OpenSCAD Experts?
ScaredyCat
PostPosted: 23:27 - 05 Jul 2015    Post subject: OpenSCAD Experts? Reply with quote
I know some of you do 3d printing and I seem to remember someone uses openSCAD. I've built my object, but in such a way that it's essentially a series of thin layers:
https://dl.dropboxusercontent.com/u/188253/_bcf/openscad1.png
There are a couple of reasons for this
1. I want to be able to build a prototype by printing templates for each layer and then cut them out of cardboard for test assembly.
2. I want to use a mixture of materials in the final object, so layers seems to be the simplest approach.
While I can export an STL file, the only thing I have that can read them is OpenSCAD and if I try to export as an image OpenSCAD tells me it's not a 2d object (fair enough) - So how do I go about getting the layers printed on my printer?
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
nowhere.elysium
The Pork Lord
PostPosted: 23:32 - 05 Jul 2015    Post subject: Reply with quote
Can you not export each layer piece as a dxf?
ScaredyCat
PostPosted: 23:48 - 05 Jul 2015    Post subject: Reply with quote
No, it wont let me. The console says
WARNING: Current top level object is not a 2D object.
nowhere.elysium
The Pork Lord
PostPosted: 10:03 - 06 Jul 2015    Post subject: Reply with quote
OK, take a look at projection, then.
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/3D_to_2D_Projection
:edit: the 'not a 2d object' thing is weird - dxf can handle 3d objects just fine.
ScaredyCat
PostPosted: 10:13 - 06 Jul 2015    Post subject: Reply with quote
Saved each layer as an STL and then reopened in openscad and used
Code:
projection(cut = false) import("v2-mid-startlayer.stl");
and can now export as DXF - although, for added fun, under linux the only export available seems to be for STL whereas on my Mac I get multiple file format options.
nowhere.elysium
The Pork Lord
PostPosted: 10:20 - 06 Jul 2015    Post subject: Reply with quote
Code:
What? Why?
Use an iterator to move the whole model in Z in whatever increments you need, with cut set to true. So much less faff, and it's an eminently re-usable function afterwards.
ScaredyCat
PostPosted: 11:05 - 06 Jul 2015    Post subject: Reply with quote
What? Why?
It's not a solid object sliced it's individual layers (about 4mm thick). ie A module for each layer and I just render the one I'm interested in.
My first go with openscad so I'm just learning but the intention isn't to get it 3d printed, but laser cut instead.
nowhere.elysium
The Pork Lord
PostPosted: 12:19 - 06 Jul 2015    Post subject: Reply with quote
What did you want it cut from? If it's metal, I can't help, but wood or plastics are fine in my machines at work.
ScaredyCat
PostPosted: 15:33 - 06 Jul 2015    Post subject: Reply with quote
I want wood, although I've no idea what sort of wood is suitable. A lot of what I've seen is ply stuff - I suspect you have much more knowledge on what wood cuts well with a nice finish. What sort of file format would it need to be in? I've managed to get the layers into inkscape using slic3r.
Also found that red seems to be the colour for cuts and black for engraving and 0.01mm line widths?
The last post was made 11 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 66.29 Kb
