| Pea |
 Pea Derestricted Danger
| lukehanham |
 lukehanham Two Stroke Sniffer
 Posted: 00:08 - 28 Jun 2015 Post subject: |
For the rear light:
The bulb on the back actually has 2 lights inside of it, one of them may be blown, replace the bulb as one of the elements in the bulb has gone. Thats for the back light at least.
There is a cable that goes from the front wheel up to the dashboard on the bike, check this is plugged in properly, if it is and the speedo does not work, the cable may need replacing.
As for the cable going from the throttle, it could be that someone has just stuck a throttle from a 4 stroke onto the bike as these use two cables where as most 2 strokes have one cable, it is nothing major to be worried about.
You can buy most spares for this bike in Europe from here;
https://www.adrenalin-pedstop.co.uk/cp-Furia_50-5189.aspx |
| Just_James |
 Just_James Could Be A Chat Bot
 Posted: 00:31 - 28 Jun 2015 Post subject: |
| lukehanham wrote: | As for the cable going from the throttle, it could be that someone has just stuck a throttle from a 4 stroke onto the bike as these use two cables where as most 2 strokes have one cable, it is nothing major to be worried about. |
Sorry, but NOT THIS
If you're unsure about this bike or how 2 strokes work, DO NOT run it for now!
That second cable is for the 2 stroke oil feed and if it's been disconnected the previous owner will (hopefully at least) have been running it on premix.
Basically, don't go running it on just petrol in the tank - it will die quickly!
Your other issues are insignificant for now. Running on premix is not an issue on its own either so long as you understand that you need to do it!
I'd expect the auto 2 stroke feed has been disconnected for some reason so you may want to investigate / repair that but for now just don't run it on petrol alone! ____________________ Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125 |
| Pea |
| Pea |
| Vincent |
 Vincent Banned
| Just_James |
 Posted: 06:23 - 29 Jun 2015 Post subject: |
https://www.amazon.co.uk/T-F-L-throttle-cable-coated-Motorhispania/dp/B00ANLEBO2
Fair play for having a go at fixing the cable but as said above, it needs to be accurate.
Another thing to consider is whether or not the previous owner knew the cable was snapped?
If so then hopefully he would have been running it on premix in which case you're best emptying the tank and starting with fresh fuel when you start using the oil feed again or you're going to have running issues.
Once you've fitted your new cable, undo that pozidrive screw (above your solder in the last pic) until oil comes through to make sure it's bled. ____________________ Current Bikes / Projects: 1999 Rieju RS1 50
| Pea |
| Just_James |
 Posted: 10:08 - 29 Jun 2015 Post subject: |
If it's been run without premix, yes there will be damage but to what extent is anyones guess depending on how long it's been run like that etc.
Main thing is that you've caught it before it's seized if nothing else. You could do a compression test once it's sorted but if it's running fine you might as well just keep running it really.
Yes, oil will come from that screw. Don't need the bike running but you might have to open the throttle a little.
If you want to check that it's set right, you need to clean the area up a bit and you will see a line that needs to line up with the one on the pulley.
Heres a pic of one of mine
https://i62.tinypic.com/10h0u1e.jpg
You shouldn't need to make any adjustment to it with your new cable on though unless its previously been messed with ____________________ Current Bikes / Projects: 1999 Rieju RS1 50
| Pea |
 Posted: 23:02 - 29 Jun 2015 Post subject: |
Really appreciate the help and the picture.
Yeh the engine sounded fine when it was running and I turned it off fine. It's not like it died or anything so hopefully not too much damage. The bike still seemed to pull well.
I've ordered a replacement cable so when that comes I'll get it fitted and make sure it lines up. Will also remember to prime the 2 stroke oil pump.
Once I've sorted that I'll then look into the original problem of speedo and lights
PS. I have noticed there is like an oil cap on the engine casing also ... Does the bike need engine oil aswell as the 2 stroke oil ? As far as I was aware the 2 stroke oil was all it needed. Or have I got that wrong ?
These little 2 strokes sure are fun !
Cheers. |
| Just_James |
 Posted: 23:42 - 29 Jun 2015 Post subject: |
The cap on the casing is for gearbox oil.
The 2 stroke oil lubricates the top part of the engine (piston and stuff), gearbox oil lubricates the bottom part (gears and cogs and stuff)
The 2 stroke oil gets mixed with fuel and burned off during the combustion process so will regularly need toping up and is a 'consumable' (why environmentalists no likey? ) but the gearbox oil just sits there in the bottom of the engine swilling around lubing stuff. It doesn't need regular refilling like the 2 stroke oil but it does deteriorate over time and gets contaminated etc.
With the bike being new to you, you're as well to drop the gearbox oil and replace it for peace of mind if nothing else, only costs a few quid.
AM6 workshop manual says to use SAE 75W-90 but that's probably thicker than necessary (especially if bike is deristricted), I generally put cheap 10W 40 in mine. ____________________ Current Bikes / Projects: 1999 Rieju RS1 50
| lukehanham |
| Pea |
| Vincent |
 Vincent Banned
| Pea |
 Posted: 09:40 - 10 Jul 2015 Post subject: |
Hi All,
New cable fitted and all is well
Also, lightts and speedo all back working.
Unscrewed the gear oil cap but no marks in regards to how much to put in ?
Thanks. |
| Just_James |
 Posted: 11:55 - 10 Jul 2015 Post subject: |
Glad you got it sorted
IIRC the AM6 takes 850cc of gearbox oil ____________________ Current Bikes / Projects: 1999 Rieju RS1 50
| Pea |
| JoshT |
 JoshT Derestricted Danger
 Posted: 21:50 - 31 Jul 2015 Post subject: New User |
Nice to see someone else posting recently about the MH Furia. I've just got my son a Peugeot XPS a Furia in different colours  |
The last post was made 11 years, 85 days ago. Instead of replying here, would creating a new thread be more useful? |
