Yamaha wr125x iridium spark plug worth the price?
geraghty125
PostPosted: 12:37 - 06 Jul 2015    Post subject: Yamaha wr125x iridium spark plug worth the price? Reply with quote
I have recently brought a 2014 yamaha wr125x and i am intending on looking after her ( i tend to brake bikes) so i want to buy nothing but the best for her but i have read alsorts of bad things about iridium over the factory copper plugs any help would be nice.
Also could you dumb it Down am not a mechanic or scientist.
arry
PostPosted: 12:38 - 06 Jul 2015    Post subject: Reply with quote
Ain't worth it. Stick with coppers and change often since they're peanuts
PostPosted: 13:14 - 06 Jul 2015    Post subject: Reply with quote
Yup. If your plugs are hard to get at then iridium makes sense as they (ostensibly) last longer. If you've got easy access, I'd just slap an NGK in and keep it cleaned and gapped.
Acerman This post is not being displayed because the poster is banned. Unhide this post / all posts.
delsol
PostPosted: 14:37 - 06 Jul 2015    Post subject: Reply with quote
Iridium plugs are better by design and materials, they can cost up to 4 times the price of standard plugs. But are they worth it ?
Long life:
My worry here is that they could be installed for 10 years or more (e.g. 2500 miles per year would keep them within manufacturer's life expectancy blurb), my main concern would be 'fit & forget' and find them fubar seized when you 'have' to remove them.
Less Maintenance: Yes
Reliability: Yes
Improved Performance: Personally I cannot tell the difference.
If you are happy with the costs then go Iridium, but I would not fit and forget, ever Rolling Eyes
P. S. I do use both (not on same bike).
delsol
PostPosted: 14:53 - 06 Jul 2015    Post subject: Reply with quote
Acerman wrote:
Bought a 15 year old bike with original plugs on due to low mileage, no problem getting plugs off. If thats a problem you can always realese and tighten plugs once a year. Remove plugs when engine is hot!!
In 15 years, were you the first person to remove those plugs to check clean and gap them ?
PostPosted: 15:08 - 06 Jul 2015    Post subject: Reply with quote
Spark plug is a spark plug.
Unless you are racing in competition type events and notice that 0.001bhp or that 240,000 spark or the fact its missed 1.... then no. Copper all the time.
geraghty125
PostPosted: 18:12 - 06 Jul 2015    Post subject: Reply with quote
Thanks to you all i have made the decision to buy the iridium to try it out
Thanks again
ADSrox0r
PostPosted: 18:22 - 06 Jul 2015    Post subject: Reply with quote
You will notice a whole world of fuck all difference, other than in your wallet.
PostPosted: 18:36 - 06 Jul 2015    Post subject: Reply with quote
Acerman wrote:
Really good plugs
In what way?
Pigeon
PostPosted: 18:47 - 06 Jul 2015    Post subject: Reply with quote
I've put them in two bikes and on both have found the bikes start before the button is even half way pressed in. But that this continues for 3,000 miles, whereas on copper plugs I'd notice a couple of turns would creep in.
That being said, I won't be buying them for the Street Triple as there are a few reports out of loss of power and poor running, possibly due to the actual plug being a different layout to OEM (dual ground on copper, single on iridium).
There are plenty of people who report rough running with Iridium. Best to find someone else with your bike who's used them if possible.
stevo as b4
PostPosted: 18:55 - 06 Jul 2015    Post subject: Reply with quote
Possibly an advantage in a four stroke. Less so in a two stroke, where plugs are supposed to be thrown away at around 2000miles, assuming they havn't oil fouled first that is.
blurredman
PostPosted: 19:14 - 06 Jul 2015    Post subject: Reply with quote
I use an iridium on my 2t MZ, it never fouls up even if I under-gear it like crap at slower city speeds. Just gradually roll on the throttle and everything is happy. There is absolutely no performance difference, but at least when the bike stalls or w/e I can pretty much rule out spark plug foul immediately.
Not used it on a 4t, but I can imagine that I might use them if the spark plugs on a bike were particularly poor to access or the rings were particularly worn and I didn't want to open it up yet.
Fidge This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 08:04 - 07 Jul 2015    Post subject: Reply with quote
Acerman wrote:
-Lower voltage required.
If your bike is missing ignition with the plugs it was designed to use that's a good sign that you've got a problem somewhere else.
Acerman wrote:
-Increased plug service, we are talking about 10 times normal plug.
Agreed.
Acerman wrote:
-Improved throttle respons.
https://cdn.meme.am/instances/400x/58265434.jpg
Have you been reading the NGK marketing blurb?
Fizzer Thou
PostPosted: 10:28 - 07 Jul 2015    Post subject: Reply with quote
I fitted an Iridium plug to my 450 Enduro and it did make a difference to throttle response.
But I also found that the plug specified by KTM is okay for 'normal' use but with the Iridium item I can use a decent NGK plug cap which is way better than the notoriously unreliable standard plug cap.
Two friends with KTM 525s also found that their bikes ran better with the Iridium plugs.
But on a restricted 125 I would not bother
Always have a 'Plan B'
The last post was made 11 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.18 - MySQL Queries: 15 - Page Size: 105.66 Kb
