MPG Figures...How to read it correctly
Ame
PostPosted: 19:09 - 16 Jun 2015    Post subject: MPG Figures...How to read it correctly Reply with quote
Could someone help explain what the number 31326.5 [MPG] reads/means,please
sorry for being a bit dim,but is it 6.5/ [26.5 I would think!] so what are all the numbers [313] at the beginning ??
Thanks!
PostPosted: 19:14 - 16 Jun 2015    Post subject: Reply with quote
Where are you getting the figure from?
b422063
PostPosted: 19:15 - 16 Jun 2015    Post subject: Reply with quote
How many miles did you do on how much petrol?
Ame
PostPosted: 19:29 - 16 Jun 2015    Post subject: Reply with quote
I know what the [MPG] means its the actual number displayed that I dont get
it's off a fuel efficiency app:
miles 79.088 1048.7 MPG [DOWN]
miles 78,479 1201.9 MPG [UP]
what's going on here?
wr6133
PostPosted: 19:56 - 16 Jun 2015    Post subject: Reply with quote
You didn't tell the app every time you filled up? That is a lot of miles for a tank
Ame
PostPosted: 20:14 - 16 Jun 2015    Post subject: Reply with quote
if only Very Happy !!
it says enter the total miles on the odometer NOT the distance since last fill...
my average MPG is 31326.5 ??!!
I think i need to contact the support,so all I can think is I'm interpreting the figure wrongly!
PostPosted: 20:15 - 16 Jun 2015    Post subject: Reply with quote
https://cdn.meme.am/instances/500x/54564901.jpg
iooi
PostPosted: 20:41 - 16 Jun 2015    Post subject: Reply with quote
Shall we start again....
Just what APP are you using?
What figures have you entered....
Best and easiest way is to Zero trip when you fill up. Ride bike. Fill up and note Miles done & fuel put in so. Rinse & repeat..
So you do 150 miles & use 9 ltrs of fuel.
150/9.0 = 16.66 * 4.55 = 75.83 MPG
The other option is to use Fuelly. Which works a treat Thumbs Up
Aff
PostPosted: 20:47 - 16 Jun 2015    Post subject: Reply with quote
Apparently not if you enter your Odo reading in the "miles since last fuel up" box. Laughing
Electric Bike Project
Ame
PostPosted: 21:00 - 16 Jun 2015    Post subject: Reply with quote
[quote="iooi"][quote="Ame"]
The other option is to use Fuelly. Which works a treat Thumbs Up[/quote]
Its a blackberry app called 'Fuel Economy' [dekerta.com]
Yes I'd have thought to use back to Zero,but it does say you must put the Odo reading and NOT the mileage between fill up's tho?
I will check out 'Fuley',thanks.
wr6133
PostPosted: 21:14 - 16 Jun 2015    Post subject: Reply with quote
If you are entering the odometer reading between each fill then it should only be the distance between each fill difference...... you have a 609 mile difference between those 2 readings, so you have told the app you did 609 miles between fills, going by the MPG figure you also told it you have about a half gallon tank??????
Ame
PostPosted: 21:46 - 16 Jun 2015    Post subject: Reply with quote
[quote]
If you are entering the odometer reading between each fill then it should only be the distance between each fill difference...... you have a 609 mile difference between those 2 readings, so you have told the app you did 609 miles between fills, going by the MPG figure you also told it you have about a half gallon tank??????[/quote]
is it the odo I'm reading wrong,then?
wr6133
PostPosted: 21:57 - 16 Jun 2015    Post subject: Reply with quote
Is this a troll?
If not
You started at 78479 miles
You then added fuel at 79088 miles
(or at least the above is what you told the app)
That equals 609 miles covered
You put in 2.64L of petrol
2.64L equals 0.58 of a gallon
So 609 miles using .58 of a gallon equals 1048.68 MPG
Therefore you either pushed the bike most of that distance with the engine off or you are a potato at using a basic app/simple maths/being sentient.
PostPosted: 22:09 - 16 Jun 2015    Post subject: Reply with quote
Someone's including the 1/10th of a mile in the odometer reading, methinks...
Bike looks like an XR125, which should be getting around 100MPG (and is unlikely to have 79k on the clock)
Ame
PostPosted: 22:10 - 16 Jun 2015    Post subject: Reply with quote
[quote="wr6133"]Is this a troll?
If not
Therefore you either pushed the bike most of that distance with the engine off or you are a potato at using a basic app/simple maths/being sentient.[/quote]
no really I said I was dim at the start!
There's no way I've done 609 miles tho ?!?
Am I entering too many numbers from the Odo reading??
PostPosted: 22:16 - 16 Jun 2015    Post subject: Reply with quote
https://cdn.iwastesomuchtime.com/7142012231507Hklm7.gif
Ame
PostPosted: 22:53 - 16 Jun 2015    Post subject: Reply with quote
[quote="The Shaggy D.A."]Someone's including the 1/10th of a mile in the odometer reading, methinks...
Bike looks like an XR125, which should be getting around 100MPG (and is unlikely to have 79k on the clock)[/quote]
I've sussed it with you saying 79k!!!!
I't should be :
0[7908] and not including the 1/10th,of course....
really sorry about this post,I've no idea why the hell I was leaving out the all important ZERO at the start.....
Apologies all and thanks for your help...... Confused Laughing
monkeybiker
PostPosted: 23:13 - 16 Jun 2015    Post subject: Reply with quote
I fear I may well have become slightly more stupid due to reading this thread Sad
NJD
PostPosted: 00:04 - 17 Jun 2015    Post subject: Reply with quote
fuelly
Next time you top up your bike keep the receipt and run the bike until it needs to be refilled again, when it needs to be refilled again use the receipt to enter details as well as the figure on the trip-o-meter just before filling up the second time on that website, there you have your MPG.
So, you use details from receipt top up 1 and figure from the trip-o-meter just before top up 2 to enter details on website, then rinse and repeat..
Details from top up 2 receipt and figure from trip-o-meter just before top up 3 to enter on website..
etc, etc.
Ame
PostPosted: 00:27 - 17 Jun 2015    Post subject: Reply with quote
[quote="NJD"][url=https://www.fuelly.com/]fuelly[/url]
etc, etc.[/quote]
Thanks NJD.I will register on the Fuelly site and get myself sorted.
iooi
PostPosted: 05:11 - 17 Jun 2015    Post subject: Reply with quote
Awaits the next thread about Fuelly and US gallons compared to UK gallons against ltr.... Laughing
andyscooter
PostPosted: 07:43 - 17 Jun 2015    Post subject: Reply with quote
its a 125 using about three quids worth of fuel why does the mpg really matter
monkeybiker
PostPosted: 10:09 - 17 Jun 2015    Post subject: Reply with quote
On my bike I tend to just do a quick calculation in my head, no need to keep a record of it. Just work out miles per litre then multiply by 4.5.
PostPosted: 10:45 - 17 Jun 2015    Post subject: Reply with quote
OP went full retard.
NJD
PostPosted: 11:04 - 17 Jun 2015    Post subject: Reply with quote
please do change the deafult setting of the account to UK, as well as if your bike is in miles or km on the trip-o-meter.
The last post was made 11 years, 85 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 129.64 Kb
