Law on numberplate visibility?
Albigularis
PostPosted: 22:49 - 04 Jul 2015    Post subject: Law on numberplate visibility? Reply with quote
I was looking at some options for moving the plate on my bike, and after over tightening some stuff, I need to replace the undertray.
I've been looking at moving the plate further in the bike, sort of like this-
https://www.sportbikes.net/forums/attachments/general-sportbikes/138838d1191031609-new-bike-07-600rr-long-but-pics-1krr05small.jpg
On my bike, I can do that with a full size plate and it still seems fairly visible from behind- mock up jammed in with a cloth -
https://i.imgur.com/G5bLH81.jpg
What's the legality of doing this? It's still easily visible from behind as normal, even at an angle, as the pillion pegs aren't on and the exhaust hangar goes back a fair bit.
I had a search and couldn't really find much other than this-
60. Fixing of registration plate
(1) (a) Where a vehicle has been so designed that a space has been provided for the fixing
of a registration plate, the plate shall be fixed in the space so provided.
(Where a space is not provided the plate shall be fixed in the manner specified in
paragraph (2)).
(2) Subject to paragraph (3), a registration plate shall be fixed vertically or, where that is not
reasonably practicable, in a position as close to the vertical as is reasonably practical at the front and
rear of every motor vehicle in such manner that the characters of the registration mark shall, at all
times, be visible from the front or the rear of the motor vehicle.
So if I replace the undertray with one that doesn't have the cut-outs for the tail tidy (most don't), it's all perfectly legal?
inb4 N30 style decal
Biking history so far-
Aprilia RS125 - Kawasaki ZXR400 - Triumph Street Triple R - Suzuki GSXR1000 L3 - BMW R1200GS - Kawasaki Z1000 - Kawasaki ZX10R C1H - Ducati Multistrada 1200 S Touring - Suzuki Hayabusa
wr6133
PostPosted: 23:13 - 04 Jul 2015    Post subject: Reply with quote
How visible is it when sat in a 4X4 and tailgating the bike? (I'd imagine that would be PC pric's reasoning when stopping you).
Albigularis
PostPosted: 23:29 - 04 Jul 2015    Post subject: Reply with quote
From what I can gather, plenty. The tail is at such a steep angle and so high that you'd definitely be able to see into it from behind.
https://i.imgur.com/v64sKnb.jpg
binge
Emo Kiddy
PostPosted: 23:35 - 04 Jul 2015    Post subject: Reply with quote
Pretty sure it's stated that a number plate must be mounted as near to the back of the vehicle, and as vertically as possible.
You could argue that (once tail tidy replaced etc) that the new location IS as far back as possible.
But then they will go down the 'modified and now not fit for purpose' route.
In reality, you'll probably be fine. I've ran smaller plates in more stupid positions.
But now and then, you will come across a Traffic Cop that'll have you for it.
Very unlikely to get trouble from your usual PC plod.
Used to run mine on the YZF450 in the same place. Never had any issues.
But then again, I would never have stopped to talk to a copper on it anyway. Nearest field, and see ya!
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xfa1/v/t1.0-9/545024_10151326754225606_1525150236_n.jpg?oh=5168e7fb7f7a51e510574f805d762def&oe=5616675E
CaNsA
PostPosted: 02:50 - 05 Jul 2015    Post subject: Reply with quote
I would think about the amount of travel the swing arm has.
You don't want to be damaging your hugger or the undertray.
N30 didn't get too much hassle IIRC, got stopped a few times but nothing major.
https://i.imgur.com/K6rMwE8.jpg
https://i.imgur.com/29eLlPJ.jpg
Teflon-Mike
tl;dr
PostPosted: 04:56 - 05 Jul 2015    Post subject: Reply with quote
Wording is 'Rear' of the vehicle... Competition regs tend to use the wheel-axles as datums, so I'd suggest that anything in-front of the front axle was 'front' anything behind the back axle 'rear' and anything between, 'the middle'... so a rear-number plate mounted in-front of the back wheel, I think could pretty much be construed as a contravention of C&U regs as not being mounted at the rear, or even as close as practically possible to the 'rear', before any debate over whether its 'clearly visible'!
Bottom line, really is,do you want to give a half clued up cop an excuse to pull you over for a closer look, at that and anything and everything else? And then do you REALLY want to have the debate with him over the matter, when you already know that at best it's 'contentious'. And what's the gain in the mean-time? Dubious aesthetic merit?
Just mho, but I don't see much point in handing plod my licence on a 'plate'. Dangle a regulation sized and spaced one under the tail-lamp where they expect it and avoid the contention, and make them work to catch you committing a real crime if your prepared to do the time.
PostPosted: 10:58 - 05 Jul 2015    Post subject: Reply with quote
'Sup.
https://www.legislation.gov.uk/uksi/2001/561/regulation/5/made
Dem regs wrote:
A registration plate must be fixed on the rear of the vehicle vertically or, where that is not reasonably practicable, in a position as close to the vertical as is reasonably practicable in such a position that in normal daylight the characters of the registration mark are easily distinguishable from every part of [a square with a 22m diagonal and one corner under the plate]
https://i.imgur.com/4d3xnBV.png
defblade
PostPosted: 11:06 - 05 Jul 2015    Post subject: Reply with quote
To me, putting a plate there just says "this guy intends to ride well over the speed limit and/or like a twat, and is trying not to get caught". So Mr Bored Plod might just decide you're worth stopping when if your bike had looked 100% legal, he'd have turned a blind eye to the speed.
I think in your case, I might go with a a-bit-smaller-than-usual-but-not-tiny plate... mounted at the back.
delsol
PostPosted: 13:12 - 05 Jul 2015    Post subject: Reply with quote
You have answered your own question, your pic illustrates that the number plate is obscured.
Mr/Mrs Plodingham will tell you "it is all about enforcement" as they try to keep a straight face writing out the wonga remittance advice note.
PostPosted: 13:33 - 05 Jul 2015    Post subject: Reply with quote
You can only put your plate as hidden as possible under the (twisted?) subframe if you're cool enough. By having your plate like that you're letting everyone else know just how cool you are. Thumbs Up
Post your cool stories, pictures and videos on facebook pitbike pages and sites such as 125ccsportsbikes.com because they'll be much more impressed than BCF.
Who knows, if you post enough photos, youtube videos and cool stories, you can pimp yourself to get discounted bike parts from companies.
Because you had to ask if it's legal to have your plate like that, you're clearly not cool enough and never will be. Thumbs Down
The Artist
PostPosted: 13:38 - 05 Jul 2015    Post subject: Reply with quote
No one remember IIN30II's old plates?
https://i.imgur.com/88DHfiC.jpg
https://i.imgur.com/NpZXwXi.jpg
CaNsA
PostPosted: 13:40 - 05 Jul 2015    Post subject: Reply with quote
The Artist wrote:
I didnt read the thread
No shit!
https://www.bikechatforums.com/viewtopic.php?p=4149600#4149600
The Artist
PostPosted: 13:49 - 05 Jul 2015    Post subject: Reply with quote
CaNsA wrote:
No shit!
Pics didn't work for me for some raisin.
CaNsA
PostPosted: 13:59 - 05 Jul 2015    Post subject: Reply with quote
Re-hosted Thumbs Up
69.9mph
PostPosted: 18:47 - 05 Jul 2015    Post subject: Re: Law on numberplate visibility? Reply with quote
paragraph (2)).
Even if it is legal, it is still undesirable. It makes you look like a wanabee. HTH
ADSrox0r
PostPosted: 19:08 - 05 Jul 2015    Post subject: Reply with quote
Nah, pointless. Just gives plod an excuse to finger you if he's feeling mardy.
ReadySalted
PostPosted: 19:48 - 05 Jul 2015    Post subject: Reply with quote
I don't really get why you'd want to do it. I put the whole small number plate thing on the same level as kids with fiat puntos who drop the suspension, or put alpine stickers on the doors. To the reader of max power it may look like you're Rossi on your day off, but to most other road users I think it would give the impression of being a knobber.
At risk of offending a large population of the bcf community, I have never really understood small plates. From what I gather they leave you open to points and fines for such little aesthetic gain (and even an aesthetic gain is debatable).
Having said that, it takes all sorts. I'm probably the guy you wheelie past thinking what a pussy, so each to his own.
Motorhate
PostPosted: 13:14 - 09 Jul 2015    Post subject: Reply with quote
The first thing a cop will pull you over for if he wants to is an irregular number plate. They're terrible for it round my way. Traffic cops are the worst and I've seen them get tape measures out to measure the height of letters and numbers on mine. They're also pedantic about the font too for some reason. Italics and fancy fonts are a no-no as they reckon it messes with speed cameras and average speed cameras. Also, a lot of mates have gotten away with using black rear number plates on relatively new bikes but I've never been that lucky so just don't use them. I think some of the photos above wouldn't last 5 mins around some pedantic traffic cop.
Saying that, I rode over 300miles with no number plate as it came off when I removed the cover from the bike once.
Current - Harley Davidson FXDB Street Bob | Harley Davidson FLTR Road Glide | Harley Davidson Road King
GONE - Honda CB500 Ratbike | Yamaha FZ750 | Yamaha XVS1100 | Kawasaki VN2000 | Kawasaki ER-6 F | Harley Davidson XL883L Sportster
Joncrete Cungle
PostPosted: 18:42 - 09 Jul 2015    Post subject: Reply with quote
To me having your plate mounted like that screams out 'PLEASE WARRANTED CUNTSTUBBLE MISERYCHOPS PULL ME OVER FORTHWITH' while the fine warranted constable goes over everything with a fine tooth comb, thrice. I have seen more than once rozzers measuring number plates, the size of the fonts and the spacing. Then going on to such kitten genocidal crimes as tinted visors and fruity exhausts.
Much ticket writing bad. But yer pays yer money yer takes yer chances, let us know how you get on.
The last post was made 11 years, 62 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 112.9 Kb
