mean cheap or weak.
The DRZ2 chain is a non O-Ring chain designed for high horsepower drag race use only. Used by the quickest and fastest streetbikes on the planet making over 650 horsepower! Also used by NHRA Pro Stock Motorcycles. Non O-ring, 11,500 lbs tensile strength
Furrybiker
PostPosted: 12:34 - 02 Jun 2015    Post subject: Reply with quote
https://www.outdoorking.com/forum/uploads/usergals/2014/06/full-5630-16821-duckhams_tin2.jpg
By gum that took me back! although in my day it were a white tinand none of those gram thing on it!
Ed Case
PostPosted: 13:27 - 02 Jun 2015    Post subject: Reply with quote
My point exactly that split links are not necessarily as weak as are believed.
PostPosted: 14:46 - 02 Jun 2015    Post subject: Reply with quote
I used a cheap non o ring chain on my GS500 it would last ~1500 miles, utter shite.
The last post was made 11 years, 96 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 131.14 Kb
