lexmoto XTR S Starter motor
jubbil
PostPosted: 16:16 - 03 Jun 2015    Post subject: lexmoto XTR S Starter motor Reply with quote
So this is my first bike and all was great loved riding. but one day i accidentally dropped it on its side and ever since i cant electronically start it but i can kick start it, also when the bike does start and i hit the electric starter it makes the noise of trying to start the bike
what would cause this to happen? i've trying removing the battery and charging it then putting it back but no luck.
PostPosted: 17:14 - 03 Jun 2015    Post subject: Re: lexmoto XTR S Starter motor Reply with quote
"Whirr whirr" or "click click"?
If "click click" then follow the thick red lead from your battery 12V terminal until you find something like this:
https://my.prostreetonline.com/wp-content/uploads/2014/10/starter_solenoid.jpg
Take a screwdriver (with an non conductive handle!) and put it across the two "main voltage terminals". Be aware that it will spark and may even spot-weld itself on, be prepared to wrench it off. That will put voltage directly to your starter.
If the starter spins (and the bike starts) like that then replace that solenoid. Costs a few £££. If that doesn't work, or if the starter is already spinning when you hit the button then let us know and in the meantime buy yourself a cheap multimeter - it will take a lot of the guesswork out.
The last post was made 11 years, 98 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 32.24 Kb
