| 770 |
 770 Nova Slayer
 Posted: 21:14 - 05 Jul 2015 Post subject: 2 stroke rattle noise |
There is a noise in the engine that runs with the rpm, when I rev, it ticks faster. I can also hear this noise when I ride. I have checked for slack in crank on both sides, changed piston, the conrodl and the whole clutch side. Also checked for engine mounts. It still runs normally and starts as usual. Can the main bearings be bad anyway? I'm starting to run out of ideas here ..
sound:
https://www.youtube.com/watch?v=P4L8OUs6HK0 |
| Vincent |
 Vincent Banned
| 770 |
 770 Nova Slayer
| Vincent |
 Vincent Banned
| 770 |
 770 Nova Slayer
| Vincent |
 Vincent Banned
| 770 |
 770 Nova Slayer
 - Super Spammer
 Posted: 08:48 - 06 Jul 2015 Post subject: |
A couple of options. Firstly, if you changed the small end bearing, what about the gudgeon pin? I normally change piston, rings, small end, pin and circlips at the same time.
Also, has it been rebored? On some engines with high squish, the standard size head gasket needs honing out a bit to match the size of the over bored piston, or the top end of the piston can catch it.
Main bearings are normally more of a knocking, rumbling noise than that.
When you changed the piston was there any damage? A small piece of ring may have ended up in the crank and has now found it's way up to the combustion chamber through a transfer port and is now merrily bouncing about. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG. |
| 770 |
 770 Nova Slayer
 Posted: 11:34 - 06 Jul 2015 Post subject: |
| mpd72 wrote: | A couple of options. Firstly, if you changed the small end bearing, what about the gudgeon pin? I normally change piston, rings, small end, pin and circlips at the same time.
When you changed the piston was there any damage? A small piece of ring may have ended up in the crank and has now found it's way up to the combustion chamber through a transfer port and is now merrily bouncing about. |
Yes, new piston so new rings, small end bearing, pin bolt and circlips. There is no head gasket kinda, there are just 2 O-rings. The old piston and ring had no damage itself, but it was getting black beneath the ring. |
 - Super Spammer
| 770 |
 770 Nova Slayer
 - Super Spammer
| 770 |
 770 Nova Slayer
| Vincent |
 Vincent Banned
| bikenut |
 bikenut World Chat Champion
 Posted: 13:28 - 06 Jul 2015 Post subject: noise |
seen video but no audio here........our computer......
1.does it make the noise if the flywheel cover is off??
2.is anything under the flywheel touching anything else??
3.how about on the primary drive side, anything in there involved with the crank touching anything else, apart from gear teeth to gear teeth or balance system?
4.sure its not an exhaust leak?
5. reeds?
6.did you check for "bump clearance"? yes I know its a petrol engine but still??  ____________________ nuts about bikes |
| Vincent |
 Vincent Banned
| 770 |
 770 Nova Slayer
| 770 |
 770 Nova Slayer
 Posted: 14:16 - 06 Jul 2015 Post subject: Re: noise |
| bikenut wrote: | seen video but no audio here........our computer......
5. reeds?
6.did you check for "bump clearance"? yes I know its a petrol engine but still??  |
1. yes
2. no
3. I have taken off the whole clutch and inspected the whole right side, I have also taken off the flywheel and tried to jiggle the crank, there's no slack.
4. The noise is definitly from the engine
5. Just checked them, they are in good condition.
6. I don't think that's possible since I have been riding a long time without any noise like this, it suddently came after a ride. |
| bypass2 |
 bypass2 Spanner Monkey
| bikenut |
 - Super Spammer
 Posted: 13:20 - 07 Jul 2015 Post subject: |
Having listened to the second video, that is more of a rumble now. I'd be guessing at big end or main bearings now. Big end should be fairly obvious if you pop the barrel off and check for movement in the con rod.
I'm not sure no side to side movement in the crank would mean the main bearings are good.
Sometimes, disconnecting the primary drive, piston and generator rotor, you can then turn the crank and by hand and feel a tight spot or rough running on the bearings without having to split the crankcase. If the con rod feels OK, then main bearings at a guess.
Time for a strip down though. Top end first. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
| bladerunner |
| 770 |
 770 Nova Slayer
 Posted: 10:41 - 08 Jul 2015 Post subject: noise |
The bike felt like it was surging, when I was going to clutch out from first it sounded like I needed to choke it. When turning it off I heard this squeaky noise, and everytime I kickstart it this squeak comes and the engine stops after a few seconds..
I have already checked clutch, piston, conrod, flywheel. Basically everything you can check without splitting.
VIDEO
https://youtu.be/VcQao433GjQ |
 - Super Spammer
 Posted: 11:21 - 08 Jul 2015 Post subject: Re: noise |
| 770 wrote: | The bike felt like it was surging, when I was going to clutch out from first it sounded like I needed to choke it. When turning it off I heard this squeaky noise, and everytime I kickstart it this squeak comes and the engine stops after a few seconds..
VIDEO
It wont fix itself, no matter how many Youtube videos you post.
As was said earlier, time to strip it down. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
The last post was made 10 years, 262 days ago. Instead of replying here, would creating a new thread be more useful? |
