ACF-50 or Scottoiler FS 365?
ACF-50
93%
 93%  [ 28 ]
Scottoiler FS 365
6%
 6%  [ 2 ]
Other
0%
 0%  [ 0 ]
Total Votes : 30
NJD
PostPosted: 00:10 - 25 Jun 2015    Post subject: ACF-50 or Scottoiler FS 365? Reply with quote
So, this post got me thinking about last winter and how I used my bike throughout the most part of it (when commuting was required and safe to do so) and didn't do any winter prep.. result was an electrical fault and a corroded clutch (post winter).
Now, we're a few months away, well the weathers not to bad where I am anyhow, but I'd rather prepare ahead of time than let my bike being to fall apart a little more before I do something about it.
I have a can of ACF-50 aerosol that sat unused through the whole of last winter and has done ever since, i'm not sure if it's ACF-50 in general that I dislike or the aerosol version (as I haven't had any other form it comes in) but wondered if scottoiler FS 365 was any easier to use and remove?
I'm aware that both are applied after washing the bike, I watched this video on how to apply scottoiler FS 365 and looks like it's a whole bunch easier to remove and far less hastle (just washes off, read that ACF-50 is a b***h to remove).
Again i'm not if it's because I have the aerosol verison of ACF-50 but there's a niggle inside of me that likes the idea of scottoiler FS 365 more.
So, ACF-50 or Scottoiler FS 365?
-Matt-
PostPosted: 00:24 - 25 Jun 2015    Post subject: Reply with quote
ACF 50 everytime for me (not that i bothered with it the last winter due to not riding much). Never found it that bad to get off after winter to be honest. Just used degreasers and brushes to scrub crud off Thumbs Up
NJD
PostPosted: 01:04 - 25 Jun 2015    Post subject: Reply with quote
From what I've read it comes across that ACF-50 is the main anti-corrosion spray and is applied twice a year, once before winter after a deep clean and then once after winter to do the same again.
Scottoiler FS 365 seems to be water based meaning it comes off a whole bunch easier and needs to be applied a lot more, as a result is cheaper and from what I've read can last 2-3 months a bottle at 3 washes a week (based on one report).
I don't mind the idea of a thick coating of over the bike (after all, anything beats having to push it home because of an electrical fault or nursing a knackered clutch because no protection was applied at all.. as I discovered) i'd just be a bit cautions of allowing dirt and grime to sit on the bike for a few months.
I own a chinese bike.. last winter I just ended up hand washing the down-pipes and bottom of the bike after every ride, apart from a bit of rust on the head of the down-pipes and some part of the downpipe it's in good condition, only one engine nut that looks like it needs a clean and only a couple of cheap materials elsewhere that took a little bit of a bashing.
I like the idea of applying one coat of ACF-50 and then washing the down-pipes and bottom of the bike after every ride and re-applying a coat of Scottoiler FS 365 just as an extra precaution.
Since I don't like the aerosol can that I have of ACF-50 would it be a good or bad idea to brake the top of the bottle and then just pour it into an empty spray bottle (the type that Scottoiler FS 365 comes in)?
Tempted to visit the local paper shop, find any form of bottled spray, tip it down the drain, wash the bottle out and use it for ACF-50.
Also, would you spray ACF-50 on the top of the battery terminals as they're electrical connections or would coating the fairing protecting it be enough?
and what about the ignition and front end of the bike, I'd assume you'd avoid spraying on the seat, footpegs and grips as well as brake/clutch lever, so generally away from that area of the bike?
-Matt-
PostPosted: 01:30 - 25 Jun 2015    Post subject: Reply with quote
Thats one of the things i've liked about using ACF-50 personally - assuming you apply enough of it in the right spots you dont need to worry about it 'sitting on the bike' as such, as its all clinging on top of the layer of ACF 50 which usually will remain for a few months, unlike FS365 and various other ones.
Ive left mine numerous winters with just a single layer of ACF-50 which has been plastered in grime and not washed it until spring. Its always looked as good as before i put the ACF 50 on after a thorough clean Thumbs Up
chickenstrip
PostPosted: 03:25 - 25 Jun 2015    Post subject: Reply with quote
I use ACF. I have heard of decanting into a spray bottle that atomises better (one guy I know of uses a perfume spray bottle), as the ACF aerosol isn't a great way to apply it, too much in too strong a jet. I just spray some onto a soft cloth and wipe everything over, then some into the cap and use a small paintbrush to apply to things like nuts, bolts, small brackets, awkward areas etc. Keep it away from brakes, tyres, and as you say, seat and footpeg rubbers. Fine for everything else.
How did not using an anti corrosion spray leave you with a knackered clutch? Eh?
Chinese bike you say? Can you keep it in an oxygen free environment? Laughing
Benjums
PostPosted: 07:45 - 25 Jun 2015    Post subject: Reply with quote
I have found applying acf 50 to be better if you use a rag and a bit sprayed into the lid for the easier areas, for the harder to reach bits shake the can really well then turn it upside down and apply. It tends to come out in a mist that way instead of a jet, so is easier to control. cover the bottom of your bike in it and leave well alone. Yea ok wash exhaust areas that get hot after every ride if you want as acf or anything will just burn off.
delsol
PostPosted: 08:21 - 25 Jun 2015    Post subject: Reply with quote
I have not used Scotoiler FS 365, I have used other products, and this is 3rd year using ACF 50
On the basis that ACF 50 works better than the stuff I have previously tried, it gets my vote.
DrSnoosnoo
PostPosted: 08:26 - 25 Jun 2015    Post subject: Reply with quote
When I started riding, I bought myself some ACF-50, and didn't use it much at the start of my career. I used it last winter and it's great. Yeah your bike looks dirty but because it ISN'T water based, it doesn't just wash away in driving rain.
I bought one spray can 3 and a half years ago and I reckon there's still a third left. After a good bit of driving rain, I just shoot a touch around the nuts and bolts and metal bits.
£13 or so over 3 and a half years isn't too bad?
wr6133
PostPosted: 08:37 - 25 Jun 2015    Post subject: Reply with quote
ACF50. It stays put so doesn't cost a fortune in reapplications. It's not hard to remove either unless your idea of cleaning the bike is spitting at it.
I don't buy the aerosol anymore. It's better value to buy the big bottle, which comes with a little spraybottle you fill up. I do 2 big cleans per year (start and end winter), the fairings, tank, etc come off and after cleaning the bike gets pretty much everything coated in ACF50. Fairing bolts, shifter linkage, etc may get occasional reapplications if the bike gets properly filthy and I clean the visible bits.
PostPosted: 08:43 - 25 Jun 2015    Post subject: Reply with quote
Aaah hahahahahahaahahah! Oh, you're an absolute card! Where do you get such fresh material?
https://3.bp.blogspot.com/-kuy3l8b8Lo8/T4BgMxdZlPI/AAAAAAAAAMo/qattQ4l9sFU/s1600/1.jpeg
3 year old Chinese bike, same manufacturer as OP's, ridden in all weather and through winters. [EDIT - with ACF-50 treatments!]
4 year old 'Japanese' bike:
https://i.ebayimg.com/00/s/NjAwWDgwMA==/z/eoUAAOSwjVVViB6-/$_86.JPG
More here:
https://www.bikechatforums.com/viewtopic.php?p=4143503#4143503
6 months:
https://www.bikechatforums.com/viewtopic.php?t=278136
From new:
https://www.bikechatforums.com/viewtopic.php?t=281543
ACF-50 FTW. Aerosols can GTFO, I bought a 950ml bottle for about £33 delivered and apply with a brush, it'll do multiple bikes for multiple years.
sidewinder
PostPosted: 08:46 - 25 Jun 2015    Post subject: Reply with quote
Acf50 used here to.3 yrs and bike still pretty much rust free.looks a mess in spring but all nice again when washed of. If it good enough the U.S. Navy's fighters ...
doggone
PostPosted: 09:14 - 25 Jun 2015    Post subject: Reply with quote
The squirting thing they supply with larger bottles of ACF isn't very good at fine sprays, I find it's better to use an empty kitchen cleaner spray bottle.
But if you take it back in the house don't get confused by what the label says.
chickenstrip
PostPosted: 09:27 - 25 Jun 2015    Post subject: Reply with quote
Rogerborg wrote:
In defence of Chinese bikes.
I knew you'd jump on that one!
I'm guessing the 4 year old "Japanese" bike example was probably built in China or another far eastern country.
Borg, if you think Chinese bikes are so good, why don't you put your money where your mouth is, sell the BM and the Enfield and buy a couple? Wink
PostPosted: 10:14 - 25 Jun 2015    Post subject: Reply with quote
Rusty POS is a made-in-India CBF.
I've already had a couple. Razz
Some of the 125s make sense. The bigger ones, less so. The WK 650s are far too expensive, coming in just a few hundred £££ under the price of an SV or SFV 650.
[UPDATE] Oh, my mistake, they're currently asking £200 more than a pre-reg £4K Suzuki. Rolling Eyes
If the "Mash" 400 was available in the local Dodgy Dan's, I might give it a look. Then I'd check out the lack of independent parts supply and come to my senses.
But that's an issue with pricing and support, not with the quality of the bikes compared to contemporary 'Japanese' equivalents.
Regardless of origin, I would (and do) ACF-50 any bike. It's cheaper than the parts its protecting.
chickenstrip
PostPosted: 11:02 - 25 Jun 2015    Post subject: Reply with quote
Had a couple doesn't count. If you were that impressed, you'd have one now.
As far as I'm aware (and no, I don't claim to know everything there is to know on the subject - doesn't mean I can't have my own thoughts about it), there really is no such thing as a completely designed-and-built-in-China bike. All the engines are copies of Japanese bikes (correct me if I'm wrong, I'd genuinely like to know). They'd be a lot further behind today if they hadn't done this.
I also think that it is wrong to defend them under a blanket term of "Chinese", as much as it may be wrong for me to slate them in this way. If everybody does that all the time and still buys them, they'll have no reason to keep improving. We have seen the decline in quality of Japanese-designed bikes since the Jap manufacturers farmed out production to China, India and so forth. Even BMW have not been immune to this. I'm not saying Chinese bikes should be totally ignored, but improvements will only come if customer driven. Yes, there are some signs of this happening, but no reason to stop helping to drive the trend. As to costs rising because of this, well, you can't have your cake and eat it.
The same goes with the Japanese firms, and others, now that many of their bikes are built elsewhere. If they're substandard, people should be vocal about it. The Japs themselves ( I need hardly remind you) started with poor quality productions. They got hammered for it, and then strove to improve.
Your first example of the Chinese bike ridden through 3 winters did not survive like that without a lot of care and attention I would guess. Was the same care given to the rusty bike you then featured?
Anyway, now I'm not gonna be satisfied until you take me up on my suggestion of switching to exclusively Chinese bikes yourself Smile
Oh, and sorry about the thread hijack OP, and no offence intended. Will you be sticking to Chinese after your current machine?
NJD
PostPosted: 11:18 - 25 Jun 2015    Post subject: Reply with quote
I assume road salt had worked it's way into the gap between the clutch cable that sits on top of the engine case and worked its way inside, after it was fixed was advised to use WD-40 of which helped for a while, a then on another trip the mechanic said once it's fixed it shouldn't need doing.. save the WD-40, and it's wor.. oh i'm not cursing it.
https://s2.postimg.org/vk2dib4eh/clutch_issue.jpg
(Bike looks near enough in same condition now, bar a layer of grime and dirt inbetween the engine and the clutch cable, can't get it removed because of how awkward it is to get to).
At least the hatred or lack of trust in the aerosol form isn't just me, might have to take another trip to poundland and get some more chinese piss water bike cleaner, clean the bike with that and then pour the ACF-50 into it.
In practice I'm sure leaving it protected rather than daily applications is the done thing as washing the down-pipes after every ride became tedious and wasn't fun on a cold dark night.
I think cleaning it off was the only other bug bear hence why FS 365 appealed more on the grounds it was easier to wash of, but it sounds like regular bike cleaner and some elbow grease should do the job post winter.
Financial costs was the reason I went chinese to start out with, working less than full time and attempting to keep a motor on the road pre 20's wasn't easy when crunching numbers at the time, I'd rather of kept myself afloat than put myself into debt attempting to purchase a CBF, YZF, YBR or similar (yes money was that tight at the time).
I might be forced (due to costs) to keep the 125 for another year regardless of if I gain my A2 license this year or not based on attempting to get the funds together for a bigger bike and then insure it, they only ever get more expensive and bigger.
I've had a couple of people ask if I'd be selling it at the end of the year so there's some interest, but I doubt they know much about bikes.
I did consider the Pulse Adrenaline 250 at one point but at 17bhp made no sense to spend £1,700 when a machine with x2 power could be had for similar price.
I'm not fussy, the GS 500 I used on the day of my training felt like a rocket and made me smile, apart from the gearbox, thing just didn't like neutral.
PostPosted: 11:59 - 25 Jun 2015    Post subject: Reply with quote
It counts to two.
Relatively impressed for the price of the bikes that I had. I don't want another 125 though (inB4 MSX) and the bigger bikes don't offer the same value for money.
To drag it back on topic, the point of that picture was to highlight the benefits of ACF-50. It got an aerosol spraying literally out of the crate in March 2009, then re-applications each autumn until it was swapped away near mint (slight surface patina on the brake rod) after its first MOT in 2012.
I have seen rusty examples of that specific bike, they're not magic. Rusted out, they go for ~£300 even as runners. I swapped mine for a freshly MOT'd 10 year old 4,500 mile GPZ500.
So about £20 - £25 of ACF-50 (£15 of it that the over-priced aerosol) retained much more than that in sale value, and certainly more than bolting on extras. ACF-50-4-eva.
chickenstrip
PostPosted: 12:04 - 25 Jun 2015    Post subject: Reply with quote
Yes, stay on topic Smile
OP, buy ACF. Use it. Good stuff Thumbs Up
Rogerborg, buy a Chinese bike, use ACF, do it!
NJD
PostPosted: 12:06 - 25 Jun 2015    Post subject: Reply with quote
Already have some in the aerosol form, just need to buy a spray bottle and pour it into that.
Shall do when the bad weather comes.
PostPosted: 12:18 - 25 Jun 2015    Post subject: Reply with quote
I did! Twice!
Chug! Chug! Chug!
Eh, I have an Indian made bike, it's much the same thing. Modern BMWs aren't exactly carved from marble either. ACF-50 remains on my must-have list.
evilzed
PostPosted: 01:50 - 27 Jun 2015    Post subject: Reply with quote
I've used ACF50 through winter on a couple of bikes, no rust. Applied with either brush/cloth/crappy spray bottle and later bikes using an air compressor which does a great job also take a look at this.
https://f2mcltd.blogspot.co.uk/2012/01/winter-salt-protection-acf50-fs365-or.html
Joncrete Cungle
PostPosted: 07:14 - 27 Jun 2015    Post subject: Reply with quote
ACF 50 is the tool.
Don't make me act that mother funking fool.
Ben90
PostPosted: 08:59 - 27 Jun 2015    Post subject: Reply with quote
/thread
Yamaha FZ6 S2
The last post was made 11 years, 77 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.91 - MySQL Queries: 15 - Page Size: 145.18 Kb
