HELP Wiring issues on Keeway Superlight LTD
bridouga
PostPosted: 10:47 - 01 Jul 2015    Post subject: HELP Wiring issues on Keeway Superlight LTD Reply with quote
Hey, Long story short i shorted out the Indicator relay.
Tried to source a relay online and i found 1 for around £60 coming from USA.
I dont want to pay that and bought 2 x 3 pin relays online for pennies.
Only problem is that the previous relay had 6 wires.
I have looked online and cannot find and wiring diagrams and i do not understand the wiring...
The 6 wired are green/black , green/white , black , blue/red , red/yellow , red/white..
I have figured out with a multimeter that the green/black and green/white lead to the indicator light on the bincale and the black leads to the -(ve) in the battery. The blue/red goes to left indicator control, red/yellow goes to right indicator and red/white goes has 12volt going to it.
I want my indicators back
HELP please
bridouga
PostPosted: 10:49 - 01 Jul 2015    Post subject: Reply with quote
oh and the relays i bought have 3 pins (x,l and p)
x is 12volt+
L is indicator switch
P is dash indicator light
oouche
PostPosted: 11:40 - 01 Jul 2015    Post subject: Reply with quote
x is 12volt+
looks like r/w to both x
r/y to one l
b/r to other l
g/b to bulb side of indicator cct on one side will need rewiring
g/w to bulb side of indicator cct on other side will need rewiring
hope this helps
edit: if you can see indicators when riding you can ignore the binnacle light wiring
bridouga
PostPosted: 12:18 - 01 Jul 2015    Post subject: Reply with quote
What would i need to rewire?
From what to where?
oouche
PostPosted: 12:34 - 01 Jul 2015    Post subject: Reply with quote
From what to where?
from g/b to one side indicator i.e. tap in to the wire to the indicator bulb
and from g/w to the other side indicator
this is the system used on old vehicles using the earth through the indicator bulbs that are not lighting to light the binnacle bulb
perhaps best to check that the indicators work ignoring g/b and g/w then add in extra wiring once they work ok
WD Forte
PostPosted: 14:29 - 01 Jul 2015    Post subject: Reply with quote
Dont like the sound of this, not confident OP has full grasp of the situation.
Bike makers are creatures of habit and tend to use the same
wiring conventions
Honda for instance uses Green for ground, BMW Brown, Suzuki Black/White and so on
The Keeway diagrams I looked at all show the Green/white and Green/black used on L&R indicators and Black for ground cables.
Not the same model I admit but both follow the same conventions
Blue/red and yellow/red have functions unrelated to indicators
(kill switch to CDI and supply to dip switch)
Why would they change conventions for the OPs bike?
Suddenly changing colours on a harness is bad form
and I haven't come across it on any the chinese bike I've
had me mitts on.
Conventionally, the green/white for instance should go from the indicators all the way to the switch.
bikers smell of wee
bridouga
PostPosted: 19:32 - 01 Jul 2015    Post subject: Reply with quote
Tell me about it... i don't like this situation either.
IM FED UP WITH HANDSIGNALS
Green/white and green/black run to binacle indication light.
But also
there is a green/white and green/black as well as ground going to respective indicator bulbs.
I traced the wires the old fashioned way. And the blue/red & yellow/red both go to the individual indicator switches.
The last post was made 11 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 52.61 Kb
