Shifting!
OneWithBike
PostPosted: 23:06 - 06 Jul 2015    Post subject: Shifting! Reply with quote
Hi guys just a quick few questions;
I'd just like to add this is my first geared bike
I have a 2010 r125 and it's perfect, no issues once I'm going at all and I'm getting the knack of upshifting in time etc.
But here is where the problem is, I don't know what to do at traffic lights.
I tried downshifting to neutral which I'm finding difficult to do (if it does it at all) but when I stop at lights in first gear it just cuts out and (it's bloody embarrassing but I guess we all start somewhere) I have no idea why it's doing this, it's really frustrating.
Any help would be appreciated
Cheers Thumbs Up
PostPosted: 23:10 - 06 Jul 2015    Post subject: Reply with quote
Hold the clutch in when you roll to a stop or it'll stall every time.
johnnyarctic
PostPosted: 23:11 - 06 Jul 2015    Post subject: Reply with quote
did you do your cbt on a geared bike?
Current Ride: VFR750
OneWithBike
PostPosted: 23:21 - 06 Jul 2015    Post subject: Reply with quote
No I did it on a ped unfortunately, so I literally have no experience. I stalled on a roundabout earlier Embarassed
johnnyarctic
PostPosted: 23:27 - 06 Jul 2015    Post subject: Reply with quote
eep. do some proper training, massive benefit you and your going to do tests anyway right?
meanwhile find a quiet road near and go up and down practicing starts and stops. pull the clutch in when your stationary
NJD
PostPosted: 23:32 - 06 Jul 2015    Post subject: Reply with quote
I stalled at a set of traffic lights attempting to take off earlier, although the van behind had drifted lanes and almost made a imprint of me in the side of his van just moments before, so was it a mistake or troll disguised with fake apology? Rolling Eyes
Several months OTR, we all do it from time to time.
Long and sweet of it is, when you know that your going to be stopping dead, completely not movement, shift down into 1st and keep the clutch pulled in a stand still, then let out and apply throttle to get going again.
If light could go from red to green or traffic gets going etc then keep the bike in 2nd, hold the clutch in and feather it along with some throttle, slow control.. it all come in time.
If you ever find yourself stationary with the clutch out or your hand no where near it and the bike is running you have issues, means the clutch is always engaged, turn the bike off and fix ASAP to prevent clutch burning up, enjoy the smell if not.
Don't shift into neutral, some people who make youtube videos do it, bad habit, means your not prepared and literally can't go anywhere you loose momentum and drive completely and are doing nothing but rolling to a stop, if someone was to go into the back of you it ad be safer to be in 1st to have a chance of moving out the way rather than a few more seconds attempting to downshift and then move.
PostPosted: 07:56 - 07 Jul 2015    Post subject: Reply with quote
You're coming to a stop in 1st gear, clutch level pulled all the way in, and the bike stalls?
I'd check the cable tension. There should be just a tiny bit of free play at the lever before the tension comes on the cable.
arry
PostPosted: 08:00 - 07 Jul 2015    Post subject: Reply with quote
Potentially as Roger says - especially since you mention it's seemingly difficult to get to neutral. Sounds like the clutch may be dragging slightly
OneWithBike
PostPosted: 10:54 - 07 Jul 2015    Post subject: Reply with quote
Thanks so much guys, your solutions have been very helpful Thumbs Up
Wonko The Sane
PostPosted: 19:07 - 07 Jul 2015    Post subject: Reply with quote
chain tension on my 125 could make finding neutral a bit harder than usual
However it's good practice for test to be foot on brake, left foot on floor in 1st gear holding the clutch ready to set off.
Pigeon
PostPosted: 19:52 - 07 Jul 2015    Post subject: Reply with quote
Once the bike is warm, make sure the idle is set correctly too......Somewhere around 1400 rpm probably, but the manual will say.
Barnoe
PostPosted: 23:13 - 07 Jul 2015    Post subject: Reply with quote
Try this tomorrow.
when your gearing down for a red light, gear down to 2nd pull in clutch and step down to 1st keeping clutch in... then brake to a stop.
Dont try and ride up to the line in 1st, its such a low gear on a 125 you will probably wobble and stall
You should be able to slow to almost a stop in 2nd, just drop to 1st about 10 feet before stopping.
All ive said above wont apply once you get plenty of miles experience and more confidence. You will do all the gear changing like a reflex and without much thought.
As for the stalling..... i hope its just you riding in 1st and braking at same time, because thats the easiest to fix Very Happy
You know you are old when you're told to slow down by your doctor and not the police.
The last post was made 11 years, 69 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 73.42 Kb
