master cylinder scews done derped
PostPosted: 19:35 - 30 Jun 2015    Post subject: Reply with quote
Small hammer and a flat punch / big Allan bit / something similar like the end of a 1/4" socket bar. See if you can hammer it a bit more solid again.
Buy and use an impact screwdriver. I use one by default now on any JIS / Phillips head that I haven't recently undone.
Quote Me Happy
PostPosted: 19:37 - 30 Jun 2015    Post subject: Reply with quote
An impact driver or drill them. Both have worked for me.
Just_James
PostPosted: 19:46 - 30 Jun 2015    Post subject: Reply with quote
As above for removal Thumbs Up
Just a tip when putting your new ones in though - buy decent stainless ones (pence) for a start then use some copper grease on the threads first. Saves you (or next owner) the hassle of it again.
I think I am yet to buy a bike that hasn't needed the m/c screws tapping or drilling out Evil or Very Mad
Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125
swampy
PostPosted: 20:07 - 30 Jun 2015    Post subject: Reply with quote
I don't think I've ever owned a bike that had the same master cylinder screws it came out of the factory with Very Happy
stirlinggaz
PostPosted: 22:46 - 30 Jun 2015    Post subject: Reply with quote
that's probably because no-one ever uses the correct screwdriver!
most of these m/c screws (on jap bikes anyway) are not your normal phillips or even pozi-drive screws.
they are JIS & therefore to remove them you need a JIS screwdriver.
I dont know anyone with a JIS screwdriver (apart from myself Smile ) although im aware another bcf'er mentioned he had one a while back.
beats me why they insist on using these bloody weird screws when nobody has the f*ckin tool to loosen them.
like others have said, they are best replaced with "normal" countersunk screws/bolts with a bit of copper grease on the threads.
I favour s/s with a slotted head that just need a "normal" flat bladed screwdriver or ones that need a "normal " allen key/hex bit.
TL/DR? if they are already chewed up, hammer in a torx bit, if they arent, use the correct screwdriver!(JIS)
cheers,
GAZ
andyscooter
PostPosted: 07:52 - 01 Jul 2015    Post subject: Reply with quote
the garage that ended up sorting mine last time put hex bolts in Thumbs Up
that was because the previous owner had fubared the screws
PostPosted: 11:41 - 01 Jul 2015    Post subject: Re: master cylinder scews done derped Reply with quote
PaulFzs wrote:
drilling as a last resort
Drilling isn't the last resort in my book. It's the quick and easy way.
If they don't come out with the screwdriver, I just drill them. No worries, lid's off in less than 2 minutes, the resulting nice long stump is easily removed with mole grips.
The screws are soft as shite anyway so they'll even drill off in next to no time with a hand drill.
The last post was made 11 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 74.09 Kb
