CB250N Superdream brake calipers
alexanderfitu
PostPosted: 17:37 - 25 Jun 2015    Post subject: CB250N Superdream brake calipers Reply with quote
Hi all
Any ideas what caliper will fit in place on a 82 superdream. I have had a few of these now, and I hate the front brakes, got to be something that will fit that's a bit more modern.
The ones on there are broken, leaking and rubbish. I may as well buy something else that's better, from a breaker.
Any ideas?
pepperami
PostPosted: 19:06 - 25 Jun 2015    Post subject: Reply with quote
I have a Superdream of lovelyness Thumbs Up
I refurbished the existing caliper and master cylinder + put modern pads in it, and I can smoke the front tyre if I really want to.
The existing caliper is fine if it is set up right Thumbs Up
MCN. This post is not being displayed because the poster is banned. Unhide this post / all posts.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:29 - 25 Jun 2015    Post subject: Re: CB250N Superdream brake calipers Reply with quote
Rather than throwing glitter on a turd, why not buy a more modern bike instead?
Triumph Sprint ST 1050
alexanderfitu
PostPosted: 19:43 - 25 Jun 2015    Post subject: Reply with quote
That may be so, but mine has cracked on the casting and wont hold new seals, so it needs to be replaced. If I am paying £50+ pounds for a second hand caliper, it may as well be one that's better Smile
alexanderfitu
PostPosted: 19:44 - 25 Jun 2015    Post subject: Reply with quote
NKVD fan wrote:
Fireblade front end drops straight in.
he he he
alexanderfitu
PostPosted: 19:45 - 25 Jun 2015    Post subject: Re: CB250N Superdream brake calipers Reply with quote
I have a 13' NC700X, 91 K100 RS, 91 XJ600 and this. I have my reasons.
Primarily because I stuck a wacking 3 cylinder diesel in it. Another reason it would be nice to have better brakes.
pepperami
PostPosted: 19:51 - 25 Jun 2015    Post subject: Re: CB250N Superdream brake calipers Reply with quote
I am desperately hurt that you could say such a thing about the mighty Superdream of lovelyness.
Why not get rid of any/all old bikes that you disapprove of Folded arms
Or maybe? some old bikes might be a good alternative to 2,000mph and 10,000bhp.
I know my Superdream of lovelyness is not everyone's cup of tea, but on a B-road in the summer with no time deadlines or anything to prove, it can still provide me with a smile Thumbs Up
Oh, and she`s my MY TURD!
alexanderfitu
PostPosted: 20:09 - 25 Jun 2015    Post subject: Re: CB250N Superdream brake calipers Reply with quote
They have their plus sides, when there is a nice road, they do handle pretty well, in a simple honest sort of way.
(apart from the slowing down bit that is)
Shaft
PostPosted: 23:54 - 25 Jun 2015    Post subject: Reply with quote
Put a 400N front end on, then you can have brakes that are twice as wooden Thumbs Up Laughing
bikenut
PostPosted: 10:49 - 26 Jun 2015    Post subject: wet dream Reply with quote
now that I would like to see, post up a picture please.
also post a picture of your cracked caliper please. you know that they bolt together?
twin disc 400 is a much better brake ( solid caliper hydraulic unit part, slide caliper as 250 but done a different way, the bike is better as well from memory so needs better brakes )
riding a wet dream 250 sure improves your riding skills as everything is planned well in advance from memory.
as to locking the front wheel? and smoking tyres? on a wet dream?? 400 perhaps but 250, not on this planet mate! unless you have a servo fitted. Very Happy
ps you can never be in a hurry on a 250 wet dream, a 400 on the other hand!?
nuts about bikes
alexanderfitu
PostPosted: 18:12 - 03 Jul 2015    Post subject: Reply with quote
Pics as requested:
https://fotifixes.com/imagehosting/images/2015/07/03/image2.th.jpg https://fotifixes.com/imagehosting/images/2015/07/03/image3.th.jpg https://fotifixes.com/imagehosting/images/2015/07/03/image4.th.jpg
The caliper is cracked on the ring that supports the seals, not on the outer body. I don't have a picture of that.
To be honest, the brakes I have on it now aren't THAT bad, I have ridden superdreams with worse, I think its primarily the horrific feel at the lever.
Just to confirm, I have tried Ducati 600 calipers, looks like they would fit, all bolt holes line up, but the caliper is too wide on the inside and it fouls the wheel. Sad
Snod Blatter
PostPosted: 22:47 - 03 Jul 2015    Post subject: Reply with quote
That is really cool!
What is the spacing between the bolt holes then? 65mm?
1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL
bikenut
PostPosted: 10:57 - 04 Jul 2015    Post subject: diesel wet dream Reply with quote
some turd eh!! respect!!!!!
having trouble about where the crack is in the hydraulic part of the splittable caliper??
oe pads seem good but Armstrong pads are good.
have you considered braided brake hose?
machining etc is no problem for you so why not double up the larger 250 disc set up, or go for a 400 front brakes, twin smaller disc with different m/cyl but a good quite powerful brake.
is the master cylinder the problem, more displacement needed?
even a servo set up? within reason?
ask m and p for tour max disc info or visit tour max for disc info, offset and pcd etc, then research that route for caliper offset etc.
from memory you may be able to "invert" a 250 caliper and holder so it can fit on the other side, so a twin disc 250 dia disc front brake brake
what engine is it may I ask
nuts about bikes
alexanderfitu
PostPosted: 13:47 - 04 Jul 2015    Post subject: Reply with quote
Thank you indeed! Yes 65mm
The caliper I tried was a Ducati 600SS caliper, same spacing, and the offset from the disk looked right too, but the caliper was too thick and the inside of the caliper hit the wheel Sad
alexanderfitu
PostPosted: 13:52 - 04 Jul 2015    Post subject: Re: diesel wet dream Reply with quote
Thanks very much! I think Maybe the MC could do with being smaller, it gives a very hard lever and no feel, I wouldn't mind more travel and more feel.
It seems from some searching that the CB250 N shares its brake discs with the GL1000 1979 goldwing. (Front left at least).
Maybe I can find something that will fit on that.
Snod Blatter
PostPosted: 14:03 - 04 Jul 2015    Post subject: Reply with quote
My CB250 is also 65mm and it has a two pot sliding caliper which can haul the bike up quite well with Nissin pads in it, which have proven to be better than EBCs.
I have been through a similar search, the lovely four pot Brembos will never fit but the CB250 Two Fifty caliper (or its carrier and a similar Nissin caliper from whatever, mine's from an NC29) and the old CBX250RS/GB250 caliper will also fit. There are a lot of lovely-looking YZF-R125 Brembo calipers floating around but the bolt hole spacing for those is 63mm, not quite right.
The real problem with these newer calipers though is that they probably won't sweep the whole disc, so you'll just wear a bit of it out. Not sure what you could do about it..
alexanderfitu
PostPosted: 15:13 - 04 Jul 2015    Post subject: Reply with quote
Its funny you mention the YZF R125 brakes, as I have tried to fit these in the past with some success, they require grinding down the disc entrance, as the disc is thicker on the Honda, than on the Yamaha, Its trivial to make a bracket to make up the difference in bolt diameter.
Also, as you say, the pads only cover half the disc area, but in reality its not a huge issue.
I would prefer something that doesnt require such extensive modification.
What year is your CB250?
There are lots of CBR250 front brake calipers that look like they would fit too?
NC29 comes up as a CBR400RR?
Casper
PostPosted: 15:34 - 04 Jul 2015    Post subject: Reply with quote
https://www.ebay.co.uk/itm/HONDA-CB400n-SUPERDREAM-FRONT-NISSIN-BRAKE-CALIPER-VGC-Dream-1981-RARE-ITEMS-R-/331595695629?pt=LH_DefaultDomain_3&hash=item4d34a4c60d
What is the engine from. Kind of speed and MPG are you looking at. I am loving the whole idea of diesel bikes. The Dutch have some great results using Triumph tigers.
alexanderfitu
PostPosted: 15:44 - 04 Jul 2015    Post subject: Reply with quote
Meh, don't really want to put the same type single piston caliper on there if I can avoid it.
Its a Kubota D850 3 cylinder diesel, with a CVT box, around 22bhp peak power.
Its really good around town and will do 75 on the motorway without issues.
Currently getting around 85-90mph, but some tweaks need to be made which will increase that a fair bit I am hoping.
Snod Blatter
PostPosted: 15:59 - 04 Jul 2015    Post subject: Reply with quote
Mine is a 1994, but calipers are rare for them because the very outer lip that holds the dust seal in place can be broken quite easily, meaning the dust seal is pointless. When mine started leaking I replaced it with the CBR400RR item but kept the CB250 carrier as the NC29 carrier has differently spaced holes. The caliper itself is a generic Nissin item, also used on Mk1 Bandit 600Ns and a load of other stuff.
There are also the older style Nissin two pots that were on eighties CBR600s and other such things, but I don't know the bolt spacing of those. They may sweep more of the disc though?
I did look into the CBR250R calipers but couldn't find any that were near my budget, but back then they had only recently come out. The ABS version even has three pistons which you could all hook up to the front master cylinder for extra weird three pot stoppers. The Suzuki Burgman I think also uses those calipers. Again, I am not sure on the bolt spacing for these..
kramdra
PostPosted: 23:32 - 04 Jul 2015    Post subject: Reply with quote
Do not like them... to think the cbr250RR was only a couple years later Shocked
Very nice engine swap Thumbs Up
Many, many bikes use the Nissin two pot callipers. CBR600 F3's, CBR400's, CBR250RR's - all the same calliper.
If you want a newish right calliper, the new CBR250's are the same (and I have one on my RR, was a few on ebay from 0 mile bikes)
pepperami
PostPosted: 12:57 - 05 Jul 2015    Post subject: Reply with quote
Pics as requested:
Shocked Shocked Shocked Shocked Kin Ell!!!! impressive Thumbs Up
LongJohn22
PostPosted: 17:11 - 05 Jul 2015    Post subject: Reply with quote
Lovely conversion, total respect.
RhynoCZ
PostPosted: 11:23 - 06 Jul 2015    Post subject: Reply with quote
We have got to hear it! Could you make a video of it running, please? Smile
The last post was made 11 years, 97 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 135.97 Kb
