| talkToTheHat |
 talkToTheHat World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 19:03 - 01 Jun 2015 Post subject: |
You could try heating it. That's ameliorated scratches for me. ____________________ Biking is 1/20th as dangerous as horse riding.
| Just_James |
 Just_James Could Be A Chat Bot
 Posted: 20:49 - 01 Jun 2015 Post subject: |
It does depend on the depth of the scratches on what amount of cut you'll require but you don't need any fancy specific products.
Removing scratches from plastic / acrylic is not really any different from removing them from paintwork (except you have more material to play with). If the scratches are very light, you may be able to just remove them with something with a light cut such as G3 or maybe even T-cut.
For deeper scratches you may need to flatt them out a little with some 2000s wet and dry paper first, then work through a couple of grades of abrasive paste to brink it back up.
Even very deep scuffs and scrapes can be removed, I salvaged a headlight that was very badly scuffed and had to start with 240's paper on it! ____________________ Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125 |
| talkToTheHat |
| Just_James |
 Posted: 00:47 - 02 Jun 2015 Post subject: |
If they're light, just have a go with the lightest abrasive you have and see if it makes a difference.
keep to using straight lines with moderate pressure rather than swirls / circular motions.
If the scratch remains you'll need to use a more coarse abrasive and work your way back to a finer one to achieve the final finish. ____________________ Current Bikes / Projects: 1999 Rieju RS1 50
| Major Doss |
 Major Doss Traffic Copper
 Posted: 01:33 - 02 Jun 2015 Post subject: |
Dremel things with a soft wheel are awesome for this.
I have had results using mediums such as;
1; t-cut (goes a bit cloudy, but will polish out with a final buffing-I would not do this for a long term fix).
2; Farecla (Cannot remember the grade; worked, but maybe TOO fine, had to do the rest of the screen to match- bike got stolen so no idea as to long term. Hope the thief got ghey AIDS from touching it).
3; fine grade valve lapping medium seems to work really well on a slow speed and nearly no pressure.
Regardless, Slow speed, little or no pressure, release often or you will melt the screen. That can be a git to smooth out.
Then you can raise your speed if you can reduce the pressure even further.
Hard to explain, as The Strokes once suggested with such verdant alacrity.
TL:DR Shit help really, have a go, nothing to lose.
edit; sorry JJ, circular is the way to go, it levels it out.  |
| Just_James |
 Posted: 02:12 - 02 Jun 2015 Post subject: |
| Major Doss wrote: |
I was referring to light abrasives and compounding by hand which is best kept to stright lines.
If you're using a dremel, machine polisher or any other rotary tool then quite naturally the motions will be circular
The key to keeping it level is to fade your abrasives into the work area, you don't really want to go buzzing away at a small but deep scratch with your dremel as you will radically alter the shape of the surface.
Example of a headlight I recovered.... started with heavy scuffs / indententation due to to broken fairing rubbing on it.
https://i9.photobucket.com/albums/a75/RS1Rebuild/IMG_4760_zps5a013abd.jpg
https://i9.photobucket.com/albums/a75/RS1Rebuild/IMG_4759_zps9bb47d1a.jpg
I took it down with 240s first
https://i9.photobucket.com/albums/a75/RS1Rebuild/IMG_4762_zpsa9a520ba.jpg
Then blended it a little further with 600s
https://i9.photobucket.com/albums/a75/RS1Rebuild/IMG_4763_zps17f21c09.jpg
Then blended it accross the entire unit with 2000s
https://i9.photobucket.com/albums/a75/RS1Rebuild/IMG_4764_zps4b85cd1d.jpg
Then machine polished with G3 followed by glazing compound
https://i9.photobucket.com/albums/a75/RS1Rebuild/IMG_4765_zps1ce02447.jpg
https://i9.photobucket.com/albums/a75/RS1Rebuild/IMG_4766_zps7ee833b0.jpg
Absolutely sure it's nothing like the extent OP needs to do but making the point that the principles are really quite basic - just on different scales depending on the severity of scratch / scuff and what abrasives need be used.
Start with the easiest / lightest and don't go melting into your plastic with a dremel unnecessarily  ____________________ Current Bikes / Projects: 1999 Rieju RS1 50
| Major Doss |
 Posted: 04:25 - 02 Jun 2015 Post subject: |
boss it, feller, boss it.  |
The last post was made 11 years, 95 days ago. Instead of replying here, would creating a new thread be more useful? |
