| kramdra |
 kramdra World Chat Champion
 Posted: 00:57 - 28 Jun 2015 Post subject: Master cylinder issue |
Strange issue with my chinese 125, master cylinder has always felt grabby, as if it had dirt inside. When I got it, the discs were also warped, relpaced them and the entire front brake system (pre assembled ).
I stripped master cylinder, found loose paint, dirt and rust. I had a spare chinese one, I believe it was the same issue.. but clean inside.
I have just replaced with a used Nissin master cylinder from a CBR6 F3. I stripped and cleaned, but it was in good usable condition..
Im getting the same issue, not nearly as bad. Could fluid contamination cause this? could it be somewhere else?
I reverse filled (and flushed lots of extra fluid) with syringe in callipers and sucked the old fluid out from reservoir. Perhaps I should have drained it first..
It is rideable, should pass MOT as is. I could strip and clean everything again, but would prefer to know the cause first. |
| CaNsA |
 CaNsA Super Spammer
 Posted: 09:43 - 28 Jun 2015 Post subject: |
I would expect the CBR master cylinder to have a FAR larger bore, and even if you get it to operate smoothly you will land up with having virtually no lever travel, lots of lever pressure and a very dead feel.
However the problem you are talking about I would normally expect from a master cylinder issue. I take it that it is a sliding caliper? If so check it slides smoothly on the pins.
K ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
| Rogerborg |
 Rogerborg nimbA
| kramdra |
 Posted: 10:52 - 28 Jun 2015 Post subject: |
| CaNsA wrote: | Put bike on side stand, full left lock, watch the bubbles float up from the m/c.
You may need to bleed the lines again, but make sure the bike is on the sidestand and the bars are on full left lock. |
I am a god at bleeding brakes, took under two minutes this time. There is no air in there, lever is solid.
Bike has 4 pots, with 1 inch diametrr pistons, and sliding callipers. Functionally identical to a cbr6f3.
The lines were replaced part of the assembled set, not long ago,
Callipers are also pretty much new, part of the assembled set, striped and cleaned, they slide freely.
I think I will drain it, flush the lines and strip the master again to be certain. Must be dirt or fluid contamination. |
| Snod Blatter |
 Snod Blatter Crazy Courier
The last post was made 11 years, 88 days ago. Instead of replying here, would creating a new thread be more useful? |
