Slow ride - Mod 1
markk21
PostPosted: 10:23 - 12 Jul 2015    Post subject: Slow ride - Mod 1 Reply with quote
I've been practicing slow riding on my 125 to try and improve my balance. It got me wondering about what is the speed you would ride at during the slow ride part of mod 1? I can ride okay at 7mph but anything lower and I start to lose control.
CBT: July 2014
1st Bike: 2014 Keeway RKV 125
Dream Bikes : Yamaha MT-07 - Yamaha R6 - BMW S1000R
Nexus Icon
PostPosted: 10:25 - 12 Jul 2015    Post subject: Reply with quote
I don't know if this still happens but the instructor used to walk alongside the bike. Given walking pace is around 3mph, I'd say you still have some work to do.
Greetings from Shitsville!
RE8ELD0G
PostPosted: 10:30 - 12 Jul 2015    Post subject: Reply with quote
keep revs high and work the rear brake and clutch, the revving engine adds a gyroscopic effect and really helps keep the bike upright and in a straight line.
I was doing around 5-6mph (digital speedo) on my mod 1 and passed no worries.
Its a fine line between an cuddle.......
And holding her down so she cant get away..!!!
Honda Varadero XL 125
Yorkshire Geek
PostPosted: 11:24 - 12 Jul 2015    Post subject: Reply with quote
I did 6 according to the speedo and got told "I'm not jogging for you" so dropped it back a bit, 7 is probably pushing it. More revs, slip clutch, drag back brake.
markk21
PostPosted: 11:26 - 12 Jul 2015    Post subject: Reply with quote
Thanks. I'll go and try it out today
CBT: July 2014
ScaredyCat
PostPosted: 11:29 - 12 Jul 2015    Post subject: Reply with quote
Look further ahead of you and don't tense up. Use your knees to grip the tank don't grip the bars with the grip of death.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
zark
PostPosted: 11:46 - 12 Jul 2015    Post subject: Reply with quote
Don't bother practicing on a 125... The slow ride is a million times easier on your test bike...
I just practiced my slow ride from the car park to the mod 1 pad (took ages to get to the gate!) And again from the gate to the manual handling area. Just helps to get your eye in, but 7 on a 125, you'll be fine on a big one
CBT - Oct 13. Theory - July 14. Mod 1 & 2 - June 15.
Rides a Fazer like an idiot... Edit: Now ride a Fazer Thou...
pig hog
PostPosted: 13:40 - 12 Jul 2015    Post subject: Reply with quote
As most other posts, keep the engine busy with throttle and clutch control; control your speed with the rear brake, this also keeps you more planted and much more stable. Raise your vision and look well ahead for balance, not at the tarmac in front of you. On my bike, at least, you should be able to crawl along with the speedo showing 0 with both feet up.
Same technique can apply for the slalom, figure of eight and U-turn, too.
I disagree with not bothering to practice on a 125—if you can do it well on a little bike, then it'll be even easier on a big bike.
EDIT: and relax! Light grip on the bars and loose elbows makes it much easier that being tensed up, holding on with a death grip.
A2 Licence: 18/10/2013
A Licence: 01/12/2015
'13 Yamaha XJ6N '15 Daytona 675R / '16 MT-07 dead / '17 MT-07 / '18 MT-10
markk21
PostPosted: 20:05 - 12 Jul 2015    Post subject: Reply with quote
Tried it today using your advice and it was much better. Managed to get down to 3-4mph and I was steady. Thanks
Also, what would you say the rough distance between start point and finish point is for the u turn in mod 1?
Thanks
CBT: July 2014
ScaredyCat
PostPosted: 20:07 - 12 Jul 2015    Post subject: Reply with quote
Thanks
It's more than 3 standard parking spaces wide at 7.5m ...
Have a look here... measurements on page 3
NJD
PostPosted: 22:26 - 12 Jul 2015    Post subject: Reply with quote
The best training for the slow ride part is to play the game of "lets not put your foot down" for an entire ride, helps with forward planning and teaches you balance and good control of the bike, outside of that the only practice I had was going from the path to the nearest drop kerb in a straight line, really, it's not that hard Rolling Eyes
Examiner watches you as you go from a complete stand still for a short distance into or just before four cones ready for the u-turn.
I found it easier on the GS 500 over my Arrow as I included the rear disc brake (on the GS) and was laughing at how much control I had, the bike was doing all the work for me.
talkToTheHat
PostPosted: 08:57 - 13 Jul 2015    Post subject: Reply with quote
Don't start the u-turn super-close to the left hand line, if you are confident, your countersteer motion will take you briefly over the line. If you are hesitant you risk running wide at the other side. Treat it like a regular kerb. Room to put your foot down.
I found that turning slightly towards the kerb and then turning hard right worked better for me as the bike passed the left line already turning tightly. However I was riding a GZ that had the turning circle of a barge.
Bandit. does. everything.
PostPosted: 12:53 - 13 Jul 2015    Post subject: Reply with quote
It's changed, you do the figure 8 (slowly), the examiner walks over to where you'll do the u-turn (slowly) and asks you to ride over to him (slowly).
It's pretty much trivial if you can do the two pieces either side. It's not a trials balance test, just go and stop.
Kaneda80
PostPosted: 18:09 - 13 Jul 2015    Post subject: Reply with quote
sounds like you have it down now, but when i was learning i was afraid to rev high (feels so different from a car) but it really helps to keep the revs up and just control the speed with the clutch and back brake.
Easier said than done i know there's a lot to think about, especially on a 125 they just aren't as smooth, but if you can do it on a 125 you can do it on a bigger bike.
good luck with your mod 1!
I like turtles
HughiusMaximu...
PostPosted: 21:17 - 13 Jul 2015    Post subject: Reply with quote
Key for the u turn is to look over your right shoulder as you drop in to the turn.
Its the old story of the bike goes where you look, so a nice tight turn will follow...
markk21
PostPosted: 09:08 - 16 Jul 2015    Post subject: Reply with quote
Thanks for the tips. I'm okay with the u turn most of the time. I realised what I was doing wrong a few weeks ago. I basically just went full lock just before half way in the u turn. It feels like the bike will fall but it hasn't yet. This might be not what you're supposed to do but it's worked every time for me on the 125
CBT: July 2014
The last post was made 11 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 89.74 Kb
