Name of rubber pipe
stranger12
PostPosted: 07:52 - 04 Jul 2015    Post subject: Name of rubber pipe Reply with quote
Hi guys,
Here is what i want to buy but don't know its name so have been trying for few hours to find it using different keywords with no luck
There are those hard rubbers that have a cut in the middle which you can open and snap it on pipe or something which can then act as protective cover or even coupling or holding two things together
I need it to i can hold my two braided lines together rather than using cable tie
Also need it so can cover part of the metal which the line robs against
I hope this makes sense
SV650 Red
R6 Red
Raffles
PostPosted: 08:45 - 04 Jul 2015    Post subject: Reply with quote
Do you mean something like this?
https://www.waytekwire.com/images/items/LCPFL.gif
misscrabstick
PostPosted: 10:01 - 04 Jul 2015    Post subject: Reply with quote
I'd call it cable conduit.
https://www.ebay.co.uk/itm/Black-Spiral-Conduit-Split-Non-Split-Tube-Cable-Tidy-/321759273599?pt=LH_DefaultDomain_3&var=&hash=item4aea58e27f
stranger12
PostPosted: 10:07 - 04 Jul 2015    Post subject: Reply with quote
Yep but it is hard rubbery
SV650 Red
R6 Red
bugeye_bob
PostPosted: 10:17 - 04 Jul 2015    Post subject: Reply with quote
Just buy some coloured silicone hose to protect and areas that rub,just cut a slit down or use scissors to slit,
adds a splash of colour if thats your thing.
hth
gbrand42
PostPosted: 10:46 - 04 Jul 2015    Post subject: Reply with quote
I've got one of them, it's name is Norman
Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European
PostPosted: 11:10 - 04 Jul 2015    Post subject: Reply with quote
I'd suggest using shrink tube if you want to hold your braided lines together.
Ideally you wouldn't want them rubbing against metal at all. I use stainless P-clips to route them properly.
https://images.safety-marine.co.uk/dbimages/3183/jcs-stainless-steel-p-clip-medium.jpg
And cable separator blocks to tandem them:
https://www.fastbikebits.com/shopimages/products/normal/CBSTPU.jpg
stranger12
PostPosted: 11:13 - 04 Jul 2015    Post subject: Reply with quote
Yep got the p clips but prefer something like the cable conduct
I think the metal or wire seperatir will rub against fork and scratch the tube
SV650 Red
R6 Red
PostPosted: 11:22 - 04 Jul 2015    Post subject: Reply with quote
....because rubber won't rub them either. Neutral
Route so they are safe from fouling the tubes.
stranger12
PostPosted: 11:14 - 15 Jul 2015    Post subject: Reply with quote
also the pipe passes through a metal hook , should I use some tape around the hook so any friction between the pipe and the hook won't wear the pipe ?
I have seen these rubber material that have a slice in middle which you can open and snap it onto a pipe so many times in cars but just don't know its name .
SV650 Red
R6 Red
ADAMH0
PostPosted: 21:17 - 15 Jul 2015    Post subject: Reply with quote
Can you give a specific make/model of car and where exactly they are used?
I have access to a few car parts catalogues so could look up a part/image which may help identify what they are called. At the moment, I can only picture the type of items that others have already suggested. Thinking
stranger12
PostPosted: 08:07 - 16 Jul 2015    Post subject: Reply with quote
don't remember the where I have seen it ( on which car) but will dig around Smile
SV650 Red
R6 Red
The last post was made 11 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.61 - MySQL Queries: 13 - Page Size: 70.15 Kb
