Battery Help PLEASE!
Richyboom
PostPosted: 19:04 - 24 Jun 2015    Post subject: Battery Help PLEASE! Reply with quote
Hi, I am new to bikes but am loving it. Very Happy
Basically my bike keeps cutting out after a couple of miles (despite a full charge.)
It is a Honda XR 125L. I bought off of e-bay. The previous owner said the battery is new. I have changed the spark plug, cleaned at the air filter. Will next check the regulator / rectifier (if I can access it!)
WITH LIGHTS ON: Battery starts at 11.12 and then slowly drops down to 9.39.
WHEN NO POWER: Battery is anywhere between 12.3 - 12.5.
WITH ENGINE RUNNING: Battery is at 13.4.
REV SLIGHTLY: Battery goes up to 14.8.
Do I need a new battery do you lot think?
Please let me know whet you think. Thanks.
delsol
PostPosted: 19:11 - 24 Jun 2015    Post subject: Reply with quote
After it cuts out, does it start again off the battery ?
More clues needed.
Teflon-Mike
tl;dr
PostPosted: 19:17 - 24 Jun 2015    Post subject: Reply with quote
Battery sounds fairly normal...
As to the cutting out.. well, wont be related to the battery I'm afraid.
Bike uses a 'self exited ignition'... the spark-plug ciurcuit has its own winding in the generator to make the electric for sparks; only effect the battery has in spinning up the crank-shaft to make the electric the ignition circuit uses; (if it's electric start not kick) after that, engine's running independent of the battery, so if it conks out, its not to do with the battery.
hedgehugger
I bought a bike. Previous owner said "new battery".
Changed the reg/rec. and bought a new battery. Problem solved for the no charging thing for us.
As for the cutting out. Different bike but had the float stuck in the carb. Bike would cut out after a couple of miles. I regularly pushed it home again! until someone stopped and pointed out that the float might be a problem. It was Thumbs Up
The last post was made 11 years, 73 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 44.84 Kb
