gpz 500 horn stopped working
nigel_robbins
PostPosted: 22:20 - 03 Apr 2013    Post subject: gpz 500 horn stopped working Reply with quote
I was riding into London near Marylebone when my horn started and wouldn't stop. Everyone moved out of my way and I got to work quickly Smile
It eventually stopped and blew a fuse.
I replaced the fuse and it blew again when I pressed the horn button.
Any idea where I should start looking to fix the problem ?
Thanks.
Islander
PostPosted: 22:26 - 03 Apr 2013    Post subject: Reply with quote
Get your multimeter out and check the horn feed. It'll either be shorting to earth somewhere in the wiring or the horn itself will be faulty. You can prove the horn by testing its resistance with it disconnected. If it measures zero ohms then there's your problem right there. If it has a resistance then you're going to have to test the wiring back to the horn button and find out where it's earthing out. If it's the wiring it'll probably be in the section of loom that runs between the handlebars and the horn itself - it'll probably have been chafing against the frame.
Efes123
PostPosted: 06:33 - 04 Apr 2013    Post subject: Reply with quote
Sounds like a sticky microswitch in the horn button. When you push it does it pop out again, or stay in? You probably can't hear any clicking do to the horn blaring I suppose Smile Srip the switch and give it a good clean.
Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD
There is a gap of 2 years, 58 days between these two posts...
nigel_robbins
PostPosted: 21:34 - 01 Jun 2015    Post subject: Reply with quote
Thanks for the replies.
It turned out to be faulty horns.
I bought two new ones and it's fine now.
PostPosted: 22:14 - 01 Jun 2015    Post subject: Reply with quote
Can't say we didn't get closure on this thread. Thumbs Up
Thorn This post is not being displayed because the poster is banned. Unhide this post / all posts.
Major Doss
PostPosted: 02:39 - 02 Jun 2015    Post subject: Reply with quote
I don't think that the horns were the initial problem. OP must deliver moar info. When you consider it has taken over 2 years to push his bike home from Marylebone...
The last post was made 11 years, 95 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 52.44 Kb
