| jacksonaron |
 jacksonaron L Plate Warrior
| Taught2BCauti... |
 Posted: 07:36 - 08 Jun 2015 Post subject: |
I think your bike has a contact-breaker type ignition, so check that the points are set to the correct gap, the condenser is good, and that the timing is correct.
If the points look pitted and worn, fit a new set and a new condenser. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 07:45 - 08 Jun 2015 Post subject: |
Toss the ignition into the bin and buy yourself a 12v contactless ignition from VAPE.
There are also other manufacturers of the contactless ignition system, but VAPE is the only one I can think of right now. You could also fit ignition from a Babetta moped, that you'll get battery less ignition system.
VAPE: https://www.jawamarkt.cz/en/electric-2/electr-ignition-set-12volt-top-price-
By the way, that site is one of the few sites, where you can buy every single part, made in CZE, for your Jawa or CZ, prices are very low, the quality is very high actually. Everytime I check these sites I wonder why am I even riding a Japanese bike, where the chain, for example, costs 5 times more and a lot of parts you can't even buy brand new for a Japanese bike.
Thanks mate, I'm back in the, let's buy a CZ mood.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
 Posted: 09:17 - 08 Jun 2015 Post subject: |
Check the terminals on the coil are making good contact.
Check the plug cap is making good contact.
Be aware of the difference between "a spark" and "a good spark". The latter is fat, yellow/blue in colour and arcs between the centre of the plug electrode and the tang, not off to one side.
First thing to do is changes the plug.
Second thing to do is put the carb screws back to the factory settings.
Third thing to do (if it still wont start) is to clean out the carb and check fuel is running from the fuel tap.
If it has been sat unused for a long time, there will likely be quite a lot of "varnish" inside the carb. If it has been sat for a very long time, there is also a good chance the crank seals are shot. You would tend to find it'll start eventually on a bump start if this is the case. Try putting your hand over the end of the carb to check for a vacuum through it when the bike is kicked over, it should suck your hand against the end of the carb. Classic symptom of shot crank seals is good compression but no vacuum through the carb. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jacksonaron |
| jacksonaron |
 Posted: 15:46 - 12 Jun 2015 Post subject: |
Hi,
So today I tried starting the cz again with no luck. Although when putting starting fluid in the carb at the air intake it did rumble and sounded like it was OK, but then I guess the fluid ran out and it stopped. It's not doing anything with gasoline. I don't think it there's no vacuum, because the spark plug gets 'wet' after a couple of kicks.
I also noticed it is spitting gas when kicked out of that little hole I on the carb intake side.(right hand side hole on the pic in the link)
https://thumbs.ebaystatic.com/d/l225/m/mHqzx-Wl_FGbebnWQpgo97w.jpg
Any further help would be appreciated. |
| pepperami |
 pepperami Super Spammer
| jacksonaron |
| pepperami |
| jacksonaron |
| RhynoCZ |
 Posted: 11:10 - 30 Jun 2015 Post subject: |
Maybe the plug was wrong. A feeler gauge should tell you if it was it.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
 Posted: 11:16 - 30 Jun 2015 Post subject: |
Duff plugs are pretty common. A new plug not working is not that unusual which is why it's important to actually look at the spark and see if it's a good-un if you're having problems. "It's a new plug" doesn't mean it's a working one.
I like to keep the old, known-to-work plug(s) I changed at a routine service kicking about somewhere for fault finding purposes.
I've heard of some batches of new plugs rocking worse than 20% defective. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 11 years, 139 days ago. Instead of replying here, would creating a new thread be more useful? |
