dt125r problems
dtmaster
PostPosted: 16:02 - 03 Feb 2005    Post subject: dt125r problems Reply with quote
Hi everyone,
Dont know if anyone can help but basicly i went away to college and left my bike lying in the shed for about a month. When i got back it was completely dead. I have taken the engine to bits cudent see anything wrong-plenty compression etc. put a new plug in and its spaking well, took the carb off cleaned it out. Reed block out nothing wrong there either. i dont know anything about electrics but i thought if there was spark it would at least fire?
has anyone got any ideas?
Regards Ross
1993 Yamaha DT125r
steve09
PostPosted: 16:34 - 03 Feb 2005    Post subject: Reply with quote
when ya say dead are you gettings lights ect??? if not try chargeing ur battery,
ermm not really very good with engines yet but could it be old petrol? i know its probaly not ,,
just check ya fuel lines and tap on the tank as i had a feild bike dt and it had a tendansoy for the tap to turn but the gubbings inside not to hehe,,
other than tht no idea and sorry if im pointing out the obvasis hehe just trying to help
cheers
steve
bish777
PostPosted: 17:03 - 03 Feb 2005    Post subject: Reply with quote
if the battery is totally dead the electronic ignition wont work!! charge your battery!!
simon1221
PostPosted: 18:03 - 03 Feb 2005    Post subject: Reply with quote
Try bump starting it Idea
I assume you have a haynes manual, check all the service items, i know there is one because I have the very same manual!
Ckeck the fluid level in the battery, check earth points.
Take the pipe off the fuel tap and see if petrol is coming out, (attach the pipe to a fuel can instead).
Dont open the throttle while trying to start it, as that will provide too much air and it wont start.
If all else fails put new petrol in.
Have you actually done a compression check?
The Dt125r shares most of its parts with the tzr, it just has a slightly different shape airbox...
dtmaster
PostPosted: 20:13 - 03 Feb 2005    Post subject: Reply with quote
thanks for the info, when i say dead its not completely you hear a slight fire every time you kick, the battery has actually always been flat on the bike but it used to start as long as it was connected.
Havent done a compression check but it actually started once after taking it all to bits then putting it back together so obviously i thought ad cracked it so i swithched it off then tried it again and no joy! Sad
1993 Yamaha DT125r
Scotsman37
PostPosted: 20:27 - 03 Feb 2005    Post subject: Reply with quote
Change your battery it's probably knackered now as it's not giving a good enough charge off the battery and if it's less than 10volts showing on a multiimeter when it should actually be about 12volts, but do also check it's fluid level is between the minimum & maximum marked on the side of it. If it is below 10volts, then do a recharge and check the readings again and if it still doesn't get above 10volts then it is knackered!!!
alains
PostPosted: 20:33 - 03 Feb 2005    Post subject: Reply with quote
you should have said if less than 12.8 volts
Scotsman37
PostPosted: 20:40 - 03 Feb 2005    Post subject: Reply with quote
It actually stated that in the Haynes manual about if the bike's battery is shown less than 10 volts then recharge. A good battery has about 12 volts coming off it.
alains
PostPosted: 21:04 - 03 Feb 2005    Post subject: Reply with quote
battery has 6 elements , each produce 2.2v end of charge , so 2.2x6=13.2 , down to 12.8 it's a sign of a tired bat
Scotsman37
PostPosted: 21:32 - 03 Feb 2005    Post subject: Reply with quote
Have you ever heard of margins of error because no measurement is exact, it's only approximate as no manufactured item can be exactly 100% reproduced as a perfect replica of the original due to minute differences in tolerances in products. So that is why we have margins of error +/-
Dom_
Points Mean Prizes
PostPosted: 21:39 - 03 Feb 2005    Post subject: Reply with quote
Your getting compression and a spark. SO the only other factors are air and fuel, i suggest you make sure the fuel line is clear and the petrol in the tank is ok and the petrol tap too. The battery wont make too much difference on a dt, as you said, its had a flat for ages.
I suggest you try bump starting it.
dtmaster
PostPosted: 16:59 - 04 Feb 2005    Post subject: Reply with quote
i will get my brother to give that a go as im not home untill next weekend, i ll let you know how he gets on.
Ross
1993 Yamaha DT125r
The last post was made 21 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 69.71 Kb
