magnatech oil
old-git
PostPosted: 19:18 - 02 Feb 2005    Post subject: magnatech oil Reply with quote
i have been putting castrol magnatech oil in my bike since it was new ,in the hope that it will last longer .
its a kymco 125 ..same engine as a cg125.
i have had it five years and done 25000 on it ,
but wonder if its just a waste of time, and just use any 4 stroke oil .
what do ya think then Very Happy
live long and prosper . Wink
mchaggis
PostPosted: 19:29 - 02 Feb 2005    Post subject: Reply with quote
I was always told that putting in Castrol GTX Magnatech was bad for wet clutches as it has special slippery additives in it. I don't know how much truth there is in that, but normal Castrol GTX keeps the CG lump in my bike happy.
I must not be a troll...
Mmmm, Guinness
PostPosted: 19:31 - 02 Feb 2005    Post subject: Reply with quote
Is it a car or bike oil?
old-git
PostPosted: 19:33 - 02 Feb 2005    Post subject: Reply with quote
what would be the difference then Embarassed
i put the car stuff in as the way i see it a 4stroke is a 4stroke is a 4stroke .could be wrong though Very Happy
PostPosted: 19:34 - 02 Feb 2005    Post subject: Reply with quote
It is car oil as far as I know.
It may mean your clutch will wear faster, but on a bike with not much power it's probably not going to be too bad.
Regular oil changes are probably more important than expensive oil.
Definitely avoid the expensive car oil in higher powered bikes as it can easily make the clutches go.
PostPosted: 19:36 - 02 Feb 2005    Post subject: Reply with quote
What G said.
old-git
PostPosted: 19:38 - 02 Feb 2005    Post subject: Reply with quote
but why would the clutch wear faster if the oil is more protective ? Confused
mchaggis
PostPosted: 19:41 - 02 Feb 2005    Post subject: Reply with quote
It's more slippery than normal oils, so the clutch won't produce as much friction between the plates, meaning that the clutch will slip more easily with less speed difference/ torque applied. More slipping the clutch means more wear.
If it's metal to metal contact (such as between the piston rings and cylinder or in the bearings), then the extra slippery stuff will help to protect them by helping them to float over each other rather than grinding.
Mmmm, Guinness
PostPosted: 19:44 - 02 Feb 2005    Post subject: Reply with quote
The oil has 'friction inhibtors'; basically slidey stuff.
Bike clutches are 'wet clutches'; they are immersed in oil. If there's extra slippyness here, it means they can start to slip when they should be fully engaged. This leads to increased wear as they are slipping all the time.
old-git
PostPosted: 19:45 - 02 Feb 2005    Post subject: Reply with quote
yes i see ,..but i dont think the word torque can be applied to my bike Laughing ....more talk than torque Embarassed
Scotsman37
PostPosted: 20:12 - 02 Feb 2005    Post subject: Reply with quote
One recommendation I do have is to stay well away from Halford's own make of engine oil as you'll definitely lose about 10mph off the top end. I sadly found that out several years ago when I had a 125.
After discovering the downturn in speed using Halford's oil and when it came to point of time after travelling for a few months I changed the oil again, but filled it Castrol's GTX Magnetec engine oil and within a short period of time I regained that top end speed back and kept using Castrol's oil from then on.
Good quality engine oil gives you the best possible performance from your bike and that's why Silkolene is such a good make for all bikes. I now only use Silkolene for my 550 bike and several outlets in/nearby Glasgow that sell/repair bikes only use Silkolene.
Regular engine oil changing is a must because the quality of the engine oil degrades over time i.e. It may no longer stay thick when the engine is being pushed to it's limit and/or it will become so thin/useless when the engine is being started from cold may no longer stop friction at the outset to prevent parts being worn out!
The last post was made 21 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 71.41 Kb
