R6 Dyno
stranger12
PostPosted: 05:27 - 21 Jun 2015    Post subject: R6 Dyno Reply with quote
Hi ,
I thought I share my dyno graph here
My bike is pretty much standard with k&n filter ( stoke not cone shape) and sp engineering straight can .
It produced 103 hp at best with baffle in and wopping 110 bhp without it Smile
The baffle is not going back Smile
What do you reckon the power at crank is , what is the loss from crank to wheel ?
apart from DIN which recognised the wheel rpm, what other methos are available ?
Many thanks
It is the 2005 r6 5sl
https://i61.tinypic.com/1xz87l.jpg
SV650 Red
R6 Red
serlant
PostPosted: 09:11 - 21 Jun 2015    Post subject: Reply with quote
Looks a bit lean?? Laughing
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
stranger12
PostPosted: 09:35 - 30 Jun 2015    Post subject: Reply with quote
someone had changed the picture, I swear it was the dyno chart not this pretty girl
here it is
The bike looks too lean from 0 to 8k rpm, is that dangerous ? can it cause engine damage ?
SV650 Red
R6 Red
PostPosted: 09:49 - 30 Jun 2015    Post subject: Reply with quote
Windows XP though.
Matt B
PostPosted: 10:38 - 30 Jun 2015    Post subject: Re: R6 Dyno Reply with quote
Guestimate drivetrain losses on a bike at about 15%. So for your 110hp run that would be roughly 126hp +/- a few. Sounds about right, I think they were quoted as having 124hp at the crank.
I would be more worried about upgrading my OS though...
stranger12
PostPosted: 10:48 - 30 Jun 2015    Post subject: Reply with quote
that is their os not mine Smile
It was doing 102 with baffle in . do you reckon my bike with standard exhuast will produce a higher bhp than a sport one with baffle in ?
this is because if the standard is same as with baffle then my bike theoritically only has 115 bhp rather than 124
SV650 Red
R6 Red
Matt B
PostPosted: 11:31 - 30 Jun 2015    Post subject: Reply with quote
Remember - dynos can be inaccurate (especially with outdated software Wink ) and runs can be influenced by ambient temperature for one. Different dyno on a different day could give you another set of numbers.
Claimed crank power for a certain bike can vary between what the manufacturer would have us believe and true power.
Engines lose power with age and mileage relative to how they have been treated and maintained.
Add all these things added together mean it's impossible to say 'what if this' and 'how about compared to'. Your bike, from this run, looks about right so forget the power runs and use the data to make sure it is fuelling correctly with the setup you want to run.
stevo as b4
PostPosted: 17:44 - 30 Jun 2015    Post subject: Reply with quote
I'd use about 15% for arguments sake on a chain driven bike with an in-line transverse engine layout, to add to the wheel power figure. The thing is as Matt said dyno's can vary hugely, so you cannot be certain unless you dyno'd using several different dyno's of the same brand and model to get a workable average.
I'm no expert, but I would expect that if you could map the fueling from tickover to max rpm under load and stay at around 13:1 you would make a gain in drivability and throttle response. Best power air/fuel ratio is always a little bit richer of stoichiometric, but not too rich so that throttle response is not woolly, and obviously at WOT and high rpm, you generally run a touch richer than theoretically ideal, to keep things cool enough not to melt.
The last post was made 11 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 56.59 Kb
