Yamaha xt 125 x dash issue
Ollie2201
PostPosted: 09:37 - 14 Jul 2015    Post subject: Yamaha xt 125 x dash issue Reply with quote
Hi everyone, I went to go out on a ride yesterday and my dash had partially stopped working. The dash flickers on and off and keeps saying endr or ntrd, then when I select ntrd it lights up and then turns off. Also when I start the bike the dash will turn off completely, it also flickers between ntrd and endr without the key being in the ignition. Also the neutral light , headlight and indicator lights around the dash work fine. Any ideas? I appreciate any help/advice.
Just_James
PostPosted: 10:13 - 14 Jul 2015    Post subject: Reply with quote
When you 'select' ntrd are you holding in the 'pass' button on left switch gear?
Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125
Ollie2201
PostPosted: 10:23 - 14 Jul 2015    Post subject: Reply with quote
Yes, when I press the mode button to select what bike I have it then says 125 ntrd , then it lights up as it should but then turns off after.
Ollie2201, Yamaha xt 125x
Just_James
PostPosted: 10:29 - 14 Jul 2015    Post subject: Reply with quote
Have you tried disconnecting the battery for a few minutes then trying again?
Taught2BCauti...
Check your battery voltages, check for loose connectors, and have a look at This Thread.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Ollie2201
PostPosted: 12:57 - 14 Jul 2015    Post subject: Reply with quote
Thanks for the help everyone , but I think it's going to need replacing with a new or aftermarket one Sad
The last post was made 11 years, 96 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 51.86 Kb
