CB400 Superfour idling problems (restricted)
B0ndy
PostPosted: 11:27 - 03 Jun 2015    Post subject: CB400 Superfour idling problems (restricted) Reply with quote
Hello everyone,
I recently purchased my first "big" bike, a Honda CB400 Superfour 93, after passing my mod1 and mod2 tests to gain an A2 license.
Yesterday I did some maintenance and removed fuel tank in the process, I ran the bike out of juice before removing the tank, this is where all my problems have started.
Today when riding the bike started up but it wasn't idling correctly and while taking it for a ride it cut out on me Sad .
I've fiddled with the idle screw to get it to idle correctly however it doesn't seem to have made a difference.
Here's a video a made to show how the bike idles, please note that I did not touch the throttle during the video
https://www.youtube.com/watch?v=usDdd68Sdtc&feature=youtu.be
Any help or advice is appreciated
CBF 125 -> CB400SF -> GSX600F -> ZX6R (G1) -> GSXR1000 K4 -> ZX6R (B1H Stunt bike) -> VFR800 -> R1 5PW -> Sprint 1050 -> Fireblade 929 -> ZX10R C2H -> GSXR1000 K3
B0ndy
PostPosted: 11:35 - 03 Jun 2015    Post subject: Reply with quote
Vincent wrote:
It probably needs the carbs setting up, or.........you have an air leak somewhere between the carbs and the cylinders.
Thanks Vincent. I did remove the fuel tank yesterday and before removing the fuel tank to do some maintenance I switched the petcock to the off position and run it out of juice so I didn't have petrol going everywhere after removing the tank, this is where all my problems started.
mudcow007
PostPosted: 11:58 - 03 Jun 2015    Post subject: Reply with quote
do you think you have sucked crap in the carb by letting it use all the fuel in the tank?
whip the carb(s) off an give em a quick clean
UncleFester
PostPosted: 13:10 - 03 Jun 2015    Post subject: Reply with quote
These have carb drain screws do they not?
As per Mudcow suggestion - you've probably drawn crap into the carbs or the pipes that feed them.
2017 Z1000SX
PostPosted: 13:27 - 03 Jun 2015    Post subject: Re: CB400 Superfour idling problems (restricted) Reply with quote
Not a problem for the carbs. However, I'd strongly suspect that you've sucked crap from the bottom of the tank either when running it dry or after disturbing it, and clogged one or more jets.
You could try various degrees of non-invasive fixing but it'll probably be quicker in the long run if you just whip them out and clean the jets properly.
In addition, have a look in the tank and see if it's rusting, clean it out thoroughly and fit a filter in the fuel line.
B0ndy
PostPosted: 13:31 - 03 Jun 2015    Post subject: Reply with quote
Thanks for your help all, I've decided that I'm going to get the carbs off and give them a clean as suggested
B0ndy
PostPosted: 13:36 - 03 Jun 2015    Post subject: Re: CB400 Superfour idling problems (restricted) Reply with quote
Vincent wrote:
Deffo he right screw?
Yes definitely the right screw - sorry what I said wasn't worded correctly, my mistake. What I meant was that the idle screw does make a difference to the idle speed but the bike still doesn't idle correctly, the idle speeds keeps varying in rpm and doesn't sound "right".
Thanks for checking though Very Happy
PostPosted: 13:37 - 03 Jun 2015    Post subject: Reply with quote
Be careful your restrictor washers don't fall out. Wink
B0ndy
PostPosted: 13:43 - 03 Jun 2015    Post subject: Reply with quote
hehe Very Happy
The last post was made 11 years, 97 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 77.93 Kb
