Crash Damage/Engine.
Commuter_Tim
PostPosted: 14:33 - 04 Jun 2015    Post subject: Crash Damage/Engine. Reply with quote
I need help assessing crash damage the previous owner left my CB500 with.
My main concern is there appears to be instant gasket sealant around the head of the engine.
https://cdn.bikechatforums.com/files/_mg_0303_copy.jpg
Is this at all normal to use gasket seal for this? (my CG just had a rubber O-ring style seal)
I have scouted through Haynes and can't see a mention of any form of seal when replacing the head cover, it's all rather vague.
Is the gasket seal going to cause a headache at all?
I have been riding it since november and no oil leaks or performance issues as of yet.
https://cdn.bikechatforums.com/files/_mg_0309_copy.jpg
https://cdn.bikechatforums.com/files/_mg_0312_copy.jpg
With the damage that there is, is there anything else I should be looking at?
Stuff I've checked:
Wheel bearings
Weld points on the front end frame are uncracked. (ones that were visible when taking the front fairings off anyway)
Had forks seals redone and had to replace a stanchion due to pitting also.
Cosmetics do not concern me, only safety and reliability for getting to work.
So is it time to stop spending any money at all keeping it running smoothly and run the old gal until she dies? or not a huge concern?
I ride a Bandit 600... badly.
Acerman This post is not being displayed because the poster is banned. Unhide this post / all posts.
WD Forte
PostPosted: 16:38 - 04 Jun 2015    Post subject: Reply with quote
Seriously?
If its an old cheap bike that's not dropping oil and running well, ignore it.
If its reliable and not left you by the side of the road carry on
and just do the usual servicing.
bikers smell of wee
lihp
PostPosted: 16:53 - 04 Jun 2015    Post subject: Reply with quote
Acerman wrote:
No if there is rubber gasket dont apply any sealent, some engines like the Yama XT use the gasket on tube like RTV. Thats because they have camshaft between the headcover and head, if the distance is alter with gasket it would make wrong distance for the camshaft and lifters.
Sometimes, small amounts of grease or sealants are applied to the rubber gaskets to help hold them in place while refitting the valve cover.
Commuter_Tim
PostPosted: 19:43 - 04 Jun 2015    Post subject: Reply with quote
WD Forte wrote:
Seriously?
Thanks, I can be somewhat neurotic when it comes to my work runner but so much is smashed on this bike I keep expecting the worst.
I mainly ask as part of the usual service routine will require taking that cover off shortly. (Valves) Smile
Commuter_Tim
PostPosted: 00:18 - 05 Jun 2015    Post subject: Re: Crash Damage/Engine. Reply with quote
Vincent wrote:
Is the crash bar bent in or something?
The crash bars are scraped/rusted on both sides, but not bent as far as I can see, looks kind curved in that photo but IRL it sticks out further than any engine bits do.
Vincent wrote:
BTW, if you can get the old one out and havn't replaced it yet, I should have one of those bar ends you can have for post.
I will try to remove the bar end (it spins in place atm so I imagine it is damaged internally) and may well take you up on the offer thanks Smile
PostPosted: 06:06 - 05 Jun 2015    Post subject: Reply with quote
Gaskets very often have sealant at the cam cut-out. Nothing unusual there.
The last post was made 11 years, 103 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 67.92 Kb
