Did I just buy Bodyguard's Fazer?
GeorgeB.
PostPosted: 16:47 - 04 Jul 2015    Post subject: Did I just buy Bodyguard's Fazer? Reply with quote
Just bought a fazer off a bloke in Darwen. As I was getting it home, the clutch cable snapped. That's a bit unfortunately timed, I think to myself. No worries though, I'll go and grab a new one and fit it, go out on it in time for a blast before work.
Whip the front sprocket cover off, only to find this:
https://imgur.com/celMF8G
I reckon it's snapped changing gear without the clutch. Fucking annoyed isn't the word. Gonna see if the guy will just refund it, but my hopes aren't high.
Current: '99 Fazer 600 | '99 Range Rover P38 4.6 HSE
Previous: Keeway TX125 | CBF 125 | CB400SF Project Big One
CBT 04/12/12 | Theory 03/12/13 | MOD 1 06/01/14 | MOD 2 13/01/14
Nobby the Bastard
Harley Gaydar
PostPosted: 16:49 - 04 Jul 2015    Post subject: Reply with quote
Picture link bolloxed.
Triumph Sprint ST 1050
GeorgeB.
PostPosted: 16:51 - 04 Jul 2015    Post subject: Reply with quote
NJD
PostPosted: 16:52 - 04 Jul 2015    Post subject: Reply with quote
OP's image:
https://i.imgur.com/celMF8G.jpg
No idea why it's so big Rolling Eyes
CaNsA
PostPosted: 16:54 - 04 Jul 2015    Post subject: Reply with quote
NJD wrote:
OP's image:
Rolling Eyes
Op's image resized
https://i.imgur.com/celMF8Gl.jpg
PostPosted: 17:09 - 04 Jul 2015    Post subject: Reply with quote
What's the shaft look like? I had a yammy and the thread was pulled out of the nut but the thread on the shaft was fine.
Vracktal
PostPosted: 17:46 - 04 Jul 2015    Post subject: Reply with quote
Looks like the thread for holding the sprocket nut on is fucked. And the chain looks slack.
Should check to see if the subframe is bent also.
2007 BMW R1200R: On road
2009 BMW G650X Challenge: On road
1975 Norton Commando 850: Off road, awaiting recommissioning
WD Forte
PostPosted: 18:05 - 04 Jul 2015    Post subject: Reply with quote
Yep looks nasty, I'd be seriously pissed off to find that.
(Its not even a good bodge, ie crude but effective)
Cant see the relative dimensions so unsure of shaft diameter
but if a refund or new shaft is a PITA,
is there anything be said for counterboring and tapping the output shaft and using a bolt/washer type thing?
https://oi60.tinypic.com/2rndg85.jpg
bikers smell of wee
PostPosted: 18:11 - 04 Jul 2015    Post subject: Reply with quote
Might be possible to recover with a decent thread file and a new nut.
chickenstrip
PostPosted: 18:16 - 04 Jul 2015    Post subject: Reply with quote
If you're stuck with the bike, it might be worth approaching Yamaha regarding a replacement nut and shaft.
Yamaha issued a thicker replacement sprocket nut (originals were 9mm thick, I think the replacement is 12mm). They said it wasn't a recall but a modification
Rolling Eyes
They also replaced some output shafts depending on certain thread measurements, which unfortunately it doesn't look like you'll be able to take. But if that is a 9mm nut, you might be able to argue for the output shaft replacement too. All if you can't chuck the bike back at the seller of course. Might be worth a shot.
PostPosted: 18:21 - 04 Jul 2015    Post subject: Reply with quote
I don't think I would trust that Pete, too much of the thread has gone.
Triumph Trophy Launch Edition
PostPosted: 18:38 - 04 Jul 2015    Post subject: Reply with quote
What you got to lose? The nut can't fall off with the sprocket cover fitted.
chickenstrip
PostPosted: 18:46 - 04 Jul 2015    Post subject: Reply with quote
The 9mm nuts can and do come off. It's well documented that a number of owners have taken the cover off to find no nut there at all Shocked
PostPosted: 18:49 - 04 Jul 2015    Post subject: Reply with quote
Aah right. On my Fazer the nut was rattling about on the shaft so much the threads were all peened away but it never fell off. I just got a new nut, gave the threads a bit of a dress and fitted it on.
PostPosted: 19:24 - 04 Jul 2015    Post subject: Reply with quote
Couldn't go too large on the hole size though. That shaft transmits the full power from gearbox to front sprocket so I'm not sure how much metal removal it would take without failing.
Sload
PostPosted: 19:30 - 04 Jul 2015    Post subject: Reply with quote
Probably his cheapest and easiest solution at this point though. He either tries to rectify it or replaces the shaft at this point (unless he can get his cash back). looks like a pain to chase a thread back onto that.
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
PostPosted: 19:55 - 04 Jul 2015    Post subject: Reply with quote
Wouldn't the "cheapest and easiest solution" be to weld the nut back on?
Vracktal
PostPosted: 19:57 - 04 Jul 2015    Post subject: Reply with quote
Also worth considering - the sprocket and gearbox shaft get pretty hot at motorway speeds, might find using this method ends up with the bolt permanently seizing in the hole you drill. Confused
PostPosted: 20:00 - 04 Jul 2015    Post subject: Reply with quote
It's the splined bit that takes the load though.
Looks like plenty of meat beyond that to drill and tap a hole to get a long enough bolt in there. Remember the nut/bolt only stops the sprocket coming off the splines, it shouldn't be seeing any significant sideways load providing the chain is straight and true.
Besides which, in engineering terms, a hollow tube is almost as strong as a solid bar of the same diameter, especially in compression.
I like what WD Forte suggests. Hole down the shaft and tap it to fit a big f-off flange bolt with a fine pitch such that you can fit a spacer under it to hold the sprocket on the splines. Bet you could even make the spacer out of nylon (or drill out the centre of the welded nut of doom slightly and use that as a spacer).
I'm not even going to suggest you could probably turn down the outside of that shaft in situ to a sufficiently accurate degree of roundness to run a die down it by using a die grinder on it with the chain off and the engine running in gear so the shaft is rotating. That would be silly... Thinking I know people who'd do it. Then again, I know someone who skimmed their rear brake drum by running the bike in gear on the mainstand having first glued emery paper to an old set of brake shoes and giving the adjuster nut a 1/4 turn every time it went quiet.
Sload
PostPosted: 20:01 - 04 Jul 2015    Post subject: Reply with quote
Why the heck not, was so successful the first time around Smile
PostPosted: 20:03 - 04 Jul 2015    Post subject: Reply with quote
Other bikes can and do use a bolt rather than a nut in that situation. My VFR750 being one example.
bugeye_bob
PostPosted: 20:47 - 04 Jul 2015    Post subject: Reply with quote
Some even use a C clip
https://img.photobucket.com/albums/v11/redshift/Sprocket%20Change/17TMounted.jpg
PostPosted: 20:53 - 04 Jul 2015    Post subject: Reply with quote
C-clip is a viable option. Cutting the groove would be a heck of an exercise but I reckon it's doable with a jig.
mentalboy
PostPosted: 21:03 - 04 Jul 2015    Post subject: Reply with quote
Hence the reason someone has already gone down that route!
...But if the OP does I'd recommend replacing that sprocket because it's past it's best.
chickenstrip
PostPosted: 21:20 - 04 Jul 2015    Post subject: Reply with quote
Well, don't know about you lot, but if I were keeping the bike, I'd do as I suggested and approach Yamaha first. Any kind of drilling, grooving the shaft for clips etc has got to be a second choice to a replacement shaft and nut gratis on Yamaha?
It has been successful in past cases. Whether or not they would still do it now, I don't know, but what you got to lose by asking? It's a problem well known to Yamaha.
The last post was made 11 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 138.19 Kb
