Paiting motorcycle forks
john24ssj
PostPosted: 18:19 - 01 Jul 2015    Post subject: Paiting motorcycle forks Reply with quote
Hi guys,
I will be replacing my fork seals since and I will have the forks off I would also like to paint them as current paint is flaking off.
Could anyone give some tips on what I would need to paint them?
I know I'll need to remove and clean the previous paint off.
And if I got it right you need to first coat it with primer and then paint it?
Thanks guys Smile Much appreciated.
Bikes: Honda CBR600Fi, Kawasaki ER5
Teflon-Mike
tl;dr
PostPosted: 18:27 - 01 Jul 2015    Post subject: Reply with quote
If you aren't too fussed about a great finish.. which probably wont last too long anyway if you use a 'good' paint, as they sliders are prone to stone-chips; just brush-paint them with something like smooth-rite silver or black.
john24ssj
PostPosted: 18:30 - 01 Jul 2015    Post subject: Reply with quote
Any paint will be better than this:
https://i.imgur.com/jSCtNyol.jpg
Just_James
PostPosted: 18:46 - 01 Jul 2015    Post subject: Reply with quote
Depends how far you want to go with them really.
To give them a simple tidy up I'd give them a good rub down with some 240s wet and dry first (no need to remove all the old paint, just anything that's loose) and then go over them with some 600s wet and dry until smooth.
I'd then just degrease them and give a few light coats of rattle can satin black or silver. If you start putting thick paint on forks it will be prone to chipping so best just to build up a few light coats just enough to get coverage.
Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125
Fisty
Rub them down then plasti dip them.
Fatter and faster than Fret
john24ssj
PostPosted: 18:57 - 01 Jul 2015    Post subject: Reply with quote
Thanks guys Smile and what's a plasti dip?
john24ssj
PostPosted: 22:28 - 01 Jul 2015    Post subject: Reply with quote
Thank you for all the replies. Once I get the seals done I'll let you know how it goes Smile
john24ssj
PostPosted: 10:55 - 19 Jul 2015    Post subject: Reply with quote
Hey guys,
So I replaced the seals and got new fork oil and wow what a massive difference Very Happy
And I went with plasti dipping the forks and here are my results:
https://i.imgur.com/LcJCv6V.jpg
https://i.imgur.com/NYm0OE2.jpg
https://i.imgur.com/RUVwOyS.jpg
https://i.imgur.com/lzMNpZb.png
Thanks for all the help and advices Smile[/img]
john24ssj
PostPosted: 11:22 - 19 Jul 2015    Post subject: Reply with quote
Vincent wrote:
Good job Thumbs Up The proof of the pudding with painting though, is how it stands up over time.
I did just as you said, pretty much spent all day pre-ping the forks, removing all the old paint, sanding, using wet & dry and getting all the oils off. It did make it a very nice and smooth surface to paint on Smile
Itchy
PostPosted: 11:50 - 19 Jul 2015    Post subject: Reply with quote
You could always put protectors on them. The ZX6R J2 has protectors for the fork legs.
Of course the protectors will get chipped and stuff. So now you need protectors for the protectors.
The protectors for the protectors will also get chipped so... Laughing
delsol
PostPosted: 13:07 - 19 Jul 2015    Post subject: Reply with quote
Nice job OP.
You should rightly be well pleased with that finish Thumbs Up
john24ssj
PostPosted: 15:16 - 19 Jul 2015    Post subject: Reply with quote
Itchy yeah I know what you mean it's a vicious never ending circle!
delsol thank you Smile I was indeed every proud when I did it but my mistake was spraying it first before assembling the forks, so I got oil and smudges and few cuts in it. But plasti dip itself seems quite solid.
john24ssj
PostPosted: 19:17 - 19 Jul 2015    Post subject: Reply with quote
Vincent wrote:
john24ssj wrote:
Is that a rubber/plastic cap on the spindle end?
Yes it's a rubber cap and has some lubricant inside, when it comes to remove the nut it goes quite nicely Smile Actually the nut looks almost new
Serendipity
PostPosted: 21:08 - 19 Jul 2015    Post subject: Reply with quote
Looks pretty good.
What colour did you go for? Is that gun metal grey with a coat of pearlizer over the top or something else?
The fork lowers on my CBF1000 are in a poor state so may do something similar.
2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
john24ssj
PostPosted: 21:38 - 19 Jul 2015    Post subject: Reply with quote
I did it in 2 parts:
Plastidip Black - £14.30 as my base coat and main coat (4 layers)
and
Plastidip Silver Metalizer - £14.95 as my top finishing metal looking coat (2 layers)
You don't need the metalizer it's only to give a sort of metal look. You can use a glossifier but I didn't as I think it looks better like this.
PostPosted: 21:51 - 19 Jul 2015    Post subject: Reply with quote
Nice job Thumbs Up
Triumph Trophy Launch Edition
kramdra
PostPosted: 22:23 - 19 Jul 2015    Post subject: Reply with quote
Looks good. Get some vinyl over the top to protect it. Get it as a sheet from ebay and cut to fit, so you can cover whole thing.
My forks have done 60k miles, and they have a small 100x50mm bit of vinyl protector, I assume from new. Looks great, stones have not touched them or the paint behind. I would like to punch the lazy/cheap git for not doing the whole fork lowers, as the surrounding paint looks utter shit Crying or Very sad
john24ssj
PostPosted: 09:26 - 20 Jul 2015    Post subject: Reply with quote
Sounds like a good idea.
I want to actually test the plastidip paint out as it's rubber/plastic it says that it does not chip or scratch like normal paint does.
delsol
PostPosted: 11:37 - 20 Jul 2015    Post subject: Reply with quote
The vinyl is a good idea and I am not at all against using it to increase protection where it is known that the primary protection is less than adequate.
However, you just spent £15.00 a can on a product that makes certain claims, I would want to find out if it was good enough to be considered for use in the future, if it works, then fair and well, if it needs a force-field around it to make it last then I would want to know that also.
I like and share your reasoning on this.
john24ssj
PostPosted: 15:29 - 20 Jul 2015    Post subject: Reply with quote
I know what you mean Delson, Also I am going to paint the end of my exhaust as the old paint is also coming off and rusting at places.
The last post was made 10 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 131.09 Kb
