| arfdlt2456 |
 arfdlt2456 L Plate Warrior
| TheGazWaz |
 TheGazWaz Nitrous Nuisance
| talkToTheHat |
 Posted: 11:43 - 13 Jul 2015 Post subject: |
Dragstar 650 engine is similar to the old 535 with a pair of mikuni BDS downdrafts, float covers on left hand side? If so you should be able to get to the important bits of carbs without removing them from the bike.
Check rear brake for play, there should be 30mm pedal movement before the brake comes on. Check front brake spins freely, dirty pistons could mean rubbing brakes. If there is air in the system it could only be rubbing when the brakes are warm, so check your lever feel.
Check plugs as above.
Check oil does is smell strongly of petrol? is there *more* than there should be? is it super thin? If so open float bowls, clean float valve seats and replace float valves. Change oil and filter. Check oil for metal particles
Check fuel level in the float bowls. could just be a bit high and you're running rich. Open float bowl, bend the tang on the float, reassemble, recheck, repeat as required.
When did you last have valve clearances done? I know the 535 needs a check every 4000 miles, suspect the 650 is similarly annoying. ____________________ Bandit. does. everything. |
| chris-red |
| talkToTheHat |
| WD Forte |
 WD Forte World Chat Champion
| Teflon-Mike |
 Posted: 14:32 - 13 Jul 2015 Post subject: Re: bad fuel mileage |
| arfdlt2456 wrote: | Last year's ridding season |
Power is Rate of change of Energy.. so as a rate at which petrol get's turned into motion, MPG is an expression of 'Power'.. and where the power 'rating' given in the specs is more a 'potential' rating of how much power the motor might make at certain revs and load, MPG is actually a better guide of how much power you are 'using'.
As such, actual real MPG figures vary far more from what they say in the specs than top-speeds... My VF1000, was reportedly 'rather thirsty' with a book figure of 30mpg... was rather perturbed then to discover I could get that down as low as the 'teens' caning the thing along by-passes between roundabouts and city commuting... but conversely, quite relieving to discover that bimbling about the Cotswold on a Sunday, I could get it up near 70!.. a more extreme example, but it effects all bikes, and the 750, is supposed to return 45mph according to the book, but I can get that down in the 20's caning it every where, or doing short runs, or up nudging 70, if I'm on a longer run just bimbling.
One thing about the 750, is it's air-cooled, and needs a bit of choke to start, unless its a nice warm day, and we ent had so many of them this summer, so not had many choke-free start ups this year....
So, given the vagaries of mpg, this years weather could easily account for a bit of a drop, using more choke on start up, and more start-ups would make bigger difference; next, others suggestions imply that 'last year' you got particularly 'good' consumption for the bike.. has the way you use it changed since last year? And are you riding it shall we say 'more confidently'.. using more power, more often, bringing mpg down?
Might be little wrong with the bike... and if there is, as has been suggested, first call is basic service items; plugs, filters. tappets, carb-balence etc.. even a weak battery.. silly one that, but if the battery is a bit tired and takes a bit longer to spin the motor into life... it's more unused fuel sucked in, possibly more, on choke, not being 'used' to do anything. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 14:37 - 13 Jul 2015 Post subject: |
| chris-red wrote: | | talkToTheHat wrote: |
Check rear brake for play, there should be 30mm pedal movement before the brake comes on. . |
Really? that seems excessive, I don't think any of my bikes have 30mm of movement across the entire range of lever travel, I.e. from rest to all my weight on it. |
I was about to advice you the same thing + check the wheel bearings and tyre pressure on both wheels. Dragging brakes, worn bearings, low tyre pressure can do alot to your MPG.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| monkeybiker |
 monkeybiker World Chat Champion
 Posted: 18:37 - 13 Jul 2015 Post subject: |
I'd be checking for fuel leaks  |
| Casper |
 Casper World Chat Champion
 Posted: 19:41 - 13 Jul 2015 Post subject: |
| talkToTheHat |
The last post was made 11 years, 96 days ago. Instead of replying here, would creating a new thread be more useful? |
