| CVSensei |
 CVSensei Scooby Slapper
| Polarbear |
 Polarbear Super Spammer
| Rogerborg |
 Rogerborg nimbA
 Posted: 08:07 - 09 Jun 2015 Post subject: |
I've been wondering this and am interested in a non-Teffers EXPLANATIONE of exactly what's going on.
Enfield, free flow exhaust, no cat, Amal carb, the fuelling seems about right at idle and WOT. No leaks that I can determine.
If I rev it hard (relatively speaking) and then shut the throttle off, after a few seconds I get a few hefty pops and bangs, especially if I down shift.
Science says? ____________________ Biking is 1/20th as dangerous as horse riding.
| CVSensei |
 Posted: 08:28 - 09 Jun 2015 Post subject: |
Often a sign of running lean. Especially what happens on the overrun when the throttle is closed.
Insufficient fuel charge to ignite properly so it doesn't explode during the power stroke. The fuel:air mix is expelled into the exhaust. Next lean fuel charge comes along, same thing. Perhaps a third.
Eventually one of them ignites and the slightly burning gas exiting into the exhaust ignites the two or three fuel charges that are now filling the exhaust.
Some dirt bikes which are commonly ridden downhill on a closed throttle for protracted poeriods have a "coaster enricher valve" fitted in the carb that is sucked open by the excess vacuum against the closed throttle and allows extra fuel to enter the engine.
With an exhaust air leak, I think it's a bit of the above, less back pressure will tend to exacerbate the whole 8-stroking effect, so people who fit a loud pipe and don't alter the jetting get a drop in power and lots of popping on the overrun. Also a bit of stoichiometry in that any small quantities of unburned fuel will reach explosive air ratios at normal air pressure further up the exhaust system where it is hotter and more likely to ignite them
Of course, on an Enfield, it could also be that your exhaust valve seat has fallen out of the cylinder head and is now flapping up and down on the end of the valve. That causes a lot of popping on a closed throttle due to fuel air escaping into the exhaust on the compression stroke.
https://i48.photobucket.com/albums/f216/stinkwheel/enfield%20head%20231010/dscn1428.jpg ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Rogerborg |
 Rogerborg nimbA
| c_dug |
 c_dug Super Spammer
| CVSensei |
 Posted: 09:01 - 09 Jun 2015 Post subject: |
Cheers, all of that makes lots of sense.
To conclude, braaaaaaaaaaaaap pap papa pop is fine and dandy?  ____________________ 2014 Yamaha MT-07 ABS Deep Armour
'If all else fails, read the instructions.' - Grandpa
'Two possibilities exist: either we are alone in the Universe or we are not. Both are equally terrifying.' - Arthur C. Clarke |
| Seb |
 Seb World Chat Champion
 Posted: 09:22 - 09 Jun 2015 Post subject: |
Probably my favourite thing about my triumph and it's underseat exhaust  ____________________ 2010 Triumph 1050 Sprint ST |
| CVSensei |
| Lord Percy |
 Lord Percy World Chat Champion
| deadwolf |
 deadwolf Could Be A Chat Bot
 Posted: 10:03 - 09 Jun 2015 Post subject: |
One part of my daily commute is a short, narrow and twisty road looping through a small valley. Its usually filled with slow-moving cars on the ride home which gives plenty of opportunities to kick down a gear and let the engine braking and some mild throttle get the revs up for a nice warm aural sensation before releasing the throttle for some delicious exhaust burbles. There's one long downhill stretch on the final approach that is particularly good for this. Definitely one of the highlights of my commute  ____________________ Motorsapien Art |
| temeluchus |
| Taught2BCauti... |
 Posted: 10:31 - 09 Jun 2015 Post subject: |
A Missfire is when the compressed fuel/air charge inside the cylinder doesn't ignite for some reason (usually loss of spark), and passes into the exhaust system unburnt.
Pre-Ignition happens when the fuel/air charge inside the cylinder is ignited by something other than the spark plug at the correct time (usually a glowing ember of carbon, or the heat of compression) also known as 'Pinking', 'Dieseling' or 'Knocking'.
A Backfire is when a fuel/air charge is ignited outside the cylinder, which can be on the inlet side (usually caused by a leaking inlet valve or incorrect valve timing) or on the exhaust side (usually caused by a glowing ember of carbon, or the glowing filament in an O2 sensor).
Negative pressure waves inside the exhaust pipes can sometimes cause oxygen to be drawn back into the system from outside, causing a small amount of super-heated unburnt fuel to spontaineously ignite.
Unburnt fuel particles normally pass through the entire exhaust system without igniting, because they are surrounded by carbon monoxide, carbon dioxide and other gasses that do not support combustion, but a small amount of oxygen introduced through a leak in the system, or by being drawn back into the system by negative pressure, is enough to cause the unburnt fuel particles to ignite.
If the unburnt fuel reaches the outside air, the ratio between oxygen and fuel, and the lower pressure, is not enough to cause ignition. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 13:24 - 09 Jun 2015 Post subject: |
my fazer pops a lot when i downshift off the throttle, sounds badass! ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
| Acemastr |
 Acemastr World Chat Champion
 Posted: 14:06 - 09 Jun 2015 Post subject: |
Happens on new bikes because there are valves in the airbox that open to let fresh air into the exhaust to burn off unburnt fuel when you let the throttle off for emissions.
Mine does it... sounds awesome  ____________________ 2017 KTM 350 XC-F - 2014 Yamaha R6 - 2005 Yamaha YZ125
2016 Toyota Tacoma Limited |
| Vincent |
 Vincent Banned
| Taught2BCauti... |
| Hefty |
 Hefty Could Be A Chat Bot
| stevo as b4 |
| Vincent |
 Vincent Banned
 Posted: 19:09 - 09 Jun 2015 Post subject: |
| Vincent |
 Vincent Banned
| Polarbear |
| Vincent |
 Vincent Banned
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:37 - 10 Jun 2015 Post subject: |
So what's the terse term for "partially combusted fuel detonating in the exhaust"? ____________________ Biking is 1/20th as dangerous as horse riding.
The last post was made 11 years, 34 days ago. Instead of replying here, would creating a new thread be more useful? |
