Premium petrol worth it? Should I be using fuel cleaner?
Tracer1234
PostPosted: 16:02 - 06 Jul 2015    Post subject: Premium petrol worth it? Should I be using fuel cleaner? Reply with quote
Hey all, random, and once again, noob Question. (well two questions)
1, is it worth while buying the premium petrol from fuel stations? Its not much money more, but is it worth it?
2, Is it worth using the fuel cleaner every now and again, and if so, who often Smile
Thank you all.
Riding: Yamaha MT-09 Tracer Occasionally Riding: 08 Suzuki SV650, Potato: 2011 Yamaha YBR Custom.
Used to ride: 2015 Yamaha MT-09 Tracer (smidsy) 09 Triumph Street Triple (P/X'd) 08 Yamaha YBR (Sold)
CBT 04/14. A: Mod 1 & 2 13/04/15
NJD
PostPosted: 16:09 - 06 Jul 2015    Post subject: Reply with quote
From general opinion that I've encountered preimum unleaded has no benefits over unleaded at supermarket petrol stations.
Using a shell garage as opposed to supermarket fuel seems to be recommended, I've always done the opposite, should really see if the grass is greener on the other side some day Thinking
Matt B
PostPosted: 16:14 - 06 Jul 2015    Post subject: Reply with quote
Try the super unleaded for a few tanks and see, won't do any harm apart from to your wallet.
Some people say that they have seen more miles per tank with it but you would need to do a back to back test for proper proof. Your bike is designed to run on 95 fuel so why waste money?
Robby
Dirty Old Man
PostPosted: 17:33 - 06 Jul 2015    Post subject: Reply with quote
Normal petrol is fine.
Super unleaded generally contains more detergent. This cleans things. If your bike has been sitting for a long time and the carbs are full of varnish, super unleaded may shift it slightly faster than regular, although both would eventually do it. A proper carb clean would be the right way to do it.
If the engine is choked up with carbon deposit, super unleaded may shift them a bit quicker than regular - but both of them will do it eventually.
Casper
PostPosted: 20:20 - 06 Jul 2015    Post subject: Reply with quote
Small cap of white spirits in the tank now and then to keep things clean Thumbs Up
Bloggsy
PostPosted: 22:04 - 06 Jul 2015    Post subject: Reply with quote
White Spirits??? Vodka or Gin????
PostPosted: 22:13 - 06 Jul 2015    Post subject: Re: Premium petrol worth it? Should I be using fuel cleaner? Reply with quote
Depends what you mean by premium unleaded.
If you just mean a fuel with a higher octane rating then for 99% of bikes it will have zero benefit. A tiny number of bikes have a knock sensor to detect knock and allow the ECU to retard / advance the ignition timing to go with it. If you have a bike that requires high octane fuel, then using low octane fuel is likely going to cause severe engine damage.
If you mean one of the other fuels then maybe. Some have a claimed higher energy content, some contain better detergent packages.
K
Tracer1234
PostPosted: 22:19 - 06 Jul 2015    Post subject: Reply with quote
Ok thank you all, what about those bottles of fuel cleaner that you can put into a tank of petrol? Smile
PostPosted: 00:55 - 07 Jul 2015    Post subject: Reply with quote
Wouldn't ever go there. Gone are the days where you need to stick in STP, octane boosters, snake oil etc.
jjdugen
PostPosted: 06:16 - 07 Jul 2015    Post subject: Reply with quote
If you are laying up your bike for a while, fill up with super first. It has less, or no ethanol content, that's the stuff that goes off quickly and gums things up.
stevo as b4
PostPosted: 06:40 - 07 Jul 2015    Post subject: Reply with quote
I'd possibly use a pour in injector cleaner on an older or high miles EFI engine, or one that spends months at a time sat unused etc.
petrol fuel injectors can get dirty and gummed up a bit, and there's no DIY way to safely clean and test them.
The last post was made 11 years, 107 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 70.49 Kb
