Bike firing on 3 cylinders
mikesaa309
PostPosted: 19:09 - 12 Jul 2015    Post subject: Bike firing on 3 cylinders Reply with quote
I'm getting quite annoyed, I have a bandit 600 1997 model and the other day i started it up and it's only running on 3 cylinders but once I get to around 5 to 6,000 rpm the number fourth cylinder starts firing until the revs drop again.
After checking every spark plug was making a spark I found there was a chunk of plastic missing from the cap on number 4 cylinder and was tracking out obviously. So as the original caps are about 21 quid each from wemoto and other places, I got a patterned Cx500 cap from David Silver Spares. This worked for a while but then went back to 3 cylinders again.
Used mutlimeter and I'm reading between 11-15k ohms for all the spark plug caps (including the broken one) but the cx one Is giving a negative number. So I swapped it for the original one of my dads cx500 which is reading 4-5k ohms on the multimeter and still not firing. Dad also tried using the patterned cx one on his bike and it runs and performs as usual.
Using the multimeter I put the prongs of the multimeter into cylinder 1 and 4 sparkplug caps to check and it's reading 15k ohms and same with the caps off and putting the prongs straight into the HT leads and still got 15k ohms. I can't find any solid reliable information on what reading I should be getting but from what I found the spark plug caps should only be reading between 5 to 10 ohms. (multimeter set on 20k ohms for each test I did btw).
Anyone know the Ohms reading I should be getting?
MCN. This post is not being displayed because the poster is banned. Unhide this post / all posts.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:51 - 12 Jul 2015    Post subject: Reply with quote
Typically, you don't lose 1 cylinder on a modern in -line 4, but two becuase they all work by wasted spark. The only time you would is if the gap on the spark plug is completely closed.
Have you checked which exhuast pipes are getting hot (from cold) when you start it?
Still think you're a fucking twat, btw.
Triumph Sprint ST 1050
nowhere.elysium
The Pork Lord
PostPosted: 21:02 - 12 Jul 2015    Post subject: Reply with quote
Unless he's got a blocked carb jet. Probably clogged with tedious bullshit.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:11 - 12 Jul 2015    Post subject: Reply with quote
Idle jet?
So he was wasting his time fucking about with a multimeter?
nowhere.elysium
The Pork Lord
PostPosted: 21:46 - 12 Jul 2015    Post subject: Reply with quote
Not necessarily, but since he's swapping parts out on the basis of "well, this one's cheaper", we might as well give him something totally free to look at.
WD Forte
PostPosted: 22:40 - 12 Jul 2015    Post subject: Reply with quote
negative resistance on the CX cap eh?
that's a neat trick.
keep talking bollocks about the electricals to it
it'll soon give in and run properly just to get you to STFU
bikers smell of wee
andyscooter
PostPosted: 08:09 - 13 Jul 2015    Post subject: Reply with quote
so
Suzuki one was expensive
so you bought one for a Honda that was from a smaller engine so possibly not designed for as much currant
and it doesn't work Shocked Shocked
what do you think may be wrong
talkToTheHat
PostPosted: 12:01 - 13 Jul 2015    Post subject: Reply with quote
NGK aftermarket plug caps? I'm sure you can find some at 10kOhm. Negative resistance means either your multimeter is not calibrated (compare to probes touching each other) or the plug is working as a battery, if so clean any corrosion off and apply a water displacer.
Friend's clio had similar problem with damaged plug cap, fixed with cheap aftermarket plug cap and ht lead pulled from the wreckers.
Bandit. does. everything.
WD Forte
PostPosted: 12:15 - 13 Jul 2015    Post subject: Reply with quote
On CX plug caps
The original caps had screw in resistors ( 4-5K as i recall) fitted
which were only there as a concession to RF interference.
The resistors often rotted and turned to black dust over the years so
many owners swapped them for patterned caps which were
cheaper and straight through, ie non resistor as well as virtually trouble free.
All the ones I've had did not have the magical negative resistance
just the very low resistance you'd expect from a short peice of brass.
bikers smell of wee
talkToTheHat
PostPosted: 12:47 - 13 Jul 2015    Post subject: Reply with quote
Indeed the diagnostic behaviour suggests the HT lead might be damaged or something is wrong with the coil.
If there is significant current flowing through the high voltage size of the ignition, I'd panic. Current should be small and size of 10k resistor is negligible compared to about 0.8mm of fuel-air mixture.
mikesaa309
PostPosted: 17:21 - 13 Jul 2015    Post subject: Reply with quote
knew I shouldn't have come back here for help...
After checking all spark plug caps and they all read 13k ohms but cx one reads 4k ohms I've found a original suzuki bandit sparkplug cap from a breaker and just waiting for it to arrive in the post.
UrbanRacer
PostPosted: 23:24 - 13 Jul 2015    Post subject: Reply with quote
lol at this sh!t Laughing
The last post was made 11 years, 94 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 87.57 Kb
