Bandit 12 won't run on choke.
TheGazWaz
PostPosted: 14:13 - 03 Jun 2015    Post subject: Bandit 12 won't run on choke. Reply with quote
Afternoon all,
I’ve now got my Bandit 1200 and I absolutely love it. I have one small issue that’s not too bad at the moment but when the cold weather kicks in it’s going to give me hassle.
The bike refuses to start with the choke on in any position. Before I got the bike it had been standing for a couple of months. Once it’s warmed up it runs perfectly but even after warming up applying any choke bogs it down.
Any Ideas? It’s a 53 with 21k on the clock. The only mod on the bike is an aftermarket can. Not sure what it is but it sounds beautiful.
Cheers all
Gaz
RhynoCZ
PostPosted: 15:27 - 03 Jun 2015    Post subject: Reply with quote
I would suggest to check the choke cable and cable adjustment. Then, if that's alright, I'd actually take the carbs out and check them. Thumbs Up
Are you sure the choke is not stuck? I'd check one spark plug, just to make sure it's not running too rich all the time.
nisp
PostPosted: 15:46 - 03 Jun 2015    Post subject: Reply with quote
"Once it’s warmed up it runs perfectly. But even after warming up applying any choke bogs it down."
why would you use the choke on a warmed engine?
Suzuki TS 50 1999 Honda CB 125 t2 1981 Yamaha XJ 600 s Diversion Honda cx 500 MZ ETZ 250 1985 Yamaha FZR 400 1981 Suzuki TS 185 1984 Triumph bonneville 790 2001 MZ TS250 1979 Suzuki sv 650 1999 KTM exc RFS 450 2007 Hercules mx 125 1976
TheGazWaz
PostPosted: 17:10 - 03 Jun 2015    Post subject: Reply with quote
Generally wouldn’t. It’s called process of elimination. When an engine is warm, putting the choke on should, in turn, increase the revs. On my bike it doesn’t, it bogs down.
RhynoCZ
PostPosted: 17:13 - 03 Jun 2015    Post subject: Reply with quote
That is what it should do. My ZXR also dies, when it's warmed up and I apply the choke. The CB-1 and GPz I had were the same. My mate's 919RR and FMX also die.
The choke basically reduces the amount of air coming through the carburetors, making the mixture rich. It's got nothing to do with the idle.
Acerman This post is not being displayed because the poster is banned. Unhide this post / all posts.
Old Git Racing
PostPosted: 17:28 - 03 Jun 2015    Post subject: Reply with quote
It's doing what it should do. I think you might be looking for a problem that doesn't exist. Just ride it if it's ok as normal and if there is a problem when cold weather comes sort it then. I reckon it will be ok.
OGR
weasley
PostPosted: 18:33 - 03 Jun 2015    Post subject: Reply with quote
Not really. The 'choke' does just that, it blocks air into the engine. Many carbs also have a mechanism that raises the idle speed too, to compensate, but with a warm engine all you are doing is blocking air and over-fuelling the engine, hence it'll bog.
If it starts fine and runs fine, it's fine.
TheGazWaz
PostPosted: 20:37 - 03 Jun 2015    Post subject: Reply with quote
Thanks for all your replies. I stand corrected on the Choke facts. I love this place. Font of all knowledge.
When I start it from cold it takes a few starts and I have to hold the throttle open a tad to keep it at around 2k until it's warm enough to support itself. It's only a matter of a couple of minutes but surly this is the job of the choke.
I need to check but I have to assume the choke is activating because there is a response from the engine when doing so. Negative response though that is it's still doing something.
I so love this bike though. Coming from an RF600 to this is heaven. Not knocking my RF but everything about the Bandit 1200 is better imo.
Cheers again
Gaz
talkToTheHat
PostPosted: 11:59 - 04 Jun 2015    Post subject: Reply with quote
does the choke actually choke, or is it an enrichener or fast idle?
My 535 has an enrichener, mislabeld as choke, applying it when everything properly warm causes engine to stall.
Bandit. does. everything.
TheGazWaz
PostPosted: 13:27 - 04 Jun 2015    Post subject: Reply with quote
Maybe... I've got a heynes manual coming at the weekend so I'll have a gander then.
When I activate the choke I can see a pin moving out of the side of the carb and it goes back in when I push the choke back.
MCN. This post is not being displayed because the poster is banned. Unhide this post / all posts.
nisp
PostPosted: 18:32 - 04 Jun 2015    Post subject: Reply with quote
sounds like the choke is doing its job, it's probably a worn fast idle control cam on the carb bank (so you actually hold the throttle open a bit instead of the choke).
look at hynes, adjust, should be golden Thumbs Up
PostPosted: 19:19 - 04 Jun 2015    Post subject: Reply with quote
Has the bike been set up for the pipe change? Is the air filter clean / standard?
While when warm I would expect the choke to stall the engine (on my Bandit 12 when standard, leaving the choke on from cold would have the bike stall at the first real junction from home - about 200~300 yards away)
K
talkToTheHat
PostPosted: 23:08 - 04 Jun 2015    Post subject: Reply with quote
So an enrichener design then...
As such it is usually a sign the engine is warm if it stalls on choke and this is often the usual test to see if the choke works.
TheGazWaz
PostPosted: 11:28 - 05 Jun 2015    Post subject: Reply with quote
All starting to make sense. If I start it from cold with no choke it will fire up but I have to give it a little throttle and hold it for 30 seconds or so.
I just remember on my RF600 it like to start from choke no mater what the weather was doing. Diferent/older tech I suppose.
Can I assume then that when the weather does get cold the choke will work/be need to start the bike?
Gary
talkToTheHat
PostPosted: 15:26 - 07 Jun 2015    Post subject: Reply with quote
You'll probably need choke when its proper cold. I've never needed it in summer, but in the depths of winter some of mine have needed a good few minutes of warming up on gradually decreasing choke and the tiniest bit of throttle before they would run smoothly.
The last post was made 11 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 96.22 Kb
