When sat at traffic lights ?
johnte
PostPosted: 16:53 - 07 Jul 2015    Post subject: When sat at traffic lights ? Reply with quote
Is it OK to sit in 1st with clutch pulled in, or are you supposed to wait in neutral with foot on rear brake, then into gear as lights change (when doing test)
Thanks
PostPosted: 16:56 - 07 Jul 2015    Post subject: Reply with quote
Either is fine whatever you are more comfortable with.
DrSnoosnoo
PostPosted: 17:01 - 07 Jul 2015    Post subject: Reply with quote
I asked this same question. I was told, do what feels comfortable. But be ready to go when it goes green or you could be "punished".
Minty
PostPosted: 17:04 - 07 Jul 2015    Post subject: Reply with quote
OP, when do you blip the throttle? You don't state. Thinking
My fingers smell of your mum.
petalbriefs
PostPosted: 17:15 - 07 Jul 2015    Post subject: Reply with quote
I was taught to be in 1st and hold the clutch in, but I have since read about a couple of people, who were rear ended at lights and due to being first etc, accidentally wanged the throttle open and sent the bike flying.
Had they been in neutral, they probably would have just fallen off.
Each to their own though
Proud owner of an R6 Smile + ZXR400
Honda CBR 125 R - Stolen
Matt B
PostPosted: 17:17 - 07 Jul 2015    Post subject: Reply with quote
For the purposes of the test the examiner would prefer yo to stay in 1st with the clutch pulled in. This is because they always want to see you stopped in the safety position - left foot down and right foot up on the rear brake.
If you go into neutral at the lights you have to come out of the safety position which they don't like. It also saves you from doing the 'Hendon Shuffle' (google it or ask Tef).
Normal riding - do what you want but instructors preparing you for test should teach safety position and 1st gear at the lights.
Boxing
PostPosted: 17:20 - 07 Jul 2015    Post subject: Reply with quote
I sit in N at the front of the queue watching the pedestrian lights, when they turn red the cars from the other junction are likely to turn into your road or your lights are about to go green, so get ready to set off.
It all depends how long I'll be waiting really. You can easily swap feet so isn't the end of the world if the light turns green anyway.
Matt B
PostPosted: 17:23 - 07 Jul 2015    Post subject: Re: When sat at traffic lights ? Reply with quote
johnte wrote:
when doing test
OPs question relates to what he should do during a test...
thx1138
PostPosted: 18:09 - 07 Jul 2015    Post subject: Reply with quote
I try and stand up on the pegs without moving, I rarely make it to the green light though.
blurredman
PostPosted: 18:36 - 07 Jul 2015    Post subject: Reply with quote
I sometimes use left foot down and in gear if I know the lights will change imminantly, or right foot down, right hand on brake left foot hovering over gear selector. Only takes a second longer.
trevor saxe-coburg-gotha
PostPosted: 18:51 - 07 Jul 2015    Post subject: Re: When sat at traffic lights ? Reply with quote
Matt B wrote:
johnte wrote:
when doing test
stevo as b4
PostPosted: 19:00 - 07 Jul 2015    Post subject: Reply with quote
Either is fine I reckon, though with a heavy clutch if you don't need to hold it in for more than 5-10sec that's gotta be a bonus.
The one absolute thing you should never do at traffic lights and junctions, is put your right foot down, and have the gear change foot on the peg instead.
I just see this as lazy, can't be arsed biker's, who don't give 2fucks. If your rear brake is not applied you have no positive control over the vehicle and keeping it still, especially if someone nudges you from behind etc. It's also good practice to show a brake light when stopped especially when in wet, dark or poor visibility conditions.
There's no need to have your left foot on the peg ever when stationary, unless you have cramp in the right leg maybe? Wink
The same goes for all the wanker car driver's who sit with the foot on the brake everytime they are still. The handbrake is a great and useful tool so use it as much as possible, you won't wear it out!
Wonko The Sane
PostPosted: 19:05 - 07 Jul 2015    Post subject: Reply with quote
I sit at lights with foot on brake, clutch in
I got rear ended and I'm convinced it stopped the bike going into the middle of the junction as it stalled and skidded as I got knocked off. But then you have to put some throttle on my iL4 for it to set off, a twin might happily set off
Barnoe
PostPosted: 20:26 - 07 Jul 2015    Post subject: Reply with quote
If your right at the front, i would personally sit with clutch in.
If your a few cars back then this will give you more time.... as lights change you have a good few seconds before moving away anyway.
As lights go green and the cars at front start slowly pulling away, this will give you plenty of time to get in gear Smile
If the lights change at the front and your in neutral, the quick change looks like a silly dance lol
Not perfect for test conditions :/
If your nervous.... just sit with clutch in anyway Wink
You know you are old when you're told to slow down by your doctor and not the police.
bamt
PostPosted: 21:12 - 07 Jul 2015    Post subject: Reply with quote
(Note that the following does not apply to DVLA test conditions, so should be ignored by the OP)
Right foot down, in neutral, is perfectly acceptable - and, in fact, is generally preferred by IAM (depending upon conditions, camber, etc., etc.) as it means you can sit in neutral (more mechanical sympathy, not likely to slip off the clutch and jump forwards) with the front brake holding the bike, and knock it into gear and off without doing the Hendon Shuffle.
The other advantage of sitting in neutral, especially on the flat, is that it is the only way you can do a proper two-handed drum solo on the tank whilst waiting for the lights (or level crossing, which takes even longer so gives you much more opportunity to practice your percussion skills).
johnte
PostPosted: 21:15 - 07 Jul 2015    Post subject: Reply with quote
Ok thanks everyone Thumbs Up
I do sit with clutch in, but wasn't sure if this was ok for test purposes- seems it is...
PostPosted: 21:43 - 07 Jul 2015    Post subject: Reply with quote
Why would you be a few cars back on a bike? You would have filtered to the front wouldn't you.....
stevo as b4
PostPosted: 23:00 - 07 Jul 2015    Post subject: Reply with quote
I totally agree with being in neutral for any extended period of more than say 5sec or so. And there are many reasons why being in neutral and applying one of the brakes is a good practice.
But what is wrong with the Hendon shuffle exactly? I was taught that way for road riding, and it's stuck with me and second nature now, just as applying the handbrake and shifting to neutral in a car when stationary at all times.
bamt
PostPosted: 23:17 - 07 Jul 2015    Post subject: Reply with quote
There's nothing actually wrong with it - except it takes time and is a bit of a dance when you could just smoothly click into gear and go.
Barnoe
PostPosted: 23:18 - 07 Jul 2015    Post subject: Reply with quote
Not on my test i wouldnt Shocked
stevo as b4
PostPosted: 23:44 - 07 Jul 2015    Post subject: Reply with quote
Perversely should safe and courteous filtering not be a mandatory training module and part of any test these days though?
c_dug
PostPosted: 05:47 - 08 Jul 2015    Post subject: Reply with quote
If I remember correctly, sitting with the clutch pulled for a prolonged period can damage one of the clutch bearings in some big BMWs. No idea if that applies to any other bikes, but maybe worth bearing in mind.
ADSrox0r
PostPosted: 07:28 - 08 Jul 2015    Post subject: Reply with quote
I tend to think of it like the handbrake, if a pause becomes a wait then I'll nudge up to neutral. I just gauge it by the light sequence, if they've just changed then neutral but if I'm rolling up and they're on red with a couple of cars I'll likely just stay in first.
I'll be honest though, if I'm in neutral I sit both feet on the deck and relax. I very rarely sit with the rear brake on in first, only if it's a hill start. A habit that no doubt will get tuned out of me the first time I get a nudge in the shitpipe.
The Disapproving Brit
PostPosted: 15:58 - 17 Jul 2015    Post subject: Reply with quote
Depends on local knowledge for me. If I've just missed the green phase and I'm familiar enough with the lights to know their timings (i.e. if they're on my commute), I'll consider dropping it into neutral and relaxing a bit. If I don't know exactly when the lights are going to change, I'll stay in first and clutch in.
What you don't want to do, doubly so in a test situation, is have a panic moment where the lights start to change and you're still in neutral.
Current Bikes: 1983 Honda VF400FD / 2003 Honda VT750 Shadow
Bike Test Passed 18/03/09, Car Test Passed 14/05/13
notbike
PostPosted: 17:37 - 17 Jul 2015    Post subject: Reply with quote
Either one, depends if the traffic light is long or not. Don't fancy being hunched over a stationary bike fondling the clutch lever for more than 10 seconds, it's not as comfortable as using the bike as a chair.
The last post was made 11 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 130.53 Kb
