| Method |
 Method World Chat Champion
 Posted: 00:30 - 04 Feb 2005 Post subject: 10W 40 / 15W 40 |
Hey, being an ex car mechanic i guess i should know this realy lol but at this time of night i realy cant think.
Basicaly my GS500E says it takes 10w 40 oil, i got some 15w 40 from my mums car boot, will it be ok to put in my gs? ____________________ CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado
My Bikepics.com - No Brakes, No Gears... No Fear. |
| Robby |
 Robby Dirty Old Man
| Scotsman37 |
 Scotsman37 World Chat Champion
 Posted: 01:11 - 04 Feb 2005 Post subject: |
Here's Chevron explanation of the differences between 10W/40 and 15W/40;
What is better a SAE 10W-40 or an SAE 15W-40?
Using the simple rules above it is clear to see that both of these oils have a similar high temperature viscosity as indicated by the '40'. However the 10W-40 is a thinner oil than the SAE 15W-40 at cold temperatures. Simply apply the rule that the lower the 'W'; number the thinner the oil. The SAE 10W is lower than the SAE 15W and hence is a thinner oil. Therefore in cold temperatures we can state that the SAE 10W-40 oil is better than the SAE 15W-40 oil. In winter the end user may experience a benefit by moving from an SAE 15W-40 oil to an SAE 10W-40 oil.
Mineral Oils Versus Synthetic Oils
There is much discussion about mineral oils versus synthetic oils and the relative performance of each type. It is clear that synthetic oils offer certain advantages over mineral oils in terms of low temperature performance, and high temperature oxidation stability but that is not the whole story. Synthetic oils are very expensive and properly formulated mineral oils are more than suitable for most engine applications. A synthetic oil can be considered for very cold temperatures, or for application that may need an outstanding level of oxidation protection but it should be remembered there is a significant cost. The question should always be asked: ‘Can I use a properly formulated mineral oil for this application?
The Society of Automotive Engineers Viscosity Classification
The terms SAE 10W-30 and SAE 15W-40 are widely used. How many people actually understand what these terms mean?
Firstly any viscosity grade should be proceeded by the initials SAE. This stands for the Society of Automotive Engineers and indicated that the following viscosity classification refers to their definitions. It should be noted that SAE is not a performance category it only refers to the viscosity of the oil. When comparing oils the reader should not only compare the SAE viscosity grades of two oils but also the engine performance classifications in order to be able to fully compare performance.
Let us consider the following: SAE 15W-40.
The fact that this classification has two parts; the 15W and the 40 indicates that the oil is a multigrade. The first number with the suffix 'W' indicates the oil's performance at low temperature. In fact the 'W' stands for winter. The lower the 'W' number the lower the viscosity of the oil. Therefore an SAE 5W oil is a lower viscosity oil than an SAE 10W oil.
The number after the W, in the above case '40'; gives a measure of the oil's viscosity at high temperature. Again the lower the number the thinner the oil is at high temperature. So an SAE 30 is a thinner, or less viscous, oil than an SAE 40.
Viscosity
This is simply the most important feature of any lubricating oil. It can be defined as a fluid's resistance to flow. As the temperature of an oil increases its viscosity decreases
Here's a link explaining what the acronyms mean in regards to engine oil classifications;
https://www.chevron.com/prodserv/ehl/acronyms.htm |
| Method |
 Posted: 01:20 - 04 Feb 2005 Post subject: |
wow, a big HUG for that man lol  ____________________ CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
| bish777 |
 bish777 World Chat Champion
| Scotsman37 |
| Kickstart |
 Kickstart The Oracle
| Rory |
 Rory Traffic Copper
 Posted: 14:56 - 04 Feb 2005 Post subject: |
I was under the impression that some cheaper / own-brand oils were made from recycled oil, meaning there are fewer long chain molecules to lubricate and protect at higher temperatures (the long molecules having been chewed up during use in an engine). ____________________ My Old CBR400RR | Bike Oil FAQ | Petrol FAQ |
| Scotsman37 |
| Claud 14.7 to 1 |
 Claud 14.7 to 1 World Chat Champion
| Kickstart |
 Posted: 17:44 - 04 Feb 2005 Post subject: |
I can see no reason at all why the oil should have affected your top speed, especially on a 2 stroke. All it is affecting is a bit of drag in the gearbox and clutch and that will be the same for any oil of the same viscosity. Should not really cause a problem even if you overfilled it a bit (although overfilling it a lot will cause more drag). Only potential issue would be if it caused clutch slip, so the engine was still revving but not actually reaching its speed.
The oil could allow damage to the gearbox, but in such a situation it would definatly not get better when you changed the oil.
Unsure about the reuse of oil (think most used engine oil just gets reused as heating oil). Some people claim that it is actually a better base for the oil anyway, with the weaker long chains already broken as discarded. Mind you this certainly did not apply to the used engine oil (not recycled, just out of his fathers car) that a friend used in his old clunker of a car .
| Scotsman37 |
 Posted: 18:08 - 04 Feb 2005 Post subject: |
Any company can harp on about how great their products are, but the truth is in the pudding. The conclusion I came to as several other people that used their oil in the past with their vehicle is that they lost performance which they used to have before filling up with it. That's even the opinion of my Uncle how has 35 years experience as a Consultant Marine Engineer because he advises others NOT to buy Halfords but Castol GTX or something similar. So, I got the info confirmed by a Pro and by my own experience of using Halfords oil.
Basically, I will never buy Halfords' engine oil again !
P.S. it was filled correctly.
Have you ever seen a Halford's sticker on a side of SBK / MotoGP bikes or even racing cars/boats showing that we're using Halfords oil and so it makes you think doesn't it - why?
| Scotsman37 |
| Claud 14.7 to 1 |
| Robby |
 Robby Dirty Old Man
| Git |
 Git Brolly Dolly
| Kickstart |
| bish777 |
| Claud 14.7 to 1 |
| Scotsman37 |
| Kickstart |
| Fortuna |
 Fortuna World Chat Champion
The last post was made 21 years, 144 days ago. Instead of replying here, would creating a new thread be more useful? |
