| ultraculture1... |
 ultraculture1... Two Stroke Sniffer
| stirlinggaz |
 stirlinggaz World Chat Champion
| Fidge |
 Fidge Banned
 Posted: 15:00 - 03 Jun 2015 Post subject: |
when you take the washer of the exhaust you could shine a torch into the exhaust port and see if you can see the blades.
| Kickstart |
 Kickstart The Oracle
 Posted: 15:10 - 03 Jun 2015 Post subject: |
Under the tank on the inside of the r/h frame rail there is the solenoid for the valve. Has 2 wires going to it and a cable from it to the housing above the exhaust.
There should be a control unit hidden under the pillion seat. It will probably have the number 7800 on it in white paint (the rpm it opens at).
The housing above the exhaust / under the battery should cover the end of the actual power valve blade.
On a restricted bike the housing above the exhaust will just be a flat plate with 3 bolts through it (2 to hold it on, one to hold the valve blank). In this case the valve is replaced with a blanking piece which is a bit longer.
Note that the valves stick easily if used at low speed a lot. It is probably well worth taking the blade out and giving it a thorough clean. Also check that it is in the right way up (the end that goes into the engine is cut at about 45 degrees, this should be horizontal NOT vertical).
K ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
| Minty |
 Minty World Chat Champion
The last post was made 11 years, 97 days ago. Instead of replying here, would creating a new thread be more useful? |
