Puncture Repair Kit - Permanent/semi permanent use?
johnsmith222
PostPosted: 15:40 - 07 Jun 2015    Post subject: Puncture Repair Kit - Permanent/semi permanent use? Reply with quote
Hi guys,
I currently fit and balance my own bike tyres, and have moved on to changing car tyres too. I currently have a slow puncture in one of my clio tyres and I was thinking that it might be worthwhile to get myself a puncture repair kit to sort these issues.
I am currently looking at the stop & go puncture repair kit, which comes with a 'gun' type tool for pushing the mushroom in from the outside of the tyre. I know that strictly speaking, this shouldn't be a permanent repair, but I'm generally looking to use the kit on car tyres that are generally part-worn anyway, and would be looking to use the repair for the rest of the life of a tyre.
Does anyone have experience with this kit for the life of their tyre?
https://i.ebayimg.com/00/s/MTAwMFg2ODI=/z/U8oAAOSwrklVWzJD/$_57.JPG
I know that I could get the proper mushroom kit, and repair from the inside, but I'd probably rather avoid the extra hassle.
Let me know what you think of this kit, or if you suggest an alternative.
Thanks guys. Thumbs Up
PostPosted: 16:48 - 07 Jun 2015    Post subject: Reply with quote
Oooh, fancy, a squeezy gun and everything. I have to make do with an allan key on mine.
I haven't run one down to the life of the tyre but I've had them in 1 car and 1 bike tyre for several thousand miles with no drama. I slap some rubber cement on the plug before inserting.
kramdra
PostPosted: 17:51 - 07 Jun 2015    Post subject: Reply with quote
The head would be too small on that for me to trust it. Especially if its going to get abuse. For temporary repairs I prefer strings.
Cars are a bit more effort with jacking up, but Id just do it properly.
-Matt-
PostPosted: 18:14 - 07 Jun 2015    Post subject: Reply with quote
I have a stop and go kit, although it didn't come with the gun-thing, the rest looks the same though.
Very easy to use and have ridden on a tyre repaired with it for a few days without any problems. Not too sure about how it holds up in the long term as I had to get it replaced not long after anyway.
Would definitely recommend it as something to carry around on the bike etc. Mine also came with little gas canisters so you can re-inflate the tyre a bit at the roadside, which may come in handy one day.
johnsmith222
PostPosted: 18:39 - 07 Jun 2015    Post subject: Reply with quote
Thanks guys, this has been very helpful. I'm planning on using the plug kit more than likely exclusively on the car whenever I get a puncture. My car has a full size spare wheel, so if a mushroom was to fail then it wouldn't be a huge issue as I have a proper back up. (I'd stick the repaired tyre on the back of the car anyway, and I tend to just bimble about in the car.
As suggested, it would definitely be useful to carry it on the bike also as a get me home type repair.
Rodger, as you suggested, I think I'll add some cement to the repair also if I'm going to be using the tyre until the end of its life.
Thanks guys. I'll give the set a go and see how I get on. Thumbs Up Karma
b422063
PostPosted: 19:42 - 07 Jun 2015    Post subject: Reply with quote
bluezedd wrote:
Rodger
Laughing No idea why I splurted my coffee out over that. Laughing
'Professional' plugs I've never had fail, but I did get a slow puncture with a home attempt which is why I just replace the tyres asap now. As a get you home fix I use them, but otherwise I just swap the tyre out.
bamt
PostPosted: 19:54 - 07 Jun 2015    Post subject: Reply with quote
On my last rear tyre I fixed a puncture with that kit. I got about 8,000 miles out of it afterwards, including some fairly spirited riding, long motorway runs and 2-up. It was replaced because the tyre was worn out, not because the repair didn't hold up.
PostPosted: 20:37 - 07 Jun 2015    Post subject: Reply with quote
I guess the question would be: has anyone ever had one fail?
I've had strings fail, twice, on a puncture that a mushroom then sealed.
b422063
PostPosted: 20:59 - 07 Jun 2015    Post subject: Reply with quote
Define fail? Catastrophic failure caused by the inherent design of the device being used as directed, or a slow leak by a novice user who had a stab at it to get him home?
PostPosted: 21:17 - 07 Jun 2015    Post subject: Reply with quote
Have you experienced either?
b422063
PostPosted: 21:18 - 07 Jun 2015    Post subject: Reply with quote
The latter, as I stated earlier. 40psi -> 20psi overnight. I'm fairly sure it was to do with my technique rather than device itself, but either way I thought it was best not to have any more stabs at it. Given the very ad hoc nature of punctures, practice isn't easy to come by.
PostPosted: 21:43 - 07 Jun 2015    Post subject: Reply with quote
Ah, sorry, I hadn't registered that was with the stop-n-go plugs. Embarassed
Did you give it a good hard tug so that it grew by at least 2" in your hand, before lopping the tip off?
barrkel
PostPosted: 19:55 - 08 Jun 2015    Post subject: Reply with quote
I've plugged 4 tyres with strings, and not had a fast leak yet. I define a fast leak as a leak where I notice air loss within a week.
3 lasted without noticeable leaks at all for the life of the tyre. The most recent one appears to be leaking a small bit, losing about 0.5 bar in two months. I had run out of the miniscule tube of vulcanizing fluid, however, so this one went in dry.
PostPosted: 20:32 - 08 Jun 2015    Post subject: Reply with quote
That kit without that gun thing I have under my seat after watching a forum member (doovy) repair a nail puncture at the side of the road last year on the Mayday run. I then saw him ride the rest of the way to Hastings at "making progress" speed limit.
DMCpro
PostPosted: 15:00 - 09 Jun 2015    Post subject: Reply with quote
I use these at work nearly every day. I work on the roadside.
Very good kits if you know what your doing.
Honda CB-1, TS125X
VW Golf Estate
Doovy
PostPosted: 15:24 - 09 Jun 2015    Post subject: Reply with quote
I managed to get a puncture last week actually, tried using the Stop N Go but the angle of the screw in the tyre meant the mushroom head wouldn't sit flush to it... so I've had to use a sticky string repair this time.
Still, the Stop n Go is very quick and I do like it a lot.
WD Forte
PostPosted: 15:36 - 09 Jun 2015    Post subject: Reply with quote
I used a mushroon 'get you home' type plug on my beemer back tyre
Turns out I lived 8000 miles away but I had no ill effects thereafter.
bikers smell of wee
The last post was made 11 years, 32 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.81 - MySQL Queries: 13 - Page Size: 97.23 Kb
