Lexmoto xtrs clutch lever assembly
russellransom...
PostPosted: 18:19 - 06 Jun 2015    Post subject: Lexmoto xtrs clutch lever assembly Reply with quote
Hi everyone, I have today broken the clutch lever assembly on my lexmoto xtrs 125, upon removing it I found as well as the clutch cable there is a micro switch and a wire with a plug in connector that disapears down into the bikes frame, I very carefully removed the assembly from the bars and followed the wire which pulled out very easily and didn't appear to be connected to anything. Is this correct or when refitting a new one do I need to find a connector to plug this back into?
Thanks in advance
Russ
PostPosted: 19:01 - 06 Jun 2015    Post subject: Reply with quote
If the bike starts then you don't need it. Worst case, you won't be able to start it with it in gear or with the sidestand down.
The last post was made 11 years, 124 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 31.29 Kb
